acfine Posted September 16, 2008 Report Posted September 16, 2008 Has anyone used these style of exhaust clamps? Do they work? Leak any? Thanks Quote
jbooker82 Posted September 17, 2008 Report Posted September 17, 2008 I run the RIS pipe clamps. They are based on that style. Mine have 3 orings that seal down on the silencer tube and 1 fat oring that seals down on the head pipe or expansion chamber. The end that has the fat oring is threaded so you can thread it down and really seal up the big oring. I havent had a single trace of oil show up. They do look better made than those. I am sure they cost more to. Mine were 65 bucks for the pair and I would buy them again in a heart beat. I run them on my CPI's. They make them for CPI, Toomey, and FMF. They are custome made for each brand or size of pipe. If you have a different exhaust than what they list give them a call with some measurements and they will help you find one that will work. josh http://www.risdesigns.com/index.php?option...0&catid=172 Quote
acfine Posted September 17, 2008 Author Report Posted September 17, 2008 Cool! Thanks for the info. Your setup looks clean as hell, thanks again Anthony Quote
boneyardbanshee. Posted September 17, 2008 Report Posted September 17, 2008 i have the ones you have pictured and they work very well. they screw in on both sides to expand the orings(one on each side). no leaks and the pipes havent blown apart. Quote
John Posted September 26, 2008 Report Posted September 26, 2008 i have the ones you have pictured and they work very well. they screw in on both sides to expand the orings(one on each side). no leaks and the pipes havent blown apart. I have a different style set that I bought from cascade... they worked out very well and have a nice bling to them. Jbooker nice setup, looks very clean. Quote
KaosBanshee44 Posted September 29, 2008 Report Posted September 29, 2008 Those RIS clamps look clean as hell! Definitly a great add on cause stock clamps aren't worth a piss Quote
