mercado111
Everything posted by mercado111
  1. I'm Parting out my Complete bike. Its a 4mm 68mm Cheetah Cub Fully Ported by K&T Performance. the bike has at the most 2hrs since i completed it. Going to start something new. This setup rips. Up for sale is CPI Big bore in-frames, WCR 2-5 dunable override, K&T lockup, K&T Cool head, vforce 3, upp 38mm intakes, 38mm keihin pwk carbs, 4mm hot rod T&W crank, works triple rate front shocks, tcs dual rate rear, 10inch swingarm, 10 paddle haulers, bike is still complete with tear apart tomorrow. if theres something you and not listed let me know. All prices are without shipping unless otherwise specified. Accept Paypal [email protected], located in Indio, CA 1987 J-arm Frame Powder coated gray $350.00 Ca title Cheetah Cubs w/pistons, domes and gasket $1100. Shipped CPI Big bore Pipes $400 2-5 Dunable Overide $400 K&T lockup and cover $250.00 K&T CoolHead w/stock cly domes $150.00 Vforce 3 $175.00 Shipped Upp Intakes $75.00 Shipped 38mm Keihins $275.00 Shipped 4mm Hot Rod +5 $320 Shipped Works Shocks $250.00 TCS Rear $175.00 10in Swing arm $150.00 Ported Cases not damage $200.00 Complete Clutch $150.00 Complete electrical & adv timing plate, no key or on/off $150.00 97& up. 10 paddle haulers $260.00 shipped j-arms, spindles, Ft hubs, tie rods. $175.00 complete rear brake ass. $125.00 Aluminum Gas Tank $120.00 Shipped Dual Pingel $55.00 Shipped Complete axle w/hubs, sproket, disc, stock carrier. $90.00 Seat $60.00 Shipped Stem $15.00 Thumb Throttle 25.00
  2. sorry, i'm not going to part it out yet.
  3. 1987 Banshee with a 421 Cub Motor ported by K&T. Has Cpi big bore inframes, Dunable 2-5 override from WCR, K&T lockup clutch and coolhead, 38mm pwks, Vforce 3, upp intakes, Works triple rate front, TCS dual rate rear, 10in swingarm and 10 paddle haulers, Motor runs awesome has 2hr on it. Want to start new project. Have title in hand, $5700 Located in Indio, Ca
  4. do you have a clutch basket? i need the basket, spacer and thrust washer. if so how much shipped to 92201
  5. I have a 10mm cheetah avalible in the for sale section.
  6. For sale is my 1995 banshee, with the following mods. 535 cheetah motor 10mm stroker crank Ported by A&S Sheare out of frame drag pipes(bare) V-Force 3 Direct Drive Lock-up clutch K&T 2-5 overirde trans. 38mm Carbs(gas) K&T upgrade coil Front Marvin Shaw Coil over shocks Rear Comp. Marvin shaw Shock +14 Metal tech Swing Arm (honda style carrier) Aluminium oversized radiator K&T Aluminium gas tank with dual pingel Skat trak 12 paddle buffed rear tires Front buffed tires have extra set of 39mm carbs and fuel pump that can be converted to Alky $9500 PM me with any questions or more pictures Located in so. cal
  7. i'm interested in the frame if you have a title. how much is shipping to 92201
  8. Staples What is going on with the frame? I paid you the $270 and have no frame or have not heard from you. I have tryied other routes such as email and PM's and I have gotten no response. I did not want to air this out on the froum, but I chose to as I hope no other members would get screwed out of there hard earned cash. I have taken action with Pay-Pal and will involve authorities if I am not refunded in full or have a frame in my position. If the frame has been sent, very doughtful as you have not sent a tracking number or responded to any of my email or PM's, I am very sorry.
  9. i'll you give 270.00 for the frame and all the bolts shipped to zip 92201. [email protected]
  10. I have a set of CPI bigi bore pipes and a set of 35.5 Mikuni carbs with K&N set up for alky for auction. carbs pipes
  11. I have a set of CPI big Bore out of frame drag pipes and a set of Mikuni 35.5 alky carbs set up by K&T for acution on ebay. Here are the links. carbs cpi
  12. What size stroker do you plan on running 4mm, 7mm or 10mm? Also what kind of riding do you do drag, dune, or trail. These are just a couple of thing to think about before you get stated. Last but no least how much money do you have to spend? Alittle more info and I think you will get more replys.
  13. I also use Type F in my 10mm cheetah and 4mm. Work great.
  14. Try ESR's web site they have a 310 kit that runs pretty well and they also sell CR ignitions.
  15. I have 3's on my cheetah. So far I have not had any issues.
  16. Is the CDI for sale. If so how much?
  17. Is the CDI for sale? If so how much?
  18. How much for the wire harness? Has the harness been cut or is it complete(uncut)?
  19. I should be there on Sunday.
