Buffalo-Banshee
Everything posted by Buffalo-Banshee
  1. What would be a good starting point to run 35mm airstrikers on my stock 350 with t5s vf2s +4 timing? I know they are overkill for my setup now but i have future plans for a 485 pv motor. I just want to ride the bike a bit before i pull the motor for my winter build.
  2. I think most of the 9 grand was labor rates......
  3. I found that 90 psi has worked the best for me but I weigh 225. You just need to bring your pump and mess with them.
  4. Yea OEM Yamaha was over 50 bucks for 12 new! I found some on flea bay for 20 shipped but being a banshee forum I figured people had them laying around.
  5. I'm looking for 12 OEM dust caps for stock a arms I need them for an aftermarket a arm Install
  6. Are the pads rotor and line stll for sale?
  7. I'm looking g for a nice set of front shocks elka, ohlins,axis , or fox floats. Let me know what you have Thanks Jeremy
  8. You got the banshee bug now you need to feed it money!
  9. Well during assembly of rebuilding my motor i noticed that the lower case mounting hole where the kick start slides in rounded out and will not completely kick the motor over full due to how sloppy it fits in the case. i heard its not a good idea to miss match a lower from a nother banshee to my non wacked upper case. Is this true? can i try a lower or should i just buy a matching case set?
  10. great so this crank is scrap metal then huh. Does anybody buy these for parts ?
  11. Well with the winter approaching and my banshee not running right i decided to pull the motor out do a rebuild. Upon dissambly i noticed that the o rings on middle bearings of the hot rod crank were split and falling of the crank when i split the case! so i figure this is where the the prolbem lies with the motor! How can i fix this or does this meen the crank is shot? or can this be repaired for a reasonable price? Thanks Jeremy
  12. Im working on getting some funds together!
  13. Couldn't you have waited another month when i have money to spend to part your bike out! I may want some stuff still
  14. Is the +4 swing arm still forsale?
  15. Ok im looking for 10" rims thanks
  16. What size are the rear rims in the pic?
  17. I have a set of stock rims and a pair of rear itp gray 9 inch rims looking to trade for a pair of 10 inch rear rims! let me know what you have !
  18. Looking for a set or hiper beadlock rims or a website that sells them cheap! thanks Jeremy
  19. Ill take the prodesign shifter. Pm my your paypal info
