acfine Posted October 10, 2008 Report Posted October 10, 2008 (edited) My 2002 'shee idles up REAL high when i first start it. It started happening after I did the Coolhead and reeds install. After about 10-15 seconds, it comes back down. Any thoughts are much appreciated. My mods so far are in my signature if that helps... Thanks peeps, Anthony Edited October 10, 2008 by acfine Quote
mopar1rules Posted October 11, 2008 Report Posted October 11, 2008 sounds kinda like an air leak or something. usually when cold if you have an airleak, it will want to idle low, cause its too lean for the cold engine. mine wouldn't hold a steady idle and would need all kinds of choke to stay going. i would try 27.5 pilots and check for air leaks. and check to see if the choke is on a little bit or something. now that i think of it, i remember mine idling higher, when the choke was on a little. Quote
Hypo Posted October 11, 2008 Report Posted October 11, 2008 My 2002 'shee idles up REAL high when i first start it. It started happening after I did the Coolhead and reeds install. After about 10-15 seconds, it comes back down. Any thoughts are much appreciated. My mods so far are in my signature if that helps... Thanks peeps, Anthony It sounds like you have the slides swapped from left to right. They fit but only backwards make sure the cutouts are facing towards the back of the bike, or the vac. choke tube between the carbs is not hooked up. If you did anything with the needles make sure the vent holes in the slides aren't blocked by the needle keeper. Quote
Paddleboy Posted October 11, 2008 Report Posted October 11, 2008 if its only 10 to 15 seconds i wouldnt even worry about it. could be just extra gas from the choke or from pumping the throdle.. either way its no big deal Quote
mopar1rules Posted October 11, 2008 Report Posted October 11, 2008 oops, i had a brain fart. i thought he said 10-15 minutes before it comes down. i don't know how i comprehended that tho. its been one of those days:) Quote
acfine Posted October 16, 2008 Author Report Posted October 16, 2008 It sounds like you have the slides swapped from left to right. They fit but only backwards make sure the cutouts are facing towards the back of the bike, or the vac. choke tube between the carbs is not hooked up. If you did anything with the needles make sure the vent holes in the slides aren't blocked by the needle keeper. Wouldn't you have to force the slides in if they were backwards, due to them having a "key" to align them, making sure they're not in backwards? From my experience, if the vac. choke tube between the carbs isn't hooked up, it won't run worth a dang. Mine's just hard to keep idling once warm, and idles real high at startup. Other than that, it runs like a bat outta hell once I get a bit into the throttle. I never even have to use the choke to start it either, and it doesn't appear to be stuck open any... Quote
mopar1rules Posted October 17, 2008 Report Posted October 17, 2008 then the bottom end/choke circuit is rich. that's why you don't need to choke it to start. the reeds must have richened your bottom end up a tad. try turning the air screws out some and see what happens. what are your pilots at? did it do any of this even a little bit, before the addition of reeds and coolhead? Quote
Tim Potteiger Posted October 17, 2008 Report Posted October 17, 2008 Wouldn't you have to force the slides in if they were backwards, due to them having a "key" to align them, making sure they're not in backwards? You can definitely install them backwards, I did it once long long ago, runs like shit trying to start and idle, but by the sound of the issue you are describing, the slides aren't backwards. Quote
acfine Posted October 17, 2008 Author Report Posted October 17, 2008 then the bottom end/choke circuit is rich. that's why you don't need to choke it to start. the reeds must have richened your bottom end up a tad. try turning the air screws out some and see what happens. what are your pilots at? did it do any of this even a little bit, before the addition of reeds and coolhead? I'm about 2.5 turns out on the air screws. And no, it did not do this at all before the head and reeds install... My pilot jets are still 25's. I ordered 27.5 thinking that may help, but haven't installed them yet. I have also added a new throttle cable, maybe that's not as "free" moving as it should be??? Thanks, Anthony Quote
