m671054
    4
Everything posted by m671054
  1. Willing to bet a stock head might have 2 much compression. but it worth a try
  2. Wonder what kinda pricing you could get on a group buy?
  3. The static compression is way to high. Even for race gas. Better cut some domes so you can actually run boost
  4. Anyone else think that 21cc domes plus 12lbs of boost on pump gas seems like a bad idea?
  5. I had asked cam about some porting for a turbo. He said he has not messed around much with turbo stuff. I bet its either the dual expansion chambers causing lag or the porting.
  6. Do elaborate on the site sponsors wiring harness with problems. What was it?
  7. When you swapped stators you swap pick ups also?
  8. packard uses a mnv-1kp so you can run a 5/32od dump tube. It comes 1/8 npt but it wont fit a lectron so they get turned down. Forget the size right now. If you could use the 1/8 pipe it would be easier. Just a thought.
  9. What size port for the pj. Would be be nice if you could screw in the clippard without having to turn it down and recut threads
  10. It might be possible. ive had a 4mill cheetah that we turned into a 10mill. it used non normal parts and had lots of machine work done. look on cp webstie and compare dimensions from a 4-10 cylinder. pay attention to overall cyl height first.
  11. Lectrons have sizes cast into the body on both halves. they usually dont measure out exactly the same.
  12. Question about all this internet tv. how much of a data plan do you need for your net usage? who has the best price for internet only? my brother inlaw is looking to drop tv and go to something like this just not sure what net package to get
  13. you realize how many cranks would turn into garbage with every average joe trying to rebuild them. you could never buy a used crank again. As much as i would love to buy a set its not a good idea to make these for the masses
  14. Up to the top
  15. Good stuff. come up with a rear seat mount for building subframes,and a rear master cyl mount. would like to see a rear caliper mount using a right front 450 caliper also.
  16. Wonder if there will be a carb shootout at redline now. seems to be the local product proving grounds.
  17. You have to move outside the boundries of public transportation to avoid them. this is how they invade and destroy the nicer parts of cities. that and section 8 landlords ruin cities. As soon as 1 moves in you better act fast cause more are on the way
  18. That motor didnt sell last tine it was up. maybe if he through in a set of sniper pipes for it he could make a deal.
  19. wasnt your triple one of his old motors?
  20. Bump
  21. realisticly 7mm. Technically you could probably do 14 but would need spacer welded to tops of cylinders and new sleeves for the setup. not cost effective and wouldnt perform as well as a aftermarket cylinder. this would not be an off the shelf type thing. doubt many builders would even do it nowadays. but you asked.you can do a 14mm wampus if your trying to look stock but anyone with half a clue would know whats up
  22. Hows it attach to the frame?
