MULLET~BOY
Everything posted by MULLET~BOY
  1. tyson racing makes some good frames
  2. chill out bro i was just messing around i don't care about posts i had just never heard of it and was wondering what it was
  3. i think tithead uses kph
  4. hey i have a hot rods lr crank its got about 25 hours on it was just trued and welded and had new bearings installed on it how much do you think i could sell it for
  5. shit you guys pay alot for powder coat nyuk i noticed you guys pay alot more back east for chrome for some reasion like reas11 told me 80 bucks for foot pegs where out here i get minedone for about 25 bucks
  6. i duno what it is but it sounds like a snack or somthing
  7. i payed 125 bucks for lulipop red over silver vain came out so good i was quated 250 bucks for a chrome frame
  8. kev you brought up a good point sure my tusk clutch will probably last abotu half as long as your exspinsive clutch but hell 29 bucks you can beat that and i can aford to replace it i was running a half worn out clutch in my ported banshee had no problems even its all about the springs i think
  9. the boost bottle won't really make a noticable gain probly not gain you any boost bottles do work but you have to get it specialy made for the motor i am told
  10. give it time and it will sell i would just race the xc the way your bike is set up for now till you sell it
  11. douse any one have a yz 250 reed cage couse i need one
  12. thats just a stock fram he just has rigid suspintion
  13. just sell it like you had planed and get the 250R
  14. that is some crazy shit
  15. what kinda riding is it gona be for and how much you looking to spend
  16. i already got one have had it in for about 4 good tripps of slipping the clutch and it still looks new
  17. this bill is for evry part in a intire 1987 honda trx 250 R look at the tottle price rember this quad costed liek i think what 3 grand new or somthing might have been less look at the bottom for the tottle price i use the alba parts finder 13355-HA2-000 GEAR (37T) $37.89 $37.89 13615-HA2-000 GEAR (23T) $48.67 $48.67 13617-HA2-000 COLLAR, DRIVE GEAR $29.00 $29.00 22100-HA2-000 CLUTCH OUTER $256.89 $256.89 22120-KAE-010 CENTER, CLUTCH $55.13 $55.13 22201-KAE-000 DISK, CL FRICTION $10.75 $75.25 22321-KF0-770 PLATE, CLUTCH $9.13 $54.78 06220-HB9-305 ROD, CLUTCH LIFTER $67.98 $67.98 22352-HB9-670 PIECE, CLUTCH LIFTER $19.67 $19.67 22401-HA2-670 SPRING, CLUTCH $2.56 $12.80 06220-HB9-305 ROD, CLUTCH LIFTER $67.98 $67.98 28242-HA2-010 COLLAR (23X30) $22.45 $22.45 90013-430-000 BOLT (10X25) $5.25 $5.25 90235-KA4-000 NUT (18MM) $6.42 $6.42 90421-HA2-010 WASHER (23X48) $6.36 $6.36 90445-KAE-000 WASHER, LOCK (18MM) $3.00 $3.00 90456-KA4-000 WASHER (18X32) $3.09 $3.09 90481-430-000 WASHER (10MM) $4.67 $4.67 90603-HB9-670 CLIP (7.5) $1.31 $1.31 91023-KG4-004 BEARING (28X33X13) $14.20 $28.40 93404-06020-08 BOLT-WASHER (6X20) $0.55 $2.75 96211-04000 BALL, STEEL (#4) $0.22 $0.66 11001-HA2-770 CRANKCASE ASSY., R. $349.31 $349.31 11002-HA2-771 CRANKCASE ASSY., L. $335.71 $335.71 11191-HA2-306 GASKET, CRANKCASE $9.67 $9.67 22810-HA2-670 LEVER, CLUTCH $36.04 $36.04 22815-HA2-670 SPRING, CLUTCH LEVER $2.36 $2.36 22861-HA2-670 CLAMP, CLUTCH CABLE $4.53 $4.53 23225-430-000 COLLAR (22MM) $16.35 $16.35 90015-KA3-711 BOLT, SPECIAL (12MM) $3.76 $3.76 90432-HA2-670 WASHER (10MM) $2.04 $2.04 90441-KA4-700 PLATE $2.09 $4.18 91001-KA4-741 BEARING (22X56X14) $13.95 $13.95 91002-HA2-003 NEEDLE (10X17X10) $10.02 $10.02 91009-HC0-003 BEARING (63/28) $19.22 $38.44 91004-GC4-731 BEARING (25X42X9) $15.31 $15.31 91006-HA2-008 BEARING (17X40X12-U) $15.95 $31.90 91012-KA3-710 PLATE $3.11 $6.22 91021-148-004 BEARING (1010) $12.03 $12.03 91022-KA4-740 BEARING (33X38X8) $10.91 $10.91 91201-KA4-004 OIL SEAL (38X58X11) $11.29 $11.29 91201-430-003 O-RING (22X1.5) $1.69 $1.69 91202-KA3-711 OIL SEAL (10X17X4) $3.56 $3.56 91202-HA2-771 OIL SEAL (28X50X8) $8.40 $8.40 91202-444-023 OIL SEAL (14X24X6) $3.07 $3.07 91207-ML3-003 OIL SEAL (28X40X8) $7.82 $7.82 92900-10045-3B BOLT 2, STUD (10X45) $1.29 $5.16 93600-06012-0A SCREW, FLAT (6X12) $0.40 $0.80 94109-12000 WASHER (12MM) $0.45 $0.45 94301-10160 DOWEL PIN (10X16) $1.05 $2.10 95002-50000 CLIP, TUBE (C9) $0.42 $0.84 95003-14003-10M BULK V HOSE (6.0) $11.90 $11.90 96001-06014-00 BOLT, FLANGE (6X14) $0.70 $1.40 96001-06016-00 BOLT, FLANGE (6X16) $0.62 $0.62 96001-06045-00 BOLT, FLANGE (6X45) $1.03 $4.12 96001-06050-00 BOLT, FLANGE (6X50) $1.05 $3.15 96001-06070-00 BOLT, FLANGE (6X70) $1.24 $2.48 96100-62050-10 BEARING (6205) $12.12 $12.12 11351-HA2-000 COVER, L. CRANKCASE $75.13 $75.13 11352-HA2-306 GASKET, L. COVER $8.85 $8.85 23810-HB9-000 CVR, DRIVE SPROCKET $21.44 $21.44 23812-HA2-000 GUIDE, DRIVE CHAIN $14.22 $14.22 31100-HB9-004 ALTERNATOR ASSY. $344.64 $344.64 31110-HB9-004 FLYWHEEL $329.13 $329.13 31120-HA2-671 STATOR $257.04 $257.04 90437-611-000 WASHER, PLAIN (12MM) $2.66 $29.26 93301-05012-0A BOLT, HEX. (5X12) $0.29 $0.58 94050-12000 NUT, FLANGE (12MM) $0.76 $0.76 96001-06016-00 BOLT, FLANGE (6X16) $0.62 $2.48 96001-06045-00 BOLT, FLANGE (6X45) $1.03 $6.18 96001-06100-00 BOLT, FLANGE (6X100) $1.24 $1.24 11340-HA2-670 COVER, R. CRANKCASE $149.55 $149.55 11395-HA2-P00 GASKET, R. $13.07 $13.07 15611-381-000 CAP, OIL FILLER $10.05 $10.05 19501-HA2-000 HOSE, WATER $8.35 $8.35 19506-KA4-000 CLAMP, WATER HOSE $7.20 $14.40 90037-360-000 BOLT, OIL CHECK $1.58 $1.58 90543-273-000 GASKET, FR. $1.29 $1.29 91204-KF0-003 OIL SEAL (20X28X5) $4.15 $4.15 91304-MJ0-003 O-RING (15.8X2.4) $1.38 $1.38 94301-08140 DOWEL PIN (8X14) $0.88 $1.76 96001-06032-00 BOLT, FLANGE (6X32) $0.90 $8.10 96001-06040-00 BOLT, FLANGE (6X40) $0.90 $1.80 11361-HA2-000 HOLDER $36.87 $36.87 13011-HA2-003 RING SET (STD) $36.44 $36.44 13101-HA2-772 PISTON A (STD) $93.36 $93.36 13111-HA2-770 PIN, PISTON $15.42 $15.42 13300-HB9-770 CRANKSHAFT $354.64 $354.64 13331-360-000 KEY (25X1) $2.18 $2.18 13350-HA2-000 WEIGHT, BALANCER $196.84 $196.84 13353-HA2-000 PLATE $5.15 $5.15 90011-PF0-000 BOLT, FLANGE (6X108) $5.48 $5.48 90016-HA2-670 BOLT, FLANGE (6X100) $2.87 $2.87 90601-430-000 CLIP (1.2X18) $1.93 $3.86 91005-HA2-000 BEARING (17X40X12) $13.35 $13.35 91015-357-003 BEARING 2 $15.82 $15.82 91308-500-010 O-RING (13.8X2.4) $5.47 $5.47 95701-06025-07 BOLT, FLANGE (6X25) $0.76 $0.76 96001-06016-00 BOLT, FLANGE (6X16) $0.62 $1.24 12100-HA2-770 CYLINDER A $369.05 $369.05 12191-HA2-306 GASKET, CYLINDER $6.89 $6.89 12200-HA2-770 CYLINDER HEAD $189.95 $189.95 12254-HB9-013 GASKET, CYL HD $26.69 $26.69 14100-HA2-771 VALVE ASSY., REED $162.20 $162.20 14132-KAE-000 GASKET A, REED VALVE $2.27 $2.27 16210-HA2-770 INSULATOR $30.42 $30.42 18291-430-306 GASKET, EX. PIPE $2.82 $2.82 18351-HA2-000 JOINT, EX. PIPE $68.45 $68.45 32111-HA2-000 CLAMP, WIRE $2.69 $2.69 90011-HA2-000 BOLT, SPECIAL STUD $4.13 $24.78 90037-360-000 BOLT, OIL CHECK $1.58 $1.58 90443-107-000 NUT, CAP (8MM) $2.09 $12.54 90543-273-000 GASKET, FR. $1.29 $1.29 94050-10000 NUT, FLANGE (10MM) $0.78 $3.12 94301-12200 DOWEL PIN (12X20) $1.05 $2.10 95701-06022-00 BOLT, FLANGE (6X22) $0.67 $4.02 96001-06018-00 BOLT, FLANGE (6X18) $0.70 $2.10 98079-58846 SPARK PLUG (BR8ES) $2.11 $2.11 061A0-HA2-T71 GASKET KIT $46.94 $46.94 24211-HA2-000 FORK, R. GEARSHIFT $51.55 $51.55 24221-HA2-000 FORK, L. GEARSHIFT $51.55 $51.55 24231-HA2-000 FORK $41.31 $41.31 24265-HA2-000 SHAFT $11.62 $11.62 24266-HA2-000 SHAFT $20.64 $20.64 24311-HA2-000 DRUM, GEARSHIFT $69.13 $69.13 24312-HB9-000 CENTER $33.89 $33.89 24315-KA3-710 PIN, SHIFTER $12.11 $12.11 24320-KA3-740 SHIFTER, DRUM $36.73 $36.73 24322-HA0-000 COLLAR, SHIFTER $3.18 $3.18 24324-KA3-740 PAWL, RATCHET $7.58 $15.16 24326-360-010 PLUNGER, PAWL $3.00 $6.00 24328-HA2-000 PLATE, GUIDE $8.58 $8.58 24329-KA3-740 SPRING, PAWL PLUNGER $1.69 $3.38 24430-HA2-000 STOPPER, DRUM $10.27 $10.27 24435-HB9-000 SPRING, DRUM STOPPER $2.89 $2.89 24610-HA2-000 SPINDLE, GEARSHIFT $64.24 $64.24 24651-KA4-740 SPRING $4.81 $4.81 90023-041-010 BOLT $1.20 $1.20 90417-360-000 WASHER, DRUM STOPPER $1.27 $1.27 90428-958-000 WASHER B (14MM) $3.15 $3.15 94510-14000 CIRCLIP (14MM) $0.48 $0.48 96001-06016-00 BOLT, FLANGE (6X16) $0.62 $1.86 96220-40080 ROLLER (4X8) $0.31 $0.31 28211-HA2-670 PINION (44T) $142.44 $142.44 28215-HA2-000 PLATE, KICK STOPPER $5.15 $5.15 28221-HA2-670 RATCHET $30.40 $30.40 28223-HA2-013 SPRING $2.33 $2.33 28224-HA2-010 WASHER $3.15 $3.15 28251-HA2-000 SPINDLE $78.75 $78.75 28261-HA2-000 SPRING, KICK RETURN $7.95 $7.95 28282-HA2-000 COLLAR, KICK SPRING $3.87 $3.87 28283-HA2-010 COLLAR (20X27) $6.51 $6.51 90401-HA2-000 WASHER (20MM) $3.84 $3.84 93301-06016-0A BOLT, HEX. (6X16) $0.52 $1.04 94510-19000 CIRCLIP (19MM) $0.55 $0.55 23211-HB9-770 MAINSHAFT (14T) $116.80 $116.80 23221-HB9-770 COUNTERSHAFT $103.53 $103.53 23411-HA2-000 GEAR (36T) $91.09 $91.09 23412-HA2-000 COLLAR $10.62 $10.62 23421-HA2-000 GEAR (16T) $36.84 $36.84 23431-HA2-010 GEAR (33T) $89.53 $89.53 23432-HA2-000 COLLAR $13.85 $13.85 23441-HA2-000 GEAR (18T & 21T) $94.16 $94.16 23451-HA2-000 GEAR (30T) $80.73 $80.73 23471-HA2-670 GEAR (28T) $57.45 $57.45 23481-HB9-670 GEAR (23T) $51.96 $51.96 23482-HA2-000 COLLAR $13.44 $26.88 23491-HB9-670 GEAR (25T) $75.09 $75.09 23501-HB9-305 GEAR (25T) $48.04 $48.04 23511-HB9-670 GEAR (23T) $72.40 $72.40 23803-HA2-000 SPROCKET (13T) $23.52 $23.52 90103-426-000 BOLT, FLANGE (8X20) $2.47 $2.47 90431-HA2-000 WASHER (25.2X30) $3.84 $3.84 90446-KA5-680 WASHER (24.2X34) $3.58 $3.58 90454-KF0-000 WASHER (17MM) $2.84 $5.68 90461-286-000 WASHER B (25MM) $2.09 $4.18 90462-323-000 WASHER, LOCK (25MM) $2.18 $4.36 90463-430-000 WASHER (25MM) $3.45 $10.35 90501-HB9-003 WASHER (8X40) $2.60 $2.60 90455-ML7-000 WASHER B (22MM) $3.15 $3.15 90554-KA5-680 WASHER (19MM) $2.84 $2.84 90602-259-010 CIRCLIP (25MM) $3.87 $11.61 19215-KA3-710 IMPELLER, WATER PUMP $35.07 $35.07 19217-657-023 SEAL, MECHANICAL $32.15 $32.15 19221-HA2-670 COVER, WATER PUMP $64.36 $64.36 19222-HA2-000 SEPARATOR $5.07 $5.07 19229-HA2-306 GASKET $2.18 $4.36 19241-HA2-000 SHAFT, WATER PUMP $34.82 $34.82 90037-360-000 BOLT, OIL CHECK $1.58 $1.58 90201-415-000 NUT, CAP (6MM) $1.58 $1.58 90441-706-000 WASHER (6MM) $0.80 $0.80 90454-KA4-000 WASHER (8X13) $1.80 $1.80 90543-273-000 GASKET, FR. $1.29 $1.29 91001-KA4-003 BEARING (12X28X7) $13.95 $13.95 91201-965-000 OIL SEAL (12X22X5) $3.29 $3.29 94301-08140 DOWEL PIN (8X14) $0.88 $1.76 96001-06025-00 BOLT, FLANGE (6X25) $0.83 $1.66 96001-06032-00 BOLT, FLANGE (6X32) $0.90 $1.80 15772-GB5-670 CLIP, DRAIN TUBE $2.00 $2.00 16235-657-000 JOINT, FUEL $7.42 $7.42 17116-HB9-000 TUBE $3.50 $3.50 17210-HB9-770 HOUSING, AIR CLEANER $110.55 $110.55 17212-HB9-770 BASE, ELEMENT $12.98 $12.98 17213-HB9-770 ELEMENT, AIR CLEANER $44.16 $44.16 17217-HB9-770 LID, A/CLNR HSG $31.82 $31.82 17219-HA2-405 SEAL $4.85 $4.85 17223-HB3-003 SPRING, A/CLNR LD ST $4.96 $19.84 17224-HM5-930 TUBE $1.29 $1.29 17225-HB9-670 PIPE $67.64 $67.64 17226-HB9-000 PIPE B $35.45 $35.45 17227-HB9-000 RUBBER, SEAL (INNER) $4.91 $4.91 17252-HB9-000 TUBE $13.91 $13.91 17253-HB9-670 TUBE $42.93 $42.93 95018-42250 BAND (42) $5.52 $5.52 17256-HB9-000 BAND $8.16 $16.32 17257-HA0-000 BAND, IN. TUBE $6.49 $6.49 17255-MN1-670 BAND $3.71 $3.71 17410-HB9-670 RESONATOR $17.15 $17.15 19032-HB9-000 GROMMET $2.51 $5.02 90501-MJ6-000 COLLAR $2.84 $2.84 90106-HA0-680 SCREW, PAN (4X20) $1.17 $2.34 90107-HA0-680 SCREW, PAN (4X25) $1.40 $2.80 90111-187-000 BOLT, FLANGE (6MM) $3.62 $10.86 90522-170-700 COLLAR $1.42 $1.42 93500-04025-0G SCREW, PAN (4X25) $0.37 $0.37 94050-06000 NUT, FLANGE (6MM) $0.57 $0.57 95002-50000 CLIP, TUBE (C9) $0.42 $0.84 95003-14030-10S *95003-14001-10M $0.86 $0.86 96300-06020-00 BOLT, FLANGE (6X20) $0.65 $0.65 51350-HB9-670 ARM, R. FR. (LOWER) $284.62 $284.62 51355-HB9-671 JOINT, BALL (UPPER) $94.95 $189.90 51360-HB9-670 ARM, L. FR. (LOWER) $303.07 $303.07 51370-HB9-670 ARM, R. FR. (UPPER) $203.95 $203.95 51380-HB9-670 ARM, L. FR. (UPPER) $192.25 $192.25 51393-HB9-670 RING, STOPPER $3.18 $50.88 51394-HB9-670 COLR, FR. ARM PIVOT $8.15 $130.40 51399-HB9-670 COLLAR $3.87 $15.48 90150-MK2-770 BOLT, FLANGE (10X72) $5.64 $45.12 90304-GE8-003 NUT, U (10MM) $2.96 $23.68 90305-GE8-003 NUT, U (14MM) $3.76 $7.52 90310-HB9-000 NUT, CASTLE (12MM) $3.84 $15.36 91077-HB9-672 BEARING (10MM) $23.44 $187.52 91265-HB9-671 DUST SEAL, FR. $2.51 $40.16 94201-30450 PIN, COTTER (3.0X45) $0.37 $1.48 43352-568-003 SCREW, BLEEDER $4.35 $8.70 43353-461-771 CAP, BLEEDER $3.22 $6.44 45100-HB9-007 CALIPER, L. FR. $242.18 $242.18 45101-HB9-006 CALIPER, L. FR. $104.85 $104.85 45105-HA5-672 PAD A $18.38 $36.76 45107-MG3-016 PISTON $22.91 $91.64 45108-MY1-006 SPRING, PAD $6.60 $6.60 45108-HB9-006 SPRING, PAD $8.35 $8.35 45109-GE2-006 DUST SEAL $3.42 $13.68 45110-HB9-006 BRACKET, L. FR. $53.00 $53.00 45112-HA5-671 RETAINER $3.96 $7.92 45131-HA5-672 BOLT A, BOLT $9.44 $18.88 45131-166-016 PIN, BOLT $4.84 $9.68 45132-166-016 BUSH, PIN $3.45 $6.90 45133-MA3-006 BOOT B $3.45 $6.90 45200-HB9-007 CALIPER, R. FR. $212.13 $212.13 45201-HB9-006 CALIPER, R. FR. $104.85 $104.85 45203-MG3-016 PLUG, PIN $3.25 $6.50 45209-GE2-006 SEAL, PISTON $4.36 $17.44 45210-HB9-006 BRACKET, R. FR. $56.24 $56.24 45215-HA5-672 PIN, HANGER $6.51 $13.02 96300-08025-08 BOLT, FLANGE (8X25) $1.07 $4.28 451A0-HB9-670 BRAKE PAD KIT $40.00 $80.00 43101-HA2-671 CALIPER, RR. $128.62 $128.62 43105-HB9-008 PAD, RR. $14.21 $28.42 43107-HA2-016 PISTON $25.05 $25.05 43108-HA2-016 PISTON $31.15 $31.15 43110-HB9-771 BRACKET, RR. $58.09 $58.09 43112-HA2-006 RETAINER $4.53 $4.53 43200-HB9-008 CALIPER ASSY., RR. $353.02 $353.02 43352-568-003 SCREW, BLEEDER $4.35 $4.35 43353-461-771 CAP, BLEEDER $3.22 $3.22 43360-HA2-671 BRAKE, PARKING $35.33 $35.33 43361-961-006 SHAFT, L. $10.31 $10.31 43362-HA2-006 ARM $7.78 $7.78 43363-HA2-006 GASKET $2.04 $2.04 45108-GE2-006 SPRING, PAD $3.40 $3.40 45109-GE2-006 DUST SEAL $3.42 $6.84 45111-MA3-006 SLEEVE $8.15 $8.15 45131-MG3-006 BOLT A, PIN $10.76 $10.76 45133-MA3-006 BOOT B $3.45 $3.45 45133-166-016 BOOT, PIN $2.44 $4.88 45203-MG3-016 PLUG, PIN $3.25 $6.50 45209-GE2-006 SEAL, PISTON $4.36 $8.72 45215-KA3-732 PIN, HANGER $7.05 $14.10 46184-611-000 BOOT SEAL $5.53 $5.53 90115-HA2-670 BOLT, FLANGE (8X16) $2.69 $5.38 90116-410-006 BOLT (8X25) $3.58 $7.16 90126-961-006 BOLT (8X40) $3.09 $3.09 90180-MA3-006 BOLT, FLANGE (8X49) $3.09 $3.09 91358-964-006 O-RING (7.8X1.9) $1.33 $1.33 96300-06022-00 BOLT, FLANGE (6X22) $0.91 $0.91 94071-08080 NUT-WASHER (8MM) $0.57 $0.57 431A0-HB9-008 BRAKE PAD KIT $31.66 $31.66 52460-HB9-670 ARM, SHOCK ABSORBER $219.42 $219.42 52467-HA2-000 COLLAR A $11.33 $11.33 52468-HB9-000 COLLAR A $11.33 $11.33 52470-HB9-000 ROD ASSY. $253.25 $253.25 52479-HB9-000 COLLAR B $11.33 $22.66 52486-964-000 COLLAR, RR. $18.25 $18.25 90121-HA2-000 BOLT, FLANGE (12X57) $8.07 $8.07 90125-HB9-000 BOLT (12X110) $27.58 $27.58 90128-964-003 BOLT, FLG (12X103) $12.91 $12.91 90306-KF0-003 NUT, FLANGE (12MM) $3.15 $9.45 91266-HB9-005 SEAL A $3.15 $6.30 91266-964-672 SEAL A $5.27 $21.08 91267-HB9-005 SEAL B $3.15 $12.60 96201-10000 FITTING (A.76) $1.22 $3.66 96201-60000 FITTING (C.76) $1.65 $1.65 18293-MN5-650 RUBBER, PROTECTOR $2.76 $16.56 18300-HB9-770 MUFFLER, MAIN $330.55 $330.55 18310-HB9-670 MUFFLER, SUB $329.00 $329.00 18311-HA2-770 PIPE, TAIL $33.89 $33.89 18319-HB9-003 PROTECTOR, MUFFLER $65.16 $65.16 18332-430-700 SPRING, EX. PIPE $7.25 $14.50 18352-HA2-010 GASKET, EX. PIPE $4.33 $4.33 18358-HA2-000 RING, EX. $8.15 $8.15 18359-961-000 STAY ASSY., MUFFLER $34.65 $69.30 18359-964-000 STAY, EX. MUFFLER $34.65 $34.65 18361-HA2-000 SEAL, MUFFLER $10.36 $10.36 18362-KA4-700 BAND, MUFFLER SEAL $4.11 $8.22 18373-429-010 LID, MUFFLER $5.58 $5.58 18374-MN1-880 GASKET, MUFFLER LID $2.65 $2.65 96001-06008-00 BOLT, FLANGE (6X8) $0.62 $1.86 93401-06012-07 BOLT-WASHER (6X12) $0.60 $1.20 93893-06012-07 SCREW-WASHER (6X12) $0.52 $1.04 96300-06012-00 BOLT, FLANGE (6X12) $0.62 $1.24 96300-08012-00 BOLT, FLANGE (8X12) $1.52 $3.04 96300-08028-00 BOLT, FLANGE (8X28) $1.05 $3.15 19034-HB9-000 GROMMET, FR. $3.04 $18.24 53133-KB4-000 GROMMET $1.33 $2.66 61100-HB9-305 FDR, R. FR. *NH138* $215.68 $215.68 61101-HB9-670 STAY, R. FR. $16.16 $16.16 61102-HB9-670 STAY, L. FR. $12.98 $12.98 61111-HB9-000 STAY, R. $10.11 $10.11 61112-HB9-000 STAY, L. $10.11 $10.11 61142-001-010 METAL, FR. (LOWER) $1.73 $3.46 61200-HB9-305ZB FDR, L. FR. *NH138* $196.11 $196.11 61400-HB9-000ZA COVER, FR. *NH1* $112.73 $112.73 61502-HB9-000 BAND, SIDE COVER $8.15 $8.15 61700-HB9-000ZA COVER, FR. *PB165* $84.33 $84.33 61700-HB9-000ZB COVER, FR. *R109* $84.33 $84.33 87504-HB9-670 LABEL, USE CAUTION $5.78 $5.78 90111-187-000 BOLT, FLANGE (6MM) $3.62 $7.24 90320-HB9-000 NUT, SPRING (5MM) $1.82 $18.20 33712-GC2-000 COLLAR A, TAILLIGHT $1.95 $19.50 93500-05014-0A SCREW, PAN (5X14) $0.37 $3.70 94050-08000 NUT, FLANGE (8MM) $0.57 $1.14 96300-08016-00 BOLT, FLANGE (8X16) $0.91 $3.64 17611-HA5-000 RUBBER, FR. $3.35 $6.70 50223-HB9-670 PLATE, SEAT LOCK $8.52 $8.52 50815-HA2-670 RUBBER, RR. $9.69 $19.38 77100-HB9-405 SEAT COMP. *R82L* $278.22 $278.22 77207-HB9-000 RUBBER, SEAT SETTING $4.53 $9.06 77215-GC2-000 RUBBER B $3.22 $6.44 80100-HB9-405 FENDER, RR. *NH138* $286.70 $286.70 80101-HB9-670 CATCH, RR. FENDER $37.25 $37.25 80102-HB9-670 PLATE, SEAT LOCK $38.30 $38.30 80116-HB9-000 STAY, FENDER SUPPORT $25.84 $25.84 87505-HB9-670 MARK, TIRE CAUTION $4.85 $4.85 87518-HB2-770 LABEL $2.02 $2.02 94050-06000 NUT, FLANGE (6MM) $0.57 $4.56 96300-06010-00 BOLT, FLANGE (6X10) $0.62 $1.24 50100-HB9-670ZA FRAME *R109* $1,280.90 $1,280.90 50121-HB9-000 PIPE, ENGINE SETTING $42.05 $42.05 50221-HA2-000 LEVER, SEAT LOCK $7.20 $7.20 50222-HA2-000 SPRING $2.02 $2.02 50363-HA0-000 RUBBER B, STOPPER $2.98 $5.96 50354-HA2-670 BRACKET, RR. ENG HGR $54.69 $54.69 50356-HB9-770 PLATE, R. FR. $17.15 $17.15 50357-HB9-770 PLATE, L. FR. $17.15 $17.15 50360-HB9-000 GUARD, ENGINE $76.90 $76.90 81150-HB9-670 PIPE, FR. CARRY $98.79 $98.79 81155-HB9-000 RUBBER, FR. $3.78 $11.34 81160-HB9-670 PLATE, FR. SKID $83.47 $83.47 87506-HB9-000 LABEL $4.18 $4.18 87507-ME9-670 LABEL, RESERVE TANK $2.27 $2.27 87508-HB9-000 LABEL $2.40 $2.40 95801-10110-08 BOLT, FLG (10X110) $3.96 $7.92 90140-SA5-000 BOLT, MUDGUARD $3.70 $3.70 90152-964-000 BOLT (10X135) $8.07 $8.07 93494-08016-00 BOLT-WASHER (8X16) $0.82 $3.28 94050-08000 NUT, FLANGE (8MM) $0.57 $2.28 94050-10000 NUT, FLANGE (10MM) $0.78 $3.90 32161-404-000 BAND B1, CABLE $1.75 $1.75 95014-62100 BAND B1, CABLE $1.13 $2.26 96300-08012-00 BOLT, FLANGE (8X12) $1.52 $12.16 96300-08016-00 BOLT, FLANGE (8X16) $0.91 $5.46 96300-08045-00 BOLT, FLANGE (8X45) $1.24 $2.48 96400-10050-00 BOLT, FLANGE (10X50) $1.24 $1.24 96400-10140-00 BOLT, FLG (10X140) $2.62 $2.62 16900-HB9-000 FILTER ASSY., FUEL $35.33 $35.33 16950-HB9-005 PETCOCK ASSY. $47.71 $47.71 16952-HB9-005 SCREEN $6.49 $6.49 16953-HB9-005 LEVER, VALVE $8.58 $8.58 16954-HB9-005 PLATE $5.27 $5.27 16955-HA2-005 GASKET, PETCOCK $6.51 $6.51 16955-HB9-000 CLIP, FUEL TUBE $10.11 $10.11 16958-HA2-005 WASHER, PLAIN $3.15 $3.15 16963-HB9-005 X-RING $3.18 $3.18 16964-467-005 SPRING $3.25 $3.25 16997-467-000 O-RING (11.8X3.55) $1.64 $1.64 17505-HB9-000 RUBBER, R. FR. $6.51 $13.02 17506-HB9-000 RUBBER, L. FR. $6.51 $13.02 17510-HB9-670ZB TANK, FUEL *R109* $288.53 $288.53 17525-HB9-670 STAY, FR. $25.82 $25.82 17512-HB9-000 RUBBER, FR. TANK $5.93 $5.93 17513-HB9-670 STAY, RR. TANK $11.31 $22.62 17514-HB9-000 RUBBER, RR. TANK $2.98 $11.92 17518-HB9-000 RUBBER, FR. $2.45 $4.90 17519-HB9-000ZA RUBBER, R. *PB5L* $15.04 $15.04 17520-HB9-000ZB RUBBER, L. *R109* $15.95 $15.95 17521-HB5-670 TUBE $5.15 $5.15 17620-MA0-405 CAP, FUEL TANK $25.40 $25.40 17624-467-020 GASKET $3.40 $3.40 17626-467-000 COLLAR $3.87 $7.74 18363-KA3-730 COLLAR $4.22 $4.22 19052-MB4-880 COLR, CANISTER MOUNT $2.98 $11.92 80114-MC7-000 COLLAR, RR. FENDER $2.18 $17.44 90010-HB9-000 BOLT, FLANGE (6X18) $1.36 $5.44 90011-HB9-000 BOLT, FLANGE (6X10) $1.36 $4.08 93500-04006-0H SCREW, PAN (4X6) $0.37 $0.74 93500-05008-0A SCREW, PAN (5X8) $0.35 $2.80 95001-75008-60M BULK HOSE (7.5X8000) $51.33 $51.33 95001-75008-60M BULK HOSE (7.5X8000) $51.33 $51.33 95001-75008-60M BULK HOSE (7.5X8000) $51.33 $51.33 95002-02120 CLIP, TUBE (B12) $0.68 $4.08 95002-50000 CLIP, TUBE (C9) $0.42 $0.42 96001-06016-00 BOLT, FLANGE (6X16) $0.62 $1.24 96300-06016-00 BOLT, FLANGE (6X16) $0.62 $0.62 96300-06025-00 BOLT, FLANGE (6X25) $0.92 $0.92 96300-08012-00 BOLT, FLANGE (8X12) $1.52 $3.04 33712-KT1-670 RUBBER, TAILLIGHT $2.84 $5.68 35010-HB9-670 LOCK SET $52.13 $52.13 35113-VM6-007 CAP $5.45 $10.90 53100-HB9-770 HANDLEBAR $69.22 $69.22 53111-HB9-670 HOLDER, R. HANDLE $11.62 $11.62 53121-HB9-670 HOLDER, L. HANDLE $6.62 $6.62 53130-HB9-000 HOLDER, HANDLE $12.98 $25.96 53204-HB5-670 COLLAR $2.51 $5.02 53205-HB9-670 COVER, HANDLE $15.75 $15.75 53206-HB5-670 CAP, HANDLE COVER $2.51 $5.02 61110-388-000 PLUG, HOLE $1.58 $3.16 96300-08035-00 BOLT, FLANGE (8X35) $1.03 $4.12 90304-GE8-003 NUT, U (10MM) $2.96 $5.92 93891-06020-08 SCREW-WASHER (6X20) $0.27 $0.54 17920-HB9-305 CABLE SET, THROTTLE $40.04 $40.04 22870-KR0-000 CABLE, CLUTCH $16.63 $16.63 32161-404-000 BAND B1, CABLE $1.75 $1.75 35200-HB9-020 SWITCH ASSY. $78.82 $78.82 43455-HB9-000 CABLE, PARKING BRAKE $17.28 $17.28 45517-961-000 HOLDER $13.18 $13.18 53140-HB9-000 LINK, THROTTLE $25.80 $25.80 53141-HB9-000 COVER, THROTTLE CASE $24.31 $24.31 53142-HB9-000 CASE, THROTTLE LEVER $33.89 $33.89 53145-HA0-770 LEVER, THROTTLE $15.51 $15.51 53146-HA2-000 SPRING $2.87 $2.87 53147-965-000 HOLDER $15.91 $15.91 53148-HA0-000 BUSH, THROTTLE PIVOT $5.07 $10.14 53150-HA2-000 PIN, THROTTLE CENTER $1.89 $1.89 53165-958-010 GRIP, HANDLE $7.07 $14.14 53167-958-680 GUARD, HANDLEBAR END $3.69 $7.38 53172-961-000 BRKT, L. HANDLEBAR $41.09 $41.09 53177-HA5-000 COVER, L. HANDLEBAR $5.36 $5.36 53178-965-000 LEVER, L. HANDLEBAR $21.65 $21.65 53180-961-010 ARM, PARKING BRAKE $43.75 $43.75 53191-961-010 SPRING $2.18 $2.18 53192-268-000 BOLT, CABLE ADJ. $5.11 $10.22 53192-961-000 LEVER $10.48 $10.48 53192-965-000 LEVER $12.45 $12.45 84906-118-000 COLLAR $1.76 $3.52 87574-HA5-300 MARK $1.20 $1.20 90115-HB5-670 BOLT $5.62 $5.62 90115-961-000 SCREW $1.80 $1.80 90321-315-670 NUT, FIXING $4.67 $9.34 90503-964-000 WASHER, FLAT SCREW $1.55 $1.55 90504-HA0-000 WASHER (9X20) $1.36 $1.36 90505-HA2-000 WASHER, LOCK (6MM) $2.60 $2.60 91210-HA0-004 DUST SEAL (9X16X5) $2.51 $2.51 91354-HA2-000 GASKET $1.82 $1.82 93500-04012-0G SCREW, PAN (4X12) $0.37 $1.11 93500-05018-0G SCREW, PAN (5X18) $0.20 $0.40 93700-06025-0B SCREW, OVAL (6X25) $0.65 $1.30 93892-05025-07 SCREW-WASHER (5X25) $0.55 $0.55 93892-05032-07 SCREW-WASHER (5X32) $0.53 $0.53 94002-06000-0S NUT, HEX. (6MM) $1.48 $1.48 94050-06000 NUT, FLANGE (6MM) $0.57 $0.57 94201-10150 PIN, SPLIT (1.0MM) $0.37 $0.37 95701-06025-07 BOLT, FLANGE (6X25) $0.76 $1.52 33100-HB9-003 HEADLIGHT ASSY. $114.76 $114.76 33120-HB9-003 UNIT, HEADLIGHT $55.23 $55.23 33180-HA2-671 COVER, RUBBER $11.15 $11.15 34901-MC7-601AH BULB (12V60/55W) $6.17 $6.17 32113-HA2-000 CLIP, HARNESS $2.69 $2.69 50715-HB9-000 HOLDER, HELMET $4.02 $4.02 61301-HB9-003 CASE, HEADLIGHT $62.56 $62.56 61303-HB9-000 NUT, HEADLIGHT CASE $3.45 $6.90 61304-HB9-000 COLLAR $1.89 $5.67 61315-HB9-000 RUBBER $4.91 $9.82 61316-HB9-000 PLATE, HEADLIGHT $6.49 $12.98 61317-HB9-000 PLATE, HEADLIGHT $6.49 $12.98 64510-HB9-670 GUARD, HEADLIGHT $63.18 $63.18 87109-HA2-000 LABEL, OIL CAUTION $2.42 $2.42 87511-HA2-670 LABEL, HELMET HOLDER $1.89 $1.89 92301-05008-0A BOLT, SLOT (5X8) $0.50 $1.00 93892-05012-07 SCREW-WASHER (5X12) $0.29 $0.29 96300-06016-00 BOLT, FLANGE (6X16) $0.62 $2.48 96300-06012-00 BOLT, FLANGE (6X12) $0.62 $1.24 45462-HB9-000 GUARD, R. FR. BRAKE $5.62 $5.62 45463-HB9-000 GUARD, L. FR. BRAKE $5.62 $5.62 51210-HB9-670 KNUCKLE, R. $105.98 $105.98 51211-HB9-671 ARM, R. KNUCKLE $17.15 $17.15 51220-HB9-670 KNUCKLE, L. $105.98 $105.98 51221-HB9-671 ARM, L. KNUCKLE $16.78 $16.78 53157-HB9-003 END, TIE ROD $53.11 $106.22 53158-HB9-003 END, TIE ROD $53.11 $106.22 53510-HB9-003 ROD ASSY., TIE $92.18 $184.36 53521-HB9-003 ROD, TIE $28.33 $56.66 53526-679-000 NUT, TIE ROD LOCK $2.02 $4.04 90119-HB9-003 BOLT, UBS (10X35) $3.60 $14.40 90304-GE8-003 NUT, U (10MM) $2.96 $23.68 94031-12280 NUT, HEX. (12MM) $0.52 $1.04 94201-16250 PIN, COTTER (1.6X25) $0.42 $3.36 45126-HB9-003 HOSE, FR. BRAKE $29.75 $29.75 45127-HB9-000 PIPE, FR. BRAKE $15.00 $15.00 45127-KZ4-003 JOINT, BRAKE HOSE $12.40 $24.80 45128-HB9-003 HOSE, FR. BRAKE $45.87 $91.74 45129-HB9-006 JOINT, THREE-WAY $29.85 $29.85 45464-HB9-000 CLAMP, FR. $5.75 $11.50 45510-HC0-307 SUB ASSY, FR M/C $131.04 $131.04 45504-410-003 BOOT $7.45 $7.45 45513-KK1-771 CAP, MASTER CYLINDER $15.38 $15.38 45517-961-000 HOLDER $13.18 $13.18 45520-MG7-006 DIAPHRAGM $6.49 $6.49 45521-HA2-006 PLATE, DIAPHRAGM $6.64 $6.64 45530-KJ1-701 MASTER CYLINDER SET $31.65 $31.65 46666-HB9-006 SEPARATOR $5.75 $5.75 51203-HA7-670 CLAMP B, FR. $4.25 $8.50 53175-HC0-305 LEVER, R. HANDLEBAR $15.31 $15.31 53176-HB9-006 COVER, R. HANDLEBAR $5.22 $5.22 90114-166-006 BOLT $4.13 $4.13 90145-KM3-751 BOLT, OIL (10X22) $6.11 $18.33 46472-568-000 GASKET, OIL BOLT $2.40 $19.20 90651-MA5-671 CIRCLIP $1.69 $1.69 93500-05016-0A SCREW, PAN (5X16) $0.37 $0.74 93600-04012-0G SCREW, FLAT (4X12) $0.37 $0.74 93700-06025-0B SCREW, OVAL (6X25) $0.65 $1.30 94050-06000 NUT, FLANGE (6MM) $0.57 $0.57 96001-06016-00 BOLT, FLANGE (6X16) $0.62 $1.24 96300-06020-08 BOLT, FLANGE (6X20) $0.65 $1.30 43310-HB9-671 HOSE, RR. BRAKE $39.38 $39.38 43510-HB9-P00 SUB-ASSY, M/CYLINDER $99.20 $99.20 43503-HB9-006 CONNECTOR $5.75 $5.75 43504-MB2-006 BOOT $6.15 $6.15 43511-HA2-016 CUP, OIL $20.64 $20.64 43512-HB9-000 HOSE, RR. $17.93 $17.93 43514-964-006 CLAMP $9.95 $19.90 43516-HA2-000 RUBBER $2.84 $2.84 43517-HB9-000 RUBBER, OIL CUP $0.91 $0.91 43520-MB2-305 PISTON SET $52.85 $52.85 94201-40300 PIN, COTTER (4.0X30) $0.38 $0.38 45513-KK1-771 CAP, MASTER CYLINDER $15.38 $15.38 45520-MG7-006 DIAPHRAGM $6.49 $6.49 45521-HA2-006 PLATE, DIAPHRAGM $6.64 $6.64 46182-500-013 CIRCLIP $2.23 $2.23 46503-371-000 PIN, BRAKE ROD $2.65 $2.65 46504-MB2-006 JOINT, BRAKE ROD $5.91 $5.91 50324-425-010 COLLAR (6.3X13) $3.22 $3.22 90145-KM3-751 BOLT, OIL (10X22) $6.11 $12.22 90501-310-000 WASHER (7X12) $1.00 $1.00 46472-568-000 GASKET, OIL BOLT $2.40 $9.60 91212-422-006 O-RING (14.8X2.4) $1.47 $1.47 93600-04030-1A SCREW, FLAT (4X30) $0.29 $0.58 93893-04012-08 SCREW-WASHER (4X12) $0.55 $0.55 94002-08000-0S NUT, HEX. (8MM) $0.50 $1.00 94201-16250 PIN, COTTER (1.6X25) $0.42 $0.42 96300-06022-00 BOLT, FLANGE (6X22) $0.91 $2.73 19010-HB9-670 RADIATOR ASSY. $494.80 $494.80 19012-HB9-000 RUBBER $3.87 $15.48 19015-HB9-670 BRACKET, RADIATOR $6.49 $12.98 19030-HB9-000 SHROUD, R. RADIATOR $33.89 $33.89 19033-HB9-770 GRILLE, RADIATOR $30.42 $30.42 19035-HB9-000 SHROUD, L. RADIATOR $33.89 $33.89 19037-KA4-701 CAP $24.65 $24.65 19038-HB9-670 RUBBER, MUDGUARD $25.84 $25.84 19061-HB9-000 HOSE A, WATER $16.29 $16.29 19062-HB9-000 HOSE B, WATER $16.29 $16.29 19066-HB9-670 TUBE, BREATHER $14.22 $14.22 19101-HB9-670 TK, RADIATOR RESERVE $35.02 $35.02 19102-HB9-670 CAP, RESERVE TANK $17.75 $17.75 19105-HB9-670 JOINT, RESERVE TANK $3.87 $3.87 19506-KA4-000 CLAMP, WATER HOSE $7.20 $28.80 52130-KA4-701 CLIP, SWINGARM $1.31 $5.24 53133-KB4-000 GROMMET $1.33 $2.66 90111-187-000 BOLT, FLANGE (6MM) $3.62 $28.96 91301-PC9-003 O-RING (7.7X2.3) $1.23 $1.23 91351-KE1-000 O-RING (21.8X2.4) $1.45 $1.45 95002-02100 CLIP, TUBE (B10) $0.68 $0.68 95002-02120 CLIP, TUBE (B12) $0.68 $0.68 95002-70000 CLIP, TUBE (C11) $0.58 $0.58 95003-19008-10M BULK HOSE, VINYL $38.50 $38.50 96300-06010-00 BOLT, FLANGE (6X10) $0.62 $1.24 51400-HB9-671 SHOCK ABSORBER, FR. $349.20 $698.40 51401-HB9-671 SPRING, FR. FORK $127.84 $255.68 51410-HB9-003 DAMPER, FR. FORK $184.33 $368.66 51415-HB9-003 GUIDE, SPRING $18.25 $36.50 52406-KB7-003 CAP, DUST SEAL $3.73 $14.92 52422-ME9-013 ADJUSTER, SPRING $21.82 $43.64 52451-HA0-003 BUSH, SHOCK ABSORBER $6.51 $13.02 52452-KB7-003 BUSH, SHOCK (UPPER) $16.36 $32.72 52459-GE2-681 SEAT, SPRING STOPPER $10.62 $21.24 52486-KB7-003 COLR, SHOCK (UPPER) $8.53 $17.06 90304-GE8-003 NUT, U (10MM) $2.96 $11.84 91351-KB7-003 DUST SEAL B $2.04 $8.16 96400-10045-08 BOLT, FLANGE (10X45) $1.23 $2.46 96400-10050-08 BOLT, FLANGE (10X50) $1.23 $2.46 50252-KA4-700 BAND, SUB-TANK $16.04 $32.08 52400-HB9-671 SHOCK ABSORBER, RR. $722.00 $722.00 52401-HB9-671 SPRING, RR. SHOCK $102.42 $102.42 52402-964-671 BOOT, RR. $7.84 $7.84 52410-HB9-671 DAMPER, RR. $677.89 $677.89 52421-HB9-671 ROD, PISTON $300.38 $300.38 52422-MA0-003 ADJUSTER, SPRING $22.62 $22.62 52423-KA3-711 NUT, ADJUSTER $18.47 $18.47 52424-MA0-003 STOPPER, SPRING SEAT $10.38 $10.38 52425-381-771 CAP, AIR VALVE $3.22 $3.22 52430-HB9-671 SUB-TANK ASSY. $94.73 $94.73 52440-HB9-671 HOSE, JOINT $56.37 $56.37 52441-KA3-711 BOLT, OIL (10X22) $6.05 $12.10 52442-KA3-711 WASHER (10MM) $1.40 $5.60 52459-964-003 SEAT, SPRING $16.53 $16.53 52487-HB9-000 COLLAR $14.56 $14.56 52489-HB9-003 BUSH, SHOCK ABSORBER $16.23 $16.23 87516-MK2-681 LABEL, RR. $4.02 $4.02 90158-MG3-000 BOLT, FLANGE (10X70) $7.31 $7.31 90304-GE8-003 NUT, U (10MM) $2.96 $2.96 91265-HA2-013 SEAL $6.49 $12.98 45461-HB9-000 CLAMP, FR. BRAKE $7.20 $7.20 50235-HB9-000 CVR, STEERING SHAFT $7.35 $7.35 53221-HB9-670 BUSH, STEERING $19.25 $19.25 53223-HB3-000 HOLDER (INNER) $19.25 $19.25 53224-HB3-000 HOLDER (OUTER) $19.25 $19.25 53310-HB9-670 SHAFT, STEERING $165.08 $165.08 53317-HB9-000 COLR, STEERING SHAFT $4.91 $4.91 90305-GE8-003 NUT, U (14MM) $3.76 $3.76 90752-GB4-681 OIL SEAL (21X35X7) $2.45 $2.45 90753-GK4-003 OIL SEAL (27X40X6) $5.27 $5.27 94201-30450 PIN, COTTER (3.0X45) $0.37 $0.37 94520-40000 CIRCLIP (40MM) $1.12 $1.12 96150-62033-10 BEARING (6203UU) $10.42 $10.42 96500-08055-08 BOLT, FLANGE (8X55) $1.35 $5.40 24701-HB9-000 PEDAL, GEARSHIFT $19.22 $19.22 28300-HB9-770 ARM, KICK STARTER $101.73 $101.73 28302-965-000 PLUG, KICK ARM $1.40 $1.40 28333-124-000 SPRING $1.33 $1.33 46500-HB9-770 PEDAL, BRAKE $62.33 $62.33 46514-HB9-000 SPRING, BRAKE PEDAL $5.67 $5.67 50603-HA5-000 PIN, STEP JOINT $3.93 $7.86 50610-HB9-670 STEP, R. $31.78 $31.78 50616-HB9-000 PLATE, R. STEP $30.87 $30.87 50617-HA0-680 SPRING, R. $3.04 $3.04 50618-HA0-680 SPRING, L. $3.04 $3.04 50620-HB9-670 STEP, L. $32.47 $32.47 50630-HB9-670 ARM ASSY., R. STEP $56.85 $56.85 50640-HB9-670 ARM ASSY., L. STEP $59.07 $59.07 50642-HB9-000 PLATE, L. STEP $26.60 $26.60 90101-329-000 BOLT, KICK ARM $2.09 $2.09 96300-08028-00 BOLT, FLANGE (8X28) $1.05 $1.05 90401-430-000 WASHER (10.2MM) $1.25 $2.50 91206-965-003 OIL SEAL (19X25X3) $3.87 $7.74 91353-671-003 O-RING (13.5X1.5) $1.35 $1.35 94201-20150 PIN, SPLIT (2.0X15) $0.25 $0.50 95011-40000 RUBBER, SHIFT PEDAL $0.69 $0.69 95801-10040-00 BOLT, FLANGE (10X40) $0.92 $3.68 96211-08000 BALL (#8) (1/4) $0.58 $0.58 96300-08025-00 BOLT, FLANGE (8X25) $1.05 $1.05 87121-HB9-670 STRIPE, R. RR. $38.91 $38.91 87122-HB9-670 STRIPE, L. RR. $32.80 $32.80 87123-HB9-670 STRIPE, R. FR. $32.80 $32.80 87124-HB9-670 STRIPE, L. FR. $38.07 $38.07 87127-HB9-670 MARK, RR. $4.02 $4.02 87502-HB9-000 EMBLEM, RR. SWINGARM $4.73 $4.73 87509-HB9-000 EMBLEM, RR. $7.42 $14.84 87510-HB9-670 MARK, RR. FENDER $12.67 $25.34 87511-HB9-670 EMBLEM, FR. COVER $3.73 $3.73 42621-HA2-670 COLLAR, DISTANCE $24.04 $24.04 43211-HB9-770 STAY, RR. CALIPER $43.15 $43.15 43311-965-000 CLAMP, BRAKE HOSE $4.36 $8.72 43483-HB5-670 BUSH, RR. BRAKE STAY $5.07 $5.07 50355-HB9-770 PLATE, SKID $98.42 $98.42 52000-HB9-670 SWINGARM ASSY. $417.95 $417.95 52109-HA2-305 BUSH, PIVOT THRUST $11.33 $45.32 52141-HA2-000 COLLAR, SWINGARM $15.35 $30.70 52144-HA2-005 CAP, DUST SEAL $6.51 $26.04 52156-HB9-000 SLIDER, SKID PLATE $33.89 $33.89 52170-HA2-770 SLIDER, CHAIN $23.91 $23.91 52171-HA2-000 STAY, CHAIN SLIDER $3.87 $3.87 52175-HB9-005 SLIDER, CHAIN $17.15 $17.15 52201-HA2-670 HOLDER, BEARING $198.69 $198.69 52202-HA2-670 SEAL, BEARING HOLDER $8.45 $16.90 90011-HB9-000 BOLT, FLANGE (6X10) $1.36 $1.36 90115-964-003 BOLT, STOPPER (8MM) $2.09 $2.09 90116-125-782 BOLT, SOCKET (8MM) $4.13 $8.26 90117-HA2-000 BOLT, RR. SWINGARM $61.78 $61.78 90129-MA2-000 COLLAR $2.18 $2.18 90305-GE8-003 NUT, U (14MM) $3.76 $3.76 90481-035-000 WASHER (8MM) $1.09 $1.09 90501-HA2-670 WASHER, AXLE COLLAR $6.36 $12.72 90665-964-000 CIRCLIP (70MM) $7.58 $7.58 91051-HA2-013 BEARING (40X62X12) $24.98 $49.96 91071-MA0-003 BEARING, RR. $20.22 $40.44 91252-HA2-003 DUST SEAL (52X62X7) $9.73 $19.46 91253-HA2-005 DUST SEAL $4.56 $18.24 91351-737-752 O-RING, ROTARY CASE $3.36 $3.36 91353-HA2-670 O-RING (81X3) $4.25 $8.50 91302-MS2-003 O-RING (69X2) $2.47 $2.47 90155-964-670 BOLT-WASHER (8X16) $3.27 $13.08 94510-12000 CIRCLIP (12MM) $0.88 $0.88 96300-06010-00 BOLT, FLANGE (6X10) $0.62 $1.24 96300-06012-00 BOLT, FLANGE (6X12) $0.62 $0.62 33700-HC0-770 TAILLIGHT ASSY. $48.71 $48.71 33710-HB9-771 LENS, TAILLIGHT $22.98 $22.98 33715-HB9-000 RUBBER $2.98 $5.96 33720-HC0-003 SOCKET $13.00 $13.00 34905-HB9-671 BULB (12V5W) $2.87 $2.87 50231-HB9-000 BRKT, R. TAILLIGHT $8.52 $8.52 50232-HB9-000 BRKT, L. TAILLIGHT $9.53 $9.53 61308-HA2-000 PIN, HEADLIGHT BAND $2.36 $4.72 81200-HB9-670 PIPE, CARRIER $70.57 $70.57 83511-VM6-680 COLLAR $5.29 $10.58 83513-HB9-000 STAY A, TOOL BOX $9.22 $9.22 83514-HB9-000 STAY B, TOOL BOX $9.22 $9.22 96300-06012-00 BOLT, FLANGE (6X12) $0.62 $1.24 96300-08016-00 BOLT, FLANGE (8X16) $0.91 $1.82 96300-08040-00 BOLT, FLANGE (8X40) $1.07 $1.07 96300-08050-00 BOLT, FLANGE (8X50) $1.23 $1.23 83500-VM6-680 BOX ASSY., TOOL $54.44 $54.44 83505-VM6-680 CAP, TOOL BOX $13.95 $13.95 83507-965-000 BODY, KNOB $9.58 $9.58 83508-965-000 STOPPER, KEY BODY $2.98 $2.98 83510-VM6-680 SEAL, TOOL BOX $12.16 $12.16 83642-HA0-680 BAG, OWNER'S MANUAL $8.04 $8.04 89010-HB9-000 TOOL SET $50.42 $50.42 89101-965-003 TOOL BAG (170) $8.67 $8.67 89102-538-000 SHAFT $2.42 $2.42 89103-538-000 GRIP $1.77 $1.77 89213-HA7-670 WRENCH, BOX (P18X17) $8.24 $8.24 89215-404-670 WRENCH, PIN $3.58 $3.58 89216-HA2-670 WRENCH, BOX (21MM) $9.51 $9.51 89221-HA2-670 WRENCH, HEX. (6MM) $6.11 $6.11 89301-HA0-771 GAUGE, TIRE PRESSURE $18.45 $18.45 94305-20141 PIN, SPRING (2X14) $0.62 $0.62 99001-08120 WRENCH (8X12) $1.83 $1.83 99001-10140 SPANNER (10X14) $2.18 $2.18 99002-13500 PLIERS (135) $3.70 $3.70 42753-VM0-003 VALVE, RIM $7.67 $15.34 44312-VM0-000 COLR, FR. WHEEL SIDE $3.89 $7.78 44610-HB9-000 HUB, FR. WHEEL $162.84 $325.68 44620-VM0-000 COLLAR, FR. $8.91 $17.82 44701-HB9-003 RIM, FR. (10X5.5) $254.90 $509.80 44710-HB9-003 TIRE (21X7.00-10) $40.55 $81.10 45251-HB9-670 DISK, FR. BRAKE $124.64 $249.28 45255-HB9-000 MUDGUARD, R. FR. $31.95 $31.95 45256-HB9-000 MUDGUARD, L. FR. $33.16 $33.16 90103-HA2-003 BOLT, WHEEL (10X36) $5.22 $41.76 90105-HB9-000 BOLT, DISK (6X20) $4.09 $32.72 90304-HA2-003 NUT, WHEEL CLIP $3.53 $28.24 90306-329-770 NUT, RR. WHEEL AXLE $4.36 $8.72 91257-MAY-003 DUST SEAL (28X42X8) $5.60 $11.20 91257-VM0-004 DUST SEAL (28X42X6) $6.82 $13.64 94201-40300 PIN, COTTER (4.0X30) $0.38 $0.76 96150-60040-10 BEARING (6004UU) $13.70 $54.80 96300-06012-00 BOLT, FLANGE (6X12) $0.62 $1.24 42316-HA2-000 COLR, RR. AXLE SIDE $9.69 $19.38 42410-HB9-670 HUB, RR. WHEEL $122.27 $244.54 42701-HB9-003 RIM, RR. (9X8.0AT) $285.02 $570.04 42710-HB9-003 TIRE (20X10.00-9) $56.10 $112.20 42753-VM0-003 VALVE, RIM $7.67 $15.34 90103-HA2-003 BOLT, WHEEL (10X36) $5.22 $41.76 90304-HA2-003 NUT, WHEEL CLIP $3.53 $28.24 90305-HA5-670 NUT, AXLE (20MM) $11.07 $22.14 94201-40300 PIN, COTTER (4.0X30) $0.38 $0.76 405W3-HB9-505 CHAIN, DRIVE $111.81 $111.81 40531-HB5-671 MASTER LINK $4.40 $4.40 41201-HA2-670 SPROCKET (39T) $76.81 $76.81 42310-HB9-000 AXLE, RR. $362.51 $362.51 43122-HB9-000 DISK, BRAKE $221.18 $221.18 43126-HB9-000 FLANGE, BRAKE DISK $68.73 $68.73 43127-HB9-000 BOLT, RR. AXLE $30.98 $30.98 50254-HB9-670 GUIDE, JOINT HOSE $8.58 $8.58 52158-HB5-003 ROLLER, CHAIN $16.76 $16.76 52159-467-000 COLLAR, CHAIN ROLLER $6.65 $6.65 90112-GZ0-000 BOLT, DISK (8X20) $3.64 $14.56 90114-HA2-670 BOLT (10MM) $3.84 $15.36 90304-GE8-003 NUT, U (10MM) $2.96 $11.84 90307-HA2-000 NUT, RR. $15.07 $15.07 90308-HB9-000 NUT, RR. AXLE $15.07 $15.07 90651-HA2-000 CLIP (OUTER) (40MM) $2.16 $2.16 90652-HA2-000 CLIP (OUTER) (37MM) $2.04 $2.04 91351-HA2-005 O-RING (39.6X1.3) $2.04 $4.08 94050-08000 NUT, FLANGE (8MM) $0.57 $0.57 94101-08800 WASHER, PLAIN (8MM) $0.35 $0.35 96400-08075-00 BOLT, FLANGE (8X75) $1.23 $1.23 30401-HA0-000 CUSHION $3.13 $3.13 30406-HA2-000 RUBBER, REGULATOR $3.07 $3.07 30410-HA2-671 MODULE, IGN CONT $113.87 $113.87 30506-VM6-000 SUSPENSION $8.06 $8.06 30510-HB5-000 COIL $44.62 $44.62 30700-VM0-013 CAP ASSY. $23.51 $23.51 31410-HB5-671 REGULATOR, A.C. $92.18 $92.18 32100-HB9-671 WIRE HARNESS $89.75 $89.75 SubTotal $30,427.69 Type of shipping: Standard Shipping $55.00 Total $30,482.69
  18. shit that sounds tight
  19. i hope i can make it to this trip sounds like its gona be a fun time
  20. ok i'm way to lasy to read all your post but i swear my presure plate spins even with the clutch pulled in i will have to look at it again when my bike is back togeather mabey couse it was in nutral but who know i will jsut have to look for my self soem time
  21. wow thats a nice banshee man looks clean
  22. yes night rider is 100% correct they spin becouse your crank is still spinnning the crank is conected to the gear on the back of the clutch by a gear so you can still weld it togeather at idle if you kept revving her up like you do in a dragg race
  23. yeah that would probably work pretty good
