NYUK Posted November 25, 2008 Report Posted November 25, 2008 i need to move my cdi and voltage regulator. can`t seem to find a good spot. anyone with an idea. or who has done such, post up.i put on a subframe and want no wires running from it. Quote
wacko2000 Posted November 25, 2008 Report Posted November 25, 2008 John what about the Bracket that GB racing sells??? http://gbracing.everything2stroke.com/index.html Quote
NYUK Posted November 25, 2008 Author Report Posted November 25, 2008 i e mailed him. i wonder if it will work with a toomey radiator. and will it interfere with a nology coil, being so close. Quote
wacko2000 Posted November 25, 2008 Report Posted November 25, 2008 i e mailed him. i wonder if it will work with a toomey radiator. and will it interfere with a nology coil, being so close. I dont kno about all that, but i have emailed him a few times, he responds pretty quick. I like the idea of the bracket, real clean look.. he also shortens/cleans the harness for a few bucks Quote
baddsheee Posted November 25, 2008 Report Posted November 25, 2008 i e mailed him. i wonder if it will work with a toomey radiator. and will it interfere with a nology coil, being so close. I have one of these brackets and never got aound installing it. I also have a toomey radiator and wondering if it will work. I'll have to dig up the bracket and check. Quote
Hilarious Posted November 25, 2008 Report Posted November 25, 2008 i made myself a bracket and mounted the cdi on the back of the gas tank. also, you can shorten your harness and plug your cdi directly into the stator. Quote
NYUK Posted November 25, 2008 Author Report Posted November 25, 2008 i made myself a bracket and mounted the cdi on the back of the gas tank.also, you can shorten your harness and plug your cdi directly into the stator. got a pic? Quote
baddsheee Posted November 25, 2008 Report Posted November 25, 2008 I just looked at it and it seems like it wouldn't interfere. I believe the toomey radiator is just longer but the bracket ends up mounting underneath the front part of the gas tank. I don't see it being an issue but might want to double check with the guy who made it or wait till I get time to try it. Quote
2001Stroker Posted November 26, 2008 Report Posted November 26, 2008 I asked the same thing, but the thread title probably threw you off. http://www.bansheehq.com/forums/index.php?...mp;#entry897665 Quote
BigRed350x Posted November 26, 2008 Report Posted November 26, 2008 i e mailed him. i wonder if it will work with a toomey radiator. and will it interfere with a nology coil, being so close. john, they say to keep your cdi away from nology coils. they cause interference. shoot loco a pm. he's done a custom harness and re-located his stuff up front. I'd say down by the cross-member that goes between the shock towers would be a safe bet. Quote
NYUK Posted November 26, 2008 Author Report Posted November 26, 2008 fuck. i already ordered the bracket from gb. i made a bracket for behind the gas tank, but the cdi won`t mount clean, looks kinda sloppy. i will move the coil there and put the cdi on the gb bracket. my frames already pc`ed so welding the stock cdi mount up front is out.i got all winter to get it right. but i am so close now i am chomping at the bit to smell some castor oil and c12. Quote
shanYE west Posted November 26, 2008 Report Posted November 26, 2008 I used a key relocating bracket to move the CDI up front under the nose piece of the plastic. It was very clean looking.. no one even knew it was there.. I'm sure you could cut a piece of aluminum plate and it would be the same. Quote
rubberneck Posted November 26, 2008 Report Posted November 26, 2008 I used a key relocating bracket to move the CDI up front under the nose piece of the plastic. It was very clean looking.. no one even knew it was there.. I'm sure you could cut a piece of aluminum plate and it would be the same. I mounted my CDI and voltage regulator in the same position as fouledout 421. I welded a bracket to the frame before finishing, but you could do just like he did. It comes out clean, and you cant tell its there unless you look from underneath. really cleans things up. Quote
2001Stroker Posted November 26, 2008 Report Posted November 26, 2008 If you click on that first link I put up, scroll down to the photo RIPPEN put up. theshee made that for him. It bolts to the front gas tank mounts, and the front fender mounts. Looks real clean. Quote
