04zSpittinKlotz
Everything posted by 04zSpittinKlotz
  1. thank you sheerider!!!! by the 3rd page nobody noticed that from his first post!!! i was about to check you fools!
  2. Yours made it to the hill?
  3. My buddys 97 or 98 has red fenders, try looking that up. Also a period or something in between sentences usually helps.
  4. couldnt ya buy the 04-05 white and red plastics and then just find the graphics you want?
  5. Stfu squeeter
  6. Fugg it, I'm in
  7. Ahhh, truth. Yea, that makes sense.
  8. Call fox and tell em you want a set with an unfinished upper body. Prob get en a lil cheaper too...!
  9. that.... is a good idea!!!!
  10. I agree with zilla, that upper a arm is definitely bent,
  11. Well said blubber! Fuckin pansy has had everything handed to him and will respect nothing!... Sorry to hear matt! Beat that shit man! From what ive heard/seen is having a strong mentality is a lot to getting through all that crap they put ya through! You should have no problem with that! Get better man!
  12. does it do it when ya pop a wheelie?
  13. Odds are if its going out, it has a leak... you need to find the leak, fix whatever it is and then your good to go
  14. WHAT...THE.....FUCK........ he give you flat top pistons to run too ?
  15. Oh yea, just noticed,.. its TOE angle! just sayin
  16. im actually with ya possum, heres the link girls http://www.lsracing.com/img/Guide_21.pdf
  17. Ffs, undo the tie rods, straighten the bars, and measure either from the inside lip of the rims or center of tire tread(depending the type of tires) you should end up with 1/4" less in the front. Toe set! P.s. keep checking measurements and bars several times.
  18. Whatta bout the WP bearings
  19. There ya go ^.... x2
  20. Honestly im not sure on that one... i never really thought to check them after riding
  21. Im 155ish and liked them on the soft side, I think I ran 55psi... dont remember exactly. with your weight, Id say just start around 75 and go from there. You will have to play with them a bit to find the ride you like. The air shocks are progressive so you dont really have to worry about bottoming out. (unless you run them with no air.. also the pressure will change with temp differences so check them kind of often. GREAT SHOCKS !!!
  22. ah, ok, i got the muffler bearings if you need those also. no, jk i know what you are talking about. the little rubber pads/bumpers. someone was talking about then a while ago and i think found em online for like 3$ a piece
  23. you mean the bearings? i got those if ya need em
