Hows it going? Ive been Toomey racing's tech for the past eight years. So I've installed a ton of TORS eliminators. You need to unplug the whole TORS system incl. two conectors going to the carb caps, TORS command unit located left side under the tank (small black box with one connecter) also unplug the throttle switch follow the wire from the throttle to the plug allong the steering stem behind the rad. (DO NOT SPLICE ANY WIRES TOGETHER) try that first then move on to the carbs, vac. choke tube, slides. As for the fuel leak the needle and seats dont last long.
