christoph.tamz
Everything posted by christoph.tamz
  1. I'm running 162 mains. Sent from my SM-N920V using Tapatalk
  2. Plugs are seating fine and not backing out. Sent from my SM-N920V using Tapatalk
  3. I believe the pilot is 27.5 Sent from my SM-N920V using Tapatalk
  4. Also 93 octane Sent from my SM-N920V using Tapatalk
  5. Br8es. 32:1 yamalube . and yes. Sent from my SM-N920V using Tapatalk
  6. Carbs are getting fuel. I can take them apart to clean them. But didn't do that yet Sent from my SM-N920V using Tapatalk
  7. Also. Hard as hell to start. Sent from my SM-N920V using Tapatalk
  8. So I was ripping the shee and it died. Got it home with a hell of alot of backfiring. Took the left plug out and was crushed. Right was fine. What I've done so far was. Changed plugs Cleaned the stator and pick up Compression is at 160ish Case holds 6psi for 6mins Changed coils, confirmed spark I did notice the pick ups on the fly wheel were flattened In The start of them. She fired but won't hold an idle and heats up quick. Any ideas? Sent from my SM-N920V using Tapatalk
  9. Or this. Sent from my SM-N920V using Tapatalk
  10. There is gaskets that go there. Are you talking about this. Sent from my SM-N920V using Tapatalk
  11. They are ment for every pipe. Buy oem tho. Sent from my SM-N920V using Tapatalk
  12. Exhaust gaskets 2 Exhaust springs 4 Might as well do both so you know. Sent from my SM-N920V using Tapatalk
  13. Pressure test the motor, then do a leak down. As far as jetting, you need to get that idle down then plug chop. Sent from my SM-N920V using Tapatalk
  14. Might be to short of a cable and it's pulling. Take off the filter and see what's going on. Sent from my SM-N920V using Tapatalk
  15. It sounds like your throttle cable is stuck. Did you delete the tors? Some times it gets hung up on the inlet where it comes into the top of the carb, cable routing, idle screw. It all sounds simple but double check Sent from my SM-N920V using Tapatalk
  16. I guess people spend thousands of dollars on machines just to say I have xy and z. Sent from my SM-N920V using Tapatalk
  17. 🤣🤤 Sent from my SM-N920V using Tapatalk
  18. I oiled mine before running them. I pulled the carbs to jet and they were clean. Sent from my SM-N920V using Tapatalk
  19. Bong Sent from my SM-N920V using Tapatalk
  20. I'm tired of flakes that say they want to ride and bail. Anyone up here wanna ride. Don't care what machine you have. Sent from my SM-N920V using Tapatalk
  21. Altitude? And white plugs mean lean Sent from my SM-N920V using Tapatalk
  22. Sold. Sent from my SM-N920V using Tapatalk
  23. Pm me for carb sync tool. I have a brand new one. Sent from my SM-N920V using Tapatalk
  24. I took one of the old ones off since I have 2 coming. They do come over the crank. Sent from my SM-N920V using Tapatalk
  25. Yeah. I figured that out after I posted that Sent from my SM-N920V using Tapatalk
