sa3ood_banshee Posted September 29, 2008 Report Share Posted September 29, 2008 (edited) look wat i just picked up but i dnt no how to wire it,and what are those transparent plastic things,were 2 they go.and i dnt think they go on tha golden pieces,bcuz they might melt and tha black insulators(long ones) wont go on tha gold metal pieces if i put tha plastics on.. plz help EDIT:btw they are 50W,im replacing them with tha stock,will tha stator handle it?? sa3ood Edited September 29, 2008 by sa3ood_banshee Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted September 29, 2008 Author Report Share Posted September 29, 2008 here is a link to tha manual,and wat is one spot one flood?? and tha manual says that i have 2 connect one wire from tha light 2 tha low beam or high beam,and tha other to tha ground,and tha i have to insulate tha third wire from tha harness,cuz its not in use sa3ood Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted September 29, 2008 Report Share Posted September 29, 2008 Whatever you do please stop saying "tha", lol just j/k'n man. The transparent plastic pieces seal the metal connectors where you connect to the wire harness. There should be one wire for high and one wire for low and of course one wire for ground. Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted September 29, 2008 Author Report Share Posted September 29, 2008 (edited) Whatever you do please stop saying "tha", lol just j/k'n man. The transparent plastic pieces seal the metal connectors where you connect to the wire harness. There should be one wire for high and one wire for low and of course one wire for ground. but if i put "tha" :thumbsup: transparent plastics on tha metal connectors,tha shrinking tube wont go on,and wat metal piece should be connected to the harness(male, or female),thnx man but there are only 2 wires comming from tha trail tech light,and tha herness has 3. 1 low,1 high,1 ground Edited September 29, 2008 by sa3ood_banshee Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted September 29, 2008 Report Share Posted September 29, 2008 I would put the female terminals on the harness, but you could do anyway you want I guess. You think you could possibly install the transparent connector cover, slightly heat it to form around the connector and then install the wire tubing? Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted September 30, 2008 Author Report Share Posted September 30, 2008 bump*** Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted September 30, 2008 Author Report Share Posted September 30, 2008 comon guyz,almost half of u guyz have them,and i need help asap,i have a trip to go to tomorw and stock lights blow sa3ood Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted September 30, 2008 Author Report Share Posted September 30, 2008 buuuuummmmppppppp Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted September 30, 2008 Report Share Posted September 30, 2008 stock stator may not fully illuminate a 50w light, you should be running 35w lights with it. Wiring is super hard, one wire to the headlight ground, and one wire to the high or low beam. Quote Link to comment Share on other sites More sharing options...
sa3ood_banshee Posted September 30, 2008 Author Report Share Posted September 30, 2008 (edited) stock stator may not fully illuminate a 50w light, you should be running 35w lights with it. Wiring is super hard, one wire to the headlight ground, and one wire to the high or low beam. ahaa,wat i say is that can i put tha metal pieces on then on tha metal put tha shrinking tube,without tha transparent plastic,will it be ok,cuz i dnt no were tha plastic goes,tha prob is that now i have opend tha lights,ive opend each and every packet inside,so tha shop wont take it bak.will it be k if i run it with tha stock stator,like will it overload Edited September 30, 2008 by sa3ood_banshee Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted September 30, 2008 Report Share Posted September 30, 2008 I kept the stock connectors and soldered the wires. Quote Link to comment Share on other sites More sharing options...
shee4speed Posted October 1, 2008 Report Share Posted October 1, 2008 the blackheat shrink is for splices in the middle of the wire.The clear covers are for the metal pieces once you connect the wires on them.I put the stock harness on my trailtechs. Quote Link to comment Share on other sites More sharing options...
