ban99shee
Everything posted by ban99shee
  1. I have few sets of Yamaha wheel/tires for sale. All prices are best offer and do not include shipping. Local pick-up in Wisconsin Dells, WI is also welcome. I will ship UPS ground and only charge the actual cost. I have plenty more pictures if intersted 1)Cheng Shin 18" C826 Ice tires on Douglas 8x8 Blue label polished rims. They have a stud pattern for oval but can be changed very easy by removing or adding a few studs. They were used for about 10 races total. The 1 inch studs were sharpend and not used since. The studs are very sharp and are still tall, they were never on pavement or gravel. The tires are in excellent shape with no damaged or missing lugs. The wheels are also in great condition. They have some minor scuffs but no gouges or dents. They sat for a couple years so they need a little polishing if your picky about bling. But it's perfect for the tires. You want nice hard tires for ice racing. SOLD 2) Cheng Shin 18" C826 Ice tires on Douglas 8x8 blue label polished rims(not in pictures but exactly the same as the used set listed/pictured). These are also studded(1 inch) and are ready to use. The tires, rims and studs are all BRAND NEW! The studs have never touched the ice! The rims have some VERY minor scuffs from being moved around. They also could use a little polish. $150 3)Sand Star 20x11x10 rear paddle tires on Douglas Red label rims. The tires and wheels are in excellent condition! The paddles still have small rubber casting pieces that would wear off right away. The rims have some very minor scuffs from being loaded next to another bike on a trailer. They only have a couple tanks of total use since new. Overall they are in excellent shape. $100 4)Rear ITP beadlocks with ITP Holeshot SX tires. Rimes are 8x8, tires 18x10x8. The tires were barely used but one does have a plug. The outer rings for the bead locks have some gravle/sand in them. They will need to be removed and cleaned. The bolts for the beadlocks are a little rusty but nothing is stripped. SOLD 5)Maxxis front Razr Cross tires with ITP Pro Baja black 10x5 rims. The tires are in great shape but show a little wear on the center lugs. The rims have some minor scuffs in the anodizing only...they have no dents or gouges. Overall they are in excellent shape! $100
  2. I have a few Banshee parts for sale. Please reply with any questions or if you would like more pictures. I have many more pics than what is posted. All parts would be packaged extremely well to ensure there condition.thanks!! 1)A set of Keihin 34mm PJ carbs. They are both complete with jets and airfilters. They look and work excellent. They have no damage or wear. One bowl has the center nut welded on-see pictures. The filters are in decent shape but still work fine. SOLD 2)Toomey T-5 chrome pipes with silencers. The pipes have some very small dings and a little minor rust. They look good when on the bike though. The silencers have some very minor dings. SOLD 3)A set of V-Force 3 reeds. These are complete and in excellent condition. They were barely used and look like new. One cage was damaged and was repaired-see pictures. They still work like new. SOLD 4)+4 adjustable rear axle. It's in good condition and straight. SOLD 5)Ohlins rear shock. The shocks is very clean and in excellent shape. It was used very little and shows almost no signs of use. It looks and works like new! SOLD 6)LSR +2 +1 front a-arms. The arms are in good condition with no dents or bends. One ball joint is brand new..the other are in good shape. Also includes longer tie-rods w/ends. The powercoating has worn off in some areas but otherwise the parts are in great shape. SOLD 7)Stock OEM rear axle. Good condition and straight. $40+actual shipping. 8)Oem ported+bored cylinders. They have mid/high range porting. Not sure who did the work though. They had perfect compression but show some very minor wear grooves from the rings. SOLD 9)Hot Rods +4mm crankshaft. Trued and welded. Has about 50 hours of total use. Its' complete minus the wrist pin bearings...unless I find them before the sale. SOLD 10)Complete Ricky Stator stator and bracket. Parts are in excellent shape. The stator was barely used..the wires and plugs are like new. $65 shipped(mag is SOLD) 11)Bottom end cases...includes top and bottom. Both parts are in great shape with no repairs or major damage. The gasket surfaces are perfect. They have no stripped threads. They just need a little cleaning on the outside. SOLD 12)Complete transmission(stock oem) with gears, shafts, forks shiftstar hardware and etc. Everything in the tranny besides the clutch and kick-start gears is included. SOLD 13)Hinson HD Billet clutch basket with buttons. Parts are excellent shape with little use. SOLD 14)Pro-Design Cool Head. Complete with all o-rings and head studs. Also includes 2 sets of domes(18cc+19CC small bore). All the parts are in great condition. Nothing is damaged or worn. SOLD 15)Pro-Design alloy intakes w/alloy boost bottle and reed spacers. The intakes have flanges for 33-35mm carbs. The parts are very clean and in excellent shape. SOLD ]
  3. ban99shee
    banshee axle
    I have a stock length oem in great condition. No damage and is true. $55 shipped
  4. I have a LSR, stock length, chrome round house swinger. It's in great shape with no damage or repairs. It uses all the stock linkage and has skid plate mounts. The skid plate mounts can easily be cut off if not wanted. There are no guides or carrier. You can get a brand new alloy carrier with bearings for $100 on ebay. It uses almost any name brand round carrier and stock chain guides. $225 shipped
  5. I upgraded from 28s to 35 pwks. I already have aluminum manifolds with flanges for 28s. I thought I could just change out the rubber flanges to fit the 35s. Will the Mikuni 30-34mm flanges work with the 35s? I would like to just get new rubber flages to save money if possible.
  6. Buy a good helmet. And a neck brace if you can afford one. Cheng Chin C826 rear tires(like the other guys said) seem to be the hot set-up for the rears. Magic Racing has them for $55 each w/free shipping. Maxxis Razors are not bad either(rear) and are also really cheap. I'm running Pure Sport Bandits on the front. They are kinda hard to find but show up here and there. You want the front tires to be taller than the rear. Just about everyone seems to use Kold Kutter studs. Run 1" studs or they will just come out and ruin your tires. Using rubber tire glue from RC cars holds them in better than rubber cement from my recent test. Being that you are only 14..I imagine your body weight is kinda light. I would look at getting a -2 swingarm to help with traction. A swaybar is basically a must too. Try a lot of gear ratios...it's cheap and you can find huge gains. Keep your studs off cement, rocks and etc to keep them sharp. Ask other guys at your local track with banshees what works for them. Make sure your front end is alinged. Try different air pressures in the tires. Toomey T5 pipes are about the same as P.C. Except the toomeys can be found easier and for less $. There are tons of used pipes on HQ all the time. Pro Curcuits are good pipes too for a mostly stock engine. Check the race rules/classes first and see what class would suit you best. Check what mods they allow in that class for a banshee. It might just be pipes and airbox mods. Running stock pipes vs aftermarket is night and a day difference. So after safety gear, tires, studs...get some pipes, jets and maybe some clamp on k&n airfilters.
  7. I have a 1999 Banshee. I was wondering if the spindles(steering knuckles) from a 2009 YFZ450R will work? These from a fuel injected bike. Has anyone ever tried this? I have +2 a-arms and it's lowered a couple inches. I want to convert the spindles, brakes and etc. thanks!
  8. I'm in the Dells and was looking at racing down in Fort Atkinson. Does CWIRA run ovals too?
  9. I agree ! He is a nice guy and is easy to work with. Excellent buyer !
  10. the pipes are sold...thanks
  11. Lets do it! Please package them with care. I'm sending you a pm with more info. thanks Carbs are sold !!!
  12. Maybe...got some pics? thanks
  13. I have a pair of brand new 33mm PWKs. Never been mounted or seen fuel. I just bought these and decided to go bigger. They are complete with jets and original packaging. $270 plus shipping. Payments with paypal must be sent as a gift or extra fees apply. I'm in Wi Dells and local pick-up is welcome.
  14. I have a set of Shearer small bore inframe chrome pipes and silencers. The parts are in great condition. One pipe has a tiny tiny dent and a small rub mark from vibrating on a cylinder. Otherwise the parts are in excellent shape with no damage or repairs. I just bought these from another HQ member and decided to go another route on my Banshee. They would be packaged extremely well to ensure there condition. $400 plus actual shipping cost. Payments with paypal must be a gift or extra fees apply. I'm in Wi Dells and local pick-up is also welcome.
  15. Yes I still have them. Local pick-up or shipping is fine. thanks
  16. Hello, Can you send pics of the inframe pipes to [email protected] ? Can you also send a detailed description of age, any flaws, repairs or damage? thanks for your time.
  17. the engine is.....SOLD...SOLD...SOLD
  18. Yes, it comes with the carbs that were ran on the engine originally. They are complete, clean and jetted.
  19. YES the engine is still for sale...the thread will be updated if sold. I used PT mid rev, PT high revs and Toomey T5 pipes. I liked the PT mids the best for trail riding. thanks
  20. Great seller! Excellent packaging and parts!!! Very good guy to work with. thanks again for the pipes and help!
  21. I bought a lowering kit and kill switch from him. Good parts and comunication.
  22. I have 20+ years experience with powersports and have worked at dealers in the past. I buy and sell machines and parts all the time. I know junk when I see it and it and would never sell anything bad to my knowledge. I stand behind what I sell and I'm very easy to work with if you were not 100% satisfied. I plan on being on this site for awhile too..I have no reason to upset anyone. I'm also co-owner a photo studio in Wisconsin Dells. It's called Vintage Photos. I wouldn't offer that info to people I plan on pissing off.
