mercado111
Everything posted by mercado111
  1. here you go, 4mm hot rods +5 rods
  2. For sale is a 95 Drag Banshee with the follwoing Mods. 535 cheetah ported by A&S 10 mil stroker with TZ bearing(crankworks) V-Force 3 Direct Drive lock-up Clutch system 2-5 Overide cut by K&T 38mm Air strikers (gas) Shearer out of Frame Drap pipes K&T after market Coil Metal Tech +14 chromoly swing arm( honda style carries) 12 Paddle buffed haulers Front smoth buffs on Douglas rims cut by direct drive Front Marvin Shaw Coil overs Rear marvin Shaw Comp K&T Aluminum Fuel tank with Dual Pingal Oversized Aluminum Radiator Chorme: A-arms(stock), swing arm, spindles, stering stem. Frame and hubs poweder coated candy Red extra set of 39mm carbs with Fuel pump (can be convertered to Alky) $8000.00
  3. yes it's still for sale.
  4. yes as soon as it clears i will send your swingarm out. i plan on spliting the cases tomorrow and i will get you pics of the crank then. thanks again
  5. there not buffed, make an offer on the parts
  6. Just the crank, has at the most 2hrs, how about 310.00 shipped
  7. yes it's for a stock carrier, it's the dust caps,collar and bearing were the swingarm bolt attach.
  8. yes i'll through in the chain for an extro 50 i'll through in i steel braided brake line and the pivot works swing arm kit. my paypal is [email protected]
  9. 22x11x8, 10paddle, 69RO and yes they come with rims
  10. works triple rate no rezzies, setup for 180-200 lbs stock length arms, paint has some chips will come shock wears. will post pics tomorrow.
  11. The Guy i got it from had it setup for a stock length swingarm. it work fine for me. its in good shape and i'll get you pics tomorrow.
