Rebuild that top end
check the valve seat, if your going to put new piston and rings in you should do a valve job to
thanks for replying and do you know how much a nice set of rings and a piston would cost and should i replace the valves why im doing the piston work and how much do some good valves cost?
As far as cost goes ??? and in my opinion replacing the valves depends on age of motor and condition i would think doing new top end would be first
well my motor is a 87 but we run 10w 40 in it i run a ngk plug to but i think the motor just needs a rebild and could i do a piston and ring rebild by my self i work on old cars but is it a difficult job?
i have a brand new piston and rings for a warrior... i no longer own a warror and this is setting on my shelf. $20 plus shipping and its yours.. hit me up on pm if you want it. i believe its a wiseco but i am not sure ill have to go look.
later aaron
later aaron
ya man im intrested but is it the same piston size as the stock piston because my motor isnt bord or anything its all stock so ya ill get that piston and rings of your hangs but do you have an email or phone number?
email me at [email protected]
its an la sleeve piston thats .020 over or 83.50mm.. so you will need to get your cyl bored and honed which is prob a good isea anyway it shouldnt be much more than $50 from a machine shop. i just realized it was $105 bucks when i bought it cause its on the box lol..
anyway hit me up on pm or at the email above.
later aaron
