04_blu_shee
Everything posted by 04_blu_shee
  1. Im running 15-40 on a dune port 22x11x8 10 paddle Extreme 72RO 1-5 dunnable override on the 300' sand, im 215lbs...you should seariously be able to pull more gear on that 4mill Bud.
  2. I finally got my headpipe from CPI...ITS A MIRICLE and the best part is...no damage, third time is the charm but no more dealings with CPI, Im done with that SHIT!!!
  3. Get some PWK's and I also would say 70ish HP go +4 on timing and case match the bottom end to your jugs be worth a few more ponys, throw some good reeds in there too and let er eat!!!
  4. Here is mine...a Sunpro works and looks great
  5. tdod101... any aftermarket reed will help increase performance over the oem B.S. like the thread says you build a motor with all parts porting etc. to complement each other to squeeze every bit of H.P. and TQ out of the power plant, and yes you can go backwards adding the wrong parts to your motor...
  6. LOL ya im with ya on that one troytech...But i also say Engine Ice like WINDYCITYJOHN400 said, ive been racing my Banshee hard for well since it was new in 04 and never had it boil over...
  7. Go with the Hot Rods product...you cant go wrong, you build it right, bottom end most important you will be happy
  8. YES... Jeff is the Man he will stand behind all products he sells and will do an excellant job on the PR perspective as well.
  9. IMO from what I have seen, if you have a Drag ported motor you will benefit from the 4's over the 3's. The Dyno will prove it but as far as a mild build you can get away with the 3's having just as good performance. The price of the 4's are way cheaper than the 3's so that is a no brainer...Im running the 3's cause ive had them for bout 5yrs so when the pettles go so will the whole Reed package then I will call Jeff @ F.A.S.T and buy my 4's
  10. Might have some electonic probs I agree...I would run a mix of VP110 and 91 ethanol free fuel 1:1 ratio with that comp. and also a 32:1 fuel oil mix...Why did your builder say to run such a oil lean mix 40:1?
  11. X2 on the spacer plate... have it built right
  12. yamahaman sounds like you need a big o hug....Get real Dude
  13. Damn sheerider11 you got it...I can totally see that happening, Motorhead LMFAO. yamahaman126 chill out you are being the retard.
  14. Nightmare im gonna give ya a "Ya Buddy" on that clairifacation on the "Timing Belt"....I think I forgot to install that 4yrs. ago on my last build Huhhh
  15. Are you FUCKIN kidding me!!!!Looks like a 5 yr. old was in there choppin away. WOW Really worst ive seen. Dude you should get a very expensive prize for getting screwed on these...
  16. X2... what troyzstang said. Do it right now or pay more after a catastofic failer.
  17. Junk cast pistons, your lucky you didnt scatter a piston skirt....I also say bore hone forged pistons and weld that crank!
  18. I couldnt get them to slide out and yes I do know they come out the clutch side, had em out before.
  19. I have my cases and all parts cleaned getting ready to put my motor back together, Do you guys put case sealer on the Crank Seals or not. And a second question when I took my shift forks off of the shafts I had to tap on the plug on the case half to get the shafts out. I just tapped the plug back in place, will it leak now or will it still have a good seal.
  20. I believe the RD motor will have taller tranny gears, aimed more toward street/hiway speeds
  21. LOL....Low Budget!!!
  22. I had some like that I took my Dremel knocked the high spots down...good to go
  23. Exactly what trickcarbine said the moon is the limit on building a Banshee...so far this winter ive got $1500 in mine and I'm tearing it down and putting it back together myself money really is no object with these things but when you WFO a built Banshee, nothing compairs to it. Have fun with yours.
  24. Good to know Finch I'll go a differant route next time But Im not doggin Jeff at all, he has been a great guy to deal with I havent had any disputs with him or F.A.S.T. Racing. He is a personable guy on the phone every time Ive talked to him. That Ashley from CPI...To The Curb she goes, with my dealing with her.
