Buster91dg
Everything posted by Buster91dg
  1. Hey guys just dropped my main jets from 310 to 300. Had a little issue I've noticed when shifting into gear. Would have a slight bog but powers through I thought that it was bec I was rich so I dropped down a size but still seems to do it maybe I should try new plugs?
  2. Going to go through Dennis Kirk can't find it on the hot rods site
  3. What are my options?
  4. Where's does it say it's for a banshee I want to order it right nie
  5. Ok great I'll have to order does anyone have the link for the hot rods kit with collar and seal
  6. Ok should I bother replacing the seal it was part of the wiesco bottom end kit that I did 3 months ago maybe 6 hours of ride time on motor
  7. Ok I'll check the hot rods site for the kit
  8. And like i said could it be from a worn collar? It is a 1990
  9. This is all I'm seeing no oring
  10. Seal is brand new oil seems to be seeping from in between the collar and shaft. Is there an oring that goes on the shaft that the collar goes against?
  11. It just has to be the bad design tranny bec when I'm on road or dirt it's fine never any issues never comes out of fear I'll try the shift star mod and detent Spring
  12. Yeah dies the cascade shift star and detent roller help shift easier
  13. Shift shaft is brand new the spring that goes on shift shaft was a little worm I'll get a new one will the modded shift star and roller arm from cascade will that help it shift better it's all adjusted correctly had it apart wen I did the bottom end
  14. Ok I will try that should I get on the throttle while I'm doing so and it was shifting fine before I was doing 1-3 pulls at (WOT) is on the dirt no issues at all it's prob just me to be honest it's hard to hold on need to set it up better and get a nice aftermarket shift that's more comfortable
  15. Please tell me Its just me lol I nuts when it comes to my shee
  16. I felt is though when I'm on the gas hard from a dead stop on snow I feel like I keep hitting neutral is there something wrong with the tranny or is it just bec the tires are spinning so freely on the snow. It fine when Im driving through the trails normal
  17. So today I road my banshee in awesome Derry nh. There was abt 3 inches of snow. Was shifting fine all day till the end of the day I was doing a hard pull from 1-3 and noticed wen I have the Tirea spinning fast or I wasn't hitting the shifter good enough but during the day it was good all day on hard acceleration. Maybe it was from the accessive spinning In snow
  18. Yes there brand new but I will check
  19. The coil was the issue runs nice now I noticed another issue. I was doing some woods riding through some brush then got out of the trail and was on the road shifting through the gears and it felt is tho that something was rubbing on the chain if I lugged the motor then once I got rpms up it went away then it did it a few more times now I can't get it to do it again. It never happened before. bearings in the carrier and swing arm are all tight no play brand new chain and sprockets I just installed a tm case saver too any ideas? Could it be the transmission? I feel it in the back of me so I'm not sure any advice or help would've great
  20. had to drink my sorrows away with this thing hopefully the new coil will fix my problems
  21. Yeah I actually went and bought one but to be honest with you I have no idea how to use it and what setting to put it on
  22. Float height was good Fuel flow was good Pick up coil gap was correct Coil wires where real shitty looking and I went to advance picked up some acel wires tired those and now it's running on one cylinder. I ordered a new ignition coil hope this fixes my original problem which was it was breaking up at high rpm
