hey there so i have an 87 banshee, ive did a bit of work to it but this is the first 2 stroke ive worked on. i did the basics on an old machine i rebuilt the clutch, rebuilt the carbs. new plugs a set of t4 pipes. the issue that im having is a possible ignition coil. it fires on one side but not the other when i switch the coil wires around the problem moves as well. so im thinking ignition coil. my main question is what makes it want to rev high? ill be able to rev the throttle it will take its time to go back to an idle. then after a couple revs it just stays at a high rev so i have to kill it with the switch. ive already replaced the reeds with vforce reeds. will that ignition issue make it run at a high idle like that?
