007banshee
Everything posted by 007banshee
  1. Price lowered to$ 60 for all three.
  2. These are still available.
  3. Hey guys I have a set of plastic for sale. Front and rear race cut black both for$ 75+shipping. Throwing in the tank cover free. No cracks all bolt holes are intact. Can get picture's via text. Pm your cell. Will seperate for$ 30each. Thanks
  4. Why don't they just not stamp it. Ill try lapping it. Thanks!
  5. Hey guys putting my motor together and bought a new woodruff key.from the dealership and it had what looked to be a triangle stamped into it which caused one side to have a tiny bump not allowing it to sit properly on the crank so i bought another, with the same result. Any suggestions? Thanks!
  6. Ha nevermind 66÷23=2.86.......
  7. Ok how did you figure that out for future reference. Thanks! Nick
  8. Wondering what my gearing is. 23 on primary gear and 66 on clutch, more top end or low end?
  9. Thanks for the info guys! Never thought too much into squish,... no the motor isn't together still workin on the bottom end. Holidays working a starting a new job next week has consumed a lot.of.my time along with having to wait for parts from the dealer to come in. Nick
  10. Then measure the thickness of the solder with a dial indicator? So after you do a top end(im doing a full rebuild and am going by the manual)you would check for squish? And im still not sure what exactly that's measuring, faulty rod bearings? Crank issues?
  11. Nice. I just got done talkin to jeff at FAST and im.going to get the star,modded shaft and EZ spring when i order my pro lites. Would i be safe adjusting my shaft now(the claws ) check for proper shifting and seal the cases or wait for the new parts.
  12. Bend it at a 90* so it gets squished on the edge of the plug hole? What if your squish is out of spec?
  13. Cant find the thread for it if anyone can point me in the right direction,checked the technical pinned section and searched. Also if i run a mattoon basket can i use stock inner hub and pp? What kits sell 8 plate's? Thanks!
  14. Sorry but im new to building. What is squish? How is it measured and how do you obtain the.correct clearance on say building a stock shee motor. Don't mean to hyjack. Nick
  15. Do the stainless bolts need to be torqued differently? If so what is the difference.
  16. Good thing i found this,in th's process of rebuilding my engine just about have the bottom.end done.just have to adjust tranny and seal her up. So you guys suggest a billet impelled and.mulls gear? How much would these run and wheres a good place to get impellers. Sorry for hyjackin this thread btw.
  17. Bought one from baranhophr, disregard this post.
  18. I am looking for a kick lever. Anyone have one please let me know! Nick
  19. Ill try to add pics. Have an Android tho. Some don't have any grooves some do. Ill try the file. Baskets are a little pricey that's why i was wondering...thanks guys
  20. Took my clutch off to put in a new KG kit. I have heard some.people talk about grooving. Mine has little humps they are not huge but you can feel them what kind of issues can this cause if any. It is the original clutch off an 02 so it was ready for a refresh. Will i be ok running this basket?
  21. 007banshee
    Frame WTB
    Good point just any frame.
  22. 007banshee
    Frame WTB
    Traverse City, Mi.
  23. 007banshee
    Frame WTB
    Anyone have a good straight frame they wanna sell???
  24. Are all primary drive gears the same? Checked all the part numbers and they're the same with no options. Manual says that you need to check the number on the gear to make sure.it has the proper lashes to work with the clutch gear. Any insight would be apprciated before i fork over$ 40 to the dealer. Thanks!
  25. Nice! Well looks like ill have to undo a bunch of stuff and apply anti seize lol. Yea the rotor bolts don't work. Either do the ones that came on my hubs( bought used) they are the rounded allen's. They hit the caliper when going around, should i find bolts or rotors. The wife has an 06 and her rotor bolts are flat and looks like the rotor is recessed where the bolt goes?
