Duke 2 Stroke
Everything posted by Duke 2 Stroke
  1. Anyone happen to have a set of cpi silencers for sale please contact me 404-937-0993. Text message will be great. PayPal ready
  2. Too rich need to come down on your main jets
  3. Only if you want waste money. Compression not high enough to really run higher octane fuel. Stick with 93 pump gas and you will be just fine. Looking for more power get port work , 4mill crank, vforce4 reeds or better yet a 421 cheetah cub
  4. So their are different needle/seat assemblies as well? Do you know exact needle/seat assembly I need to order?
  5. Do you know what Mikuni fuel pump I should look for? From which model bike? Any info would be helpful
  6. That was some very good advice and knowledge you shared there brother. Thanks for the advice and I will definitely look more into this before I think about attempting this.
  7. Yes but I was trying to find out is there a certain fuel pump with certain amount of psi I need to look for
  8. Hey did you ever figure out the fuel pump issue?
  9. You have any black rear plastics
  10. I have a 421 cheetah cub non ported. Wasn’t sure what thickness to go with at time so I went with .020 base gasket
  11. I have carbs and front bumper
  12. I have a 421 Cub engine I’m building and I wanted to know what are the difference between the thickness of the gaskets. What are the different sizes for? I have a .012 thickness gasket and a .020 thickness gasket.
  13. $150 Sent from my iPad using Tapatalk
  14. Sent from my iPad using Tapatalk
  15. I have a stock stroke crank in great running condition Sent from my iPad using Tapatalk
  16. Thanks but I seen your message too late. I have a set now. Sent from my iPad using Tapatalk
  17. I need silencers. Wanna sell separate? Sent from my iPad using Tapatalk
  18. I have a set of stock 66mm bore dune ported cylinders for $200 shipped. Ready to bolt on and go. Also have a set of and a Pro Design Cool Head that I can throw in for another $100. If interested let me know. Sent from my iPad using Tapatalk
  19. Sent from my iPad using Tapatalk
  20. $300 plus shipping. Sent from my iPad using Tapatalk
  21. No it will be fine without oil. Sent from my iPad using Tapatalk
  22. I have a Hot Rod 4 mill trued and welded. Sent from my iPad using Tapatalk
