bluepartsman
Everything posted by bluepartsman
  1. Carbs are junk.... There is a ridge so bad just off idle on the main body from wear that the slides have almost 1/8 of an inch free play. The sides are not worn just the main body. It causes such a big air leak the idle is through the roof. He claims he knows nothing about the carbs because the dyno shop set them up and they worked great. Bottom line they are not as described and worn out.
  2. Still seems like its way out of wack. i will post photos if someone else maybe can Also
  3. I can do a partial trade cool head that I have for those BBshearer IF pipes you got?
  4. What I have done is replace the hard billet front pipe mount i had with the rubber mount which does two things: it spaces the pipe out further to begin with and it allows much more movement(rubberm ount) when the bolts are tight. I haven not tried moving the rear silencer mount out from the frame any more than the billet hard mount i have on it. i will try that first thing tonight but will need to find longer bolts to fit washers? behind the silencer flange.
  5. never tried the fmfs but even with the sheares I had to rotate the clutch side carb maybe 2-4 degrees and it runs great. but 45 degrees looks a little radical and from what i know about carbs they might not even work at that angle. the intakes I have on this set up have no reed spacers and are billet one piece with cross over inside from wicked I think.
  6. Maybe my searching is not as good as some on this site but I have looked through this site and the general internet but I cannot find if anyone is running T-5 pipes with TM34 mikuni carbs. I have a serious fit problem on at least the clutch side carb contacting the pipe to the point where I will not be able to install the carb(unless I rotate it almost 45 degrees). The stator side carb installs ok with a close fit but nothing too bad. I will upload pic tonight. Has anyone ever run Mikuni TM-34 with T5 Pipes? Lets see some pictures if you have. The TM-34 were a close fit with my shearer SB IF pipes but they worked with no fit problems.
  7. I have a set of T-5 or a set of T-6 with silencers to trade for shearer pipes. I would like the Shearers to be in good condition, do not need to be show quality. The T-5 and T-6 pipes are in good shape but not show quality. I can try and get a pic of the pipes up tonight. Let me know who has any so we start talking details
  8. Stupid question but will the chain that is included fit the +6 swing arm (been burned before)? I wll buy it if it does. Pm sent
  9. WOW that was fast I will take it. I will PM you.
  10. Required: I am looking for a set of Mikuni TM38 flat slide carbs Optional: Throttle cable for the TM38’s that fits a banshee Pod filters (5 degree angle fit perfered) Billet bowls
  11. https://www.google.com/search?q=252area+code&ie=UTF-8&oe=UTF-8&hl=en&client=safari NC looks like based on phone number area code
  12. Thanks I will look into those. No books available to buy?
  13. They are on the tm designworks website for 39.95 with free shipping
  14. I am interested in a good 2 stroke theory book. Either a title / author to one or especially a book that someone would be willing to sell me. I am interested in anything from beginner to advance. Does not need to be in new like condition just needs to be readable. Not so interested in internet sites and links at this point.
  15. Didn't you just sell a whole t5 setup? I got t6 for 270
  16. I need some exhaust clamps that will fit Tommoey pipes Thanks, Mike
  17. Are the terrain tracks any good or you got a set you need to get rid of???
  18. pm on hangers and clamps
  19. Since these do not seem to be very availble, how about ANY pair of paddle tires that can handle a little dirt and stones without ripping apart? Looking to fit on stock rear rim size. 20 or 22 inch diameter that can handle a 421 or a 465,not for official racing just fun.
  20. Say it isn't so.... No one has one of these tires they want to get rid of??
  21. This is f'in chaos..... I love it. How much for tm's? What size they be too?
