thats clears things up for me .I've been dialing in my project Blaster wrong the plug ..The plug is clean as new but it is pepie down low ... I thought it was lean on the top end throttle range.. went bought richer jets on my way right now to get leaner jets .. i was pulling my hair on that one
x2 check reeds and cages ,,check to see that your needle clip did not break (mine was doing the same thing) check for air leaks on that side of the motor ..
is there any fuel in the bowls..? What size are your carbs? WHats your set-up? if your carbs are too big size wise then it wont flow fuel correctly. The bigger carbs have less air speed coming through the barrel of the carb and are hard to start and/or a pain in the butt to get to idle..
