hondaracing02
Everything posted by hondaracing02
So my Push lever on my 03 Banshee popped up and bent the retainer clip when I was riding and is now slightly corked, (ATTACHED PIC). I tore into the clutch side cover when i got my new push lever. Behind the clutch pressure plate, theres the lifter thing (attached pic) and the push rod ball was froze to it, and the push rod behind it doesnt move when i press on it with a screwdriver? how do i get the push rod out to replace it, some kind of magnet to pull it out or what?? and whats the lifter piece? please see the pics and the issues Im having will be better explained.. I also attached a pic of what the nut for the clutch adjustment looked like, isnt this way out of alignment? could this have caused the push lever to pop out? Thanks for all the help
Banshee clutch replacement
hondaracing02 replied to hondaracing02's topic in Banshee Repairs and Mods
can i just tip the quad on its side and not worry abotu fluids? -
found one! confusing on how to get that push lever out/ replace... -
anyone know of a downloadable clymer? -
if i lay quad on left side ill be good with both fluids? i gotta replace the clutch arm on opposite side, but think i gotta lossen somethin up in clutch to get arm down in. -
do you have to drain any fluids to get at the clutch? how do you get at it?
I have an 03 banshee that I was riding down the road when the clutch linkage (i believe that is what its called, the internet called it the push lever assembly.. its the piece the clutch cable attaches to that goes down into the motor and has a bracket that bolts down over top of it). either way it popped out of the motor and bent that bracket up when i tried to shift to 5th or so? now its all warped and twisted. (POSTED PICTURES) I ordered a new one and got it in the mail, but am not sure how to install it? When i watched an engine disassembly video, the guy just pulled it right out of the motor? I figured it would be connected to some sort of push rod or something? I do not want to split the cases to do so, but if I have to I will. Any help on how to replace this piece will be greatly appreciated! thanks in advance. Also, based on the picture of the old clutch linkage piece, i shouldn't have to worry about pieces down in the motor should I?
