Pastrykiller
    2
Everything posted by Pastrykiller
  1. Who's numbers? Meth or shearer?
  2. When u say pump gas, are u saying 93 or race gas. My 421 as cast pulled 84 85 and 86 on shearers dyno.
  3. Some say +5, some say +7 and other are just way off the charts. I personally have a dyno sheet that showed +8 as my sweet spot. Throwing timing on any motor should be done with extreme caution. It's no different than jetting. Each bike knows what it wants and timing is treated no different. I'm no expert but first hand experience is what I am using as my source.
  4. Naw he just sold them on eBay
  5. Turn it till it cracks then back off 1/2 turn. Should be 20 ftlbs
  6. You need to find time to read about each fuel. A lot of things play a part in fuels such as lead content, specific gravity, motor octane, oxygenation......
  7. Mine was at +8. Anything short of that would result in a 6-10hp decrease. The curve was also affected drastically below +8. Not saying its right but I do believe it has everything to do with your dome size and not dome cc. I was running vp110 also
  8. Thanks. I already have sourced these jets. Now I have a shit ton that I will prob never use.
  9. I think the term you are looking or is zero tolerance. 1211 should get it done. It forms to any shape. Yamabond is like snot.
  10. 1211 will seal up rough mating surfaces. I have also heard that 1104 sealant is thicker and is possibly better to use for said application. Stay clear of yamabond and Hondabond if you dot have a smooth mating surface.
  11. Tim: I have a good caliper/master cylinder that is held up in an eBay dispute. Should have it resolved in a day or so. Admin: please lock this thread. Bike will be sold as complete unit locally.
  12. Thanks for the correction Abe. I am in southern cali
  13. Square plug 87-94 years and round plug is 94/95?-2006. It's the square plug.
  14. Photos will come shortly. If you need a photo ASAP, pm and I will get that to you. Prices are gifted and shipped Stock banshee foot pegs with bolts. 25.00 Lightened flywheel with no rattle 125.00 Old style stator with modified plate or +4 80.00 Old style wiring harness, cdi and reg 80.00 Cases no chain whack 150.00 Clutch basket inner, outer and plate. Slight wear 75.00 All three shocks, red springs no leaks, 85.00 Bills pipes 125 plus actual shipping White uncut plastics 125 plus actual shipping. If you need something, just ask.
  15. That's an easy install. Use ring pliers or needle nose pliers. Don't bend it and it should be good to go.
  16. No but how much are you talking about.
  17. Thanks for the info. I just want to see if someone had them laying around. I have a bag of jets that I will never use and I am sure other do as well.
  18. Need some 152's and 155's
  19. I'm sure someone has tried this already.
  20. 1211 sealant. Thin layer and let it sit for 24 hours. Check your squish afterwards. Smallest base gasket u will find.
