Buster91dg
Everything posted by Buster91dg
  1. So I was messing around with it so here's what I did float heights where good fuel is flowing good. Took apart coil wire where shitty so I went to advance got acel wire and tried to make them work and now it runs only on the left cylander right side has spark and is getting gas the plugs wet. Assuming something may be bad with the coil
  2. Ik I'm prob wasting my time doing this but this is a lot cheaper to eliminate probs rather than throw parts at it. I'm leaving towards a coul bec Ik before when I washed it it was skipping on one side then blew it off nd it was fine. I bought a ohm tractor any specs on wat the coil should test at. And it's dc or ac
  3. No I'm in ri I'm going to do a leak down test too anyone know what size pvc pipe to get to plug the outlets of the carb in take
  4. Where are you located
  5. Still runs like shit maybe the coil is no good noticed some wear marks on the stator
  6. Im not sure what they look like I'm gunna check float height and make sure I have nothing plugged
  7. I re check the reed I jut put new ones in
  8. It's good just fmf heck it with the feeler guage at almost redline it's doing it like it back firing just die electric greased the stator the pick up maybe I should check float height but I never noticed the problem before
  9. This is my feeler guage it's in mm
  10. Should I put any die eclectic grease on the pick up
  11. Ok let me check it I'm working on it right biw
  12. So the pick up can be adjusted to magneto??
  13. Ok I have feeler gauges but don't know if there metric. Think there in inches
  14. It was fine last weekend that's what I don't understand
  15. How do I measure the gap and I did spray that crc cleaner got a little better that's Abt it
  16. Any ideas for drying
  17. Elevation is 282 as well if that helps
  18. Hey guys another problem with this headache. So now I go out today and started noticing a bog/back fire at high rpm esp when I really lay into it was fine for the first 20 min then I started noticed opens up stator side cover plastic part was slightly coated w water bike seemed fine last weekend have 30pilots 310 mains with fmf fattys pro design intake w k&n filter no lid. Bored 64.50. Needle 4th clip down from the top 1.5 air screws out please help before I sell this thing
  19. I couldn't find it in the parts diagram
  20. I'm allset found one later that night thanks tho
  21. I can't even find that bushing on the oem parts fiche. Any body know what jt would be ubder
  22. Yeah on my anyways it's a 1990 there is a rubber washer that goes against the frame and the hanger goes against it. Does anyone know if they used the rubber bushing to mount up the tm design hanger or just bolted it metal on metal
  23. Yes just wondering if the rubber bushing that is used with the stock hangers you have to use for the tm hangers do you have a pick of yours
