EaCastillo00
Everything posted by EaCastillo00
  1. One question: how good are barnett clutch kits in general vs OEM? and Is this kit compatible with my stock clutch basket? Barnet Dirt Digger carbon fiber clutch kit
  2. What is FAST? I have looked for it cant seem to find it :/
  3. Ok so can i buy this jetting kits on ebay? Cause im from central america and they dont have like a really good bike shop here
  4. The place i am is about 100 meters above sea level
  5. Well i got myself some Toomey T5s headers and pipes, proflow sistem with k&n filter, sprokets 13 T up front, 41T on the back, my carbs are stock never have rejeted, please tell me will i need rejeting? And if so which size of jets should i buy?
  6. What does it do? What function does it have? What is the cdi box for? Please answer
  7. mine had that issue, its probably the crank seal, check if your oil level is going down
  8. or if the bike overheated too bad could also be the cylinder head that cracked and its also letting compression through :/
  9. if your radiator is spitting the coolant, its definetly the gasket, its probably al toasted because its old or something, or its to thin, the radiator spitting thing its because your gasket isnt doing its job probably not sealed correctly and its letting the compression through to the coolant, and basically its boiling and evaporating it because its too hot :/
  10. what do you mean when you say surfaces? do you mean if the cylinder head is alright? please explain? and what would be a good material for a gasket? maybe i should go yamaha oem ?
  11. thing is, im living out of the states, so my only place for buying replacements is ebay, so i need to know a good brand so i can buy em and get them shipped
  12. Im about to order a gasket kit for my banshee and i would like to know which are the best brands of gaskets
  13. actually already have them... just wondering what do i exactly have.
  14. i know this will sound stupid but well... how do i port the cylinders? what is porting a cylinder, what does it do? how to achieve it ?and cant do the second one, i have TORS boxes
  15. Well my banshee is mostly stock, everything is stock but my pipes, i got some T5 , what could be my next step? what should i change next? basicaly i want it to go faster xD i want to know what can i change so i will feel a difference on my shee
  16. I want to know at what range will it affect the performance of my quad? what do they do? are they good, bad, very good? anything you can tell me about them
  17. ok so what would be your advice? tell me your opinion im asking for help :/
  18. Yep, after 15 min of riding -.-, but its allright since it didnt melt the freaking pistons and the rings xD i just have to find some nice gaskets and it should be done, everything else on the bike is in pretty nice shape
  19. mmm they were made of laminated aluminun i think and the weren like thick enough... and they were fixed with shellac gasket cement, and i saw that the shellac went into the cool head and some holes in the cool head were blocked so there was some holes in the cool head that weren circulating the coolant right, so i think thats the main reason... im going to make some laminated asbestos gaskets, and seal them with gray gasket maker, i think that should do the trick
  20. Hey thank you for the advise, i tore it down and thank god it wasnt so bad, my pistons are all right and so are the sleeves, the rings are fine, aparently the gasket making was really crappy, the gaskets totally melted, both the cilinder head gaskets and the ones from the cylinder bases, im so relieved i didnt melt the freaking thing off i just have to get myself a really good gaskets, any advice? sorry couldnt take pictures :s next time i will
  21. sometimes you should check the seal that that keeps the oil from the tranni going into the engine, if that seal is not working anymore that could be your mistery resolved, hey guys i really need asisstance with a topic i posted yesterday please help meee
  22. hey guys please look at my post really need an opinion
  23. i was riding, i had just started the bike like 15 min ago, didnt even run it hard cause my shocks arent working well, and suddenly, it turned of, and there was smoke coming out of the base of the cilinder, im pretty sure it had coolant in the radiator cause i had just cheked it, and it had oil, the mix was done right... what could had happened? maybe the gasket got toasted, i didnt even tried to start it up again, cause i was afraid i might just have burned the engine... i dont know... what do you think... when i checked the water, after it turned off, it was gone... dont know how could it overheat if it had water and oil???? gaskets? what do you think? HELPP
  24. i was riding, i had just started the bike like 15 min ago, didnt even run it hard cause my shocks arent working well, and suddenly, it turned of, and there was smoke coming out of the base of the cilinder, im pretty sure it had coolant in the radiator cause i had just cheked it, and it had oil, the mix was done right... what could had happened? maybe the gasket got toasted, i didnt even tried to start it up again, cause i was afraid i might just have burned the engine... i dont know... what do you think... when i checked the water, after it turned off, it was gone... dont know how could it overheat if it had water and oil???? gaskets? what do you think? HELPP
