Everything posted by Fr33zypop
Rear brake pad replacement question
Fr33zypop replied to Fr33zypop's topic in General Banshee Discussion
Piston is not frozen and moves fine. If the two slide pins are supposed to move they don’t. I can try to soak them tonight. Sent from my iPhone using Tapatalk -
I could use some help on this. I don’t have the ebrake assembly anymore. This plate on the right. Is it supposed to move at all? I’ve tried to get it to move in with a clamp but it won’t budge. Not sure if it’s seized or what. The only pad I can fit is one with the pad 100% gone. The new one will but the rotor is pinched and won’t fit. Sent from my iPhone using Tapatalk -
Striped the threads for the bowl cover
The current setup meets my needs so probably nothing crazy. Sent from my iPhone using Tapatalk -
I knew this would eventually happen as I have been the most gentle with these carbs but last night was the last straw. The threads for the screws for the bowl cover let loose and I wanted to see what options I have are. I am familiar with tapping new threads. The only threads I lost are the one with the little round guides to hold the fuel overflow tubes. I tried and was able to get them tight without those guides so I am wondering it I should look for longer screw? I've only tapped steel so with aluminum I just want to be sure I don't mess it up more. The last option I have is to get a new pair of 28 keihin and seems like my best option. These old carbs have seen better days..
I don’t have the parking brake setup anymore and was removed before I owned it. I’ll have to research that. Thanks Sent from my iPhone using Tapatalk -
So I’ve replaced a ton of brakes in a lot of cars and trucks and wasn’t to worried about the banshee but wtf. I can’t seem to fit the new pad on the right side of the caliper. When I tried to put on both new pads the rotor was getting jammed by this raised area. What am I missing here? I watched some videos already but I haven’t seen this issue raised. Because I was about to go for a ride I had a pad that was completely wore off to get it to fit. Sent from my iPhone using Tapatalk
Earlier this spring I put in a new petcock as mine was leaking and this weekend I had a chance to to for a ride and while warming up the shee I could tell it wasn’t running well. I’ve come to to conclusion the gas isn’t flowing real well. When I removed the old petcock I found the plastic fuel filter has fallows off in the tank from a rollover or whatever from the last owner. I have a pretty new under 40 mile inline filter I’ve ran without issue on the old open petcock. I’m wondering if have two filters If it’s restricted. It’s hot af here so I plan to try and get a new inline and hose to see if that helps some early morning this weekend . I might try to drain the tank but I need a hand pump to see if the other filters the issue. The stem is bent in so I can’t remove the tank or petcock easily. Sent from my iPhone using Tapatalk
Yeah my bad on that lol Sent from my iPhone using Tapatalk
I read a post from a while back they said they tossed the white cover so think that was wrong until I looked at other installs of case savers. I ordered a new one. I see some wear from the chain so I’ll smooth that out and use lock tight. I think it just got loss but the oring is shot too. Sent from my iPhone using Tapatalk
I took off the saver and found the white cover was behind and cracked. I’ve had it some what tore apart repainting the frame and have been tracking where it’s coming from. I don’t know if someone has a print size I’d need to use here as it not there. Sent from my iPhone using Tapatalk
I'll just pull it i guess and see what the issue is. I don't know what vents would be around the case saver.
I didn’t install the case saver on my banshee and have found it’s leaking quite a bit. It’s plastic but not sure if this is normal or if the messed it up somehow. Not sure if it needs a gasket or some rtv to help seal it up. Sent from my iPhone using Tapatalk
