stpltn
Everything posted by stpltn
  1. I've read through this a couple times and have seen it was mentioned a little. Primary ratio gears. Some said they were confused if the higher or lower gear spun the basket faster or slower. I thought the higher the gear the faster the basket spins. So if you have an engine with 2.86 gear and have a good baseline setup. Swap it out to a 2.54 or 2.36 or what ever is the next size higher. It would in turn spin the basket faster. So wouldnt a higher basket speed speed would need stiffer base pressure so the clutch doesn't slip as much to where you can get enough grip to spin the back tire to then in turn spin the lockup. If you have a higher primary gear then wouldn't you need less weight as the basket speed is faster yet?
  2. Hell yeah!! Sent from my iPhone using Tapatalk
  3. Says in the post
  4. So you purchased the porting templates from O'Connor?
  5. Guess I'm in the clear. Not a nerd. C average in school. Don't touch kids except holding the hands of my own. Don't have a basement and parents don't live within 1000miles from me. Happily married after 10yrs. Sent from my iPhone using Tapatalk
  6. Hahaha. I don't play very much. Very rarely if any at all. This is the first time in ALONG time. PS4 is mainly Netflix and amazon. Maybe the occasional game. Mostly just movies. Expensive movie player. Sent from my iPhone using Tapatalk
  7. GTFO with the gaming on PC. Every time I think of online gaming with pc is the South Park World of Warcraft episode. Hahahaha Sent from my iPhone using Tapatalk
  8. Anyone play online? Not anything like world of warcraft shit. PS4. Star Wars Battlefront, The Division... I haven't played in awhile and games are pretty fun. Not any good. But who gives a shit.. Sent from my iPhone using Tapatalk
  9. Per CP website Sent from my iPhone using Tapatalk
  10. So your not willing to give them dome specs out??? I'll send you some "Slap yo Mama" seasoning. Sent from my iPhone using Tapatalk
  11. stpltn
    Work stand.
  12. stpltn
    Work stand.
  13. stpltn
    Work stand.
    I bought plastic folding sawhorses from lowes. Lift the bike by the wheelie bar and set it on one horse then picked up front end and later on other. I'm 6'3" and worked perfect
  14. Take a piece of soft solder. Mold it to the port you've finished. Transfer it to thick card stock. Transfer it to some thin metal and you now have a template to duplicate off of.
  15. CPI 78mm Cheetah DM Piston for 68mm stroke 10566M07800
  16. Is this Shark Tank?
  17. I use a Crankshop carb. Has calvins bigger bowl on it. Uses all mikuni jets. 54mm t slide
  18. What about the motor free porting? When it's at TDC and the piston skirt doesn't cover up the ex port and the intake charge comes through the reeds, intake, and out the ex port.
  19. Hahaha. I was thinking the same thing. Everyone wondering about people going to Canada and I'm wondering how many "legal immigrants" are going back to Mexico
  20. Is that the gearing you used for a stock cyl drag port or your dm or dmx you run?
  21. Are the screws the same length?
  22. http://bimotion.se/
  23. Turn the shirt inside out. It will be correct then
  24. If you were to turn the shirt where the neck is facing left then the flag would be correct. So it's in the correct position
