facetiousxm
    421 cub.
facetiousxm's Achievements
  1. Set of lectrons with big bowls. 40mm intake with 38mm. Comes black billet lectron engraved bowls , orginal small bowls and lectron cable. $650 shipped.
  2. Thanks man, I have a pancake and a slingshot. Big fan of the slingmonster.
  3. And denny is a stand up guy. He was honest, reliable and had my porting done quick. It might not be the OMG fastest porting in the world, but then again I only have a 4mm cub. If I wanted to be the best and not just some keyboard racer id have a big motor and a light ass frame. It's all about the setup. best porter in the world can't make you have traction.
  4. main is 160 pilot 48 needle dek slide 4.5 clip 2 it seems to like it like that. it's a tad bit on the lean side, it still doesn't idel for shit but i don't care, most of the time when i get to the line i just let it die till everyone is set so my clutches don't get hot.
  5. Actually he was spot on with the jetting. It was my fault I left a stray stator wire in the side cover lose and it rode against the fly wheel causing it to short out and wouldn't let it rev out. Live and learn. It's back running good. Thanks for the help gents.
  6. Yeah, I am at .015 on the gap. Thanks man.
  7. Yeah it's a dek needle, I was doing some search on it. usually the slide is a 6 but mine is a 4.5. It all came like that. Yes I had it ported by flotek and I like it so, your childish opinion doesn't matter to me. I came on here to ask for adult advice. It ran me 250 and turn around time was a week, great guy and has answered pretty much all my questions. Yes, I called around and I didn't wanna wait a month and pay 500. I'll just go up on the Main two sizes and down one size on the pilot and see where that takes me. Thanks to the adult responses.
  8. admin please delete i i accidentally posted twice and cant figure out how to delete thanks
  9. flotek drag port dual kn
  10. I have a 421 cub it was running pretty decent before but now not so much, after flotek porting and new pistons. I know 35 are a lot small for my motor but it's what it came with. cpi inframe sea level humid as fuck c12 36-1 klotz main is 160 pilot 48 needle dek slide 4.5 clip 2 it falls off on top end and plug is a bit gray which means lean, and it loads up at idel any help would be greatly appreciated. thanks shawn
  11. I have a 421 cub it was running pretty decent before but now not so much, after flotek porting and new pistons. I know 35 are a lot small for my motor but it's what it came with. cpi inframe sea level humid as fuck c12 36-1 klotz main is 160 pilot 48 needle dek slide 4.5 clip 2 it falls off on top end and plug is a bit gray which means lean, and it loads up at idel any help would be greatly appreciated. thanks shawn
  12. Thanks once my cub comes back from millennium ill check the squish.
  13. Thanks ill try the 1211 sealant, I have a .012 now had .005 taken of my domes from some rash believe I had a .020 base gasket originally. Just trying to keep compression around 190lbs. Thanks
