cce12
Everything posted by cce12
  1. I went from 1.6s to 1.4s using the info in this thread. I was using 2.68 and tried everything i could to slow the arms down and couldn't get it done. Now I am using 2.86 and i think its alot easier to tune than 2.68 by far. I went from a 2.23 with 2.68 prim to 2.11 with the 2.86 and pulled that gear easy by tuning the clutch. Track time/seat and your time slips will tell you what direction you're going.
  2. Hey bryan what is angel running against? Everything looks equal to 1000ft in the last 300ft there's a big difference in the mph... bike?
  3. That's really fast for some stock cylinders! !!
  4. nice!
  5. 80 lbs of spring psi with 4 springs?! Do you mean 80 lbs per spring? How are you getting that #??
  6. Post some pics of the carbs..
  7. This is what i use. http://www.everything2stroke.com/content/40-Gearing-Calculator-Banshee
  8. If you are going to keep on gas 19x8x10 a.r sd23 would work well also.
  9. The 18" tires is killing your top end...
  10. I don't think your running out of gear with 18/38,that gearing is gd for 100+ in the 1/8.Something else is going on with your motor setup. A 19 sprocket would be a lot for 421 cub on gas..
  11. Tim@Titan...
  12. WTF!!! Just when i was starting to get this down! Bryan thanks for starting the thread and sharing. Your info was helpful to all us beginners in the clutch tuning world.
  13. cce12
    jj@a honda sprocket
    got one.
  14. cce12
    jj@a honda sprocket
    My bad.. jj@a Honda sprocket hub..
  15. Pm me if u have one. Thx.
  16. I'll throw my 2 cents out there about spring pressure and what worked for me. After I got back from the track I took out the springs that were in it and used those springs for my baseline. For example say that all 6 came out to 280 lbs. then I took the box of springs and kept taking 10% off the 280lbs to about 260lbs to 240lbs etc. Eventually my 60' started to improve and I knew exactly what my spring pressure was. I've seen 2 springs that look identical but they are 5lbs off now if you multiply that by the number of springs you are using its a huge difference.
  17. cce12
    Clutch basket
    I am looking for a stock/billet clutch basket that is in gd shape and doesn't have a lot of play.. send me a PM and let me know what you got
  18. i have a +10 swing arm pc black that i would trade for stock crank in GOOD condition with gd bearing and no play..
  19. 35mm carrier sold tires sold
  20. New bike/ engine combo and running some those ### at your first event! Great job to you and you team!!
  21. lowering links sold.. AR tires pending.
  22. i have a 35mm for $45 shipped
  23. crank sold..
  24. chrome 40 rear sprocket $60 shipped http://s1172.beta.photobucket.com/user/cce1975/media/A642672F-1FDC-4783-B901-34C8DC02D60A-23775-0000065562FE47E9_zps694581ff.jpg.html?sort=3&o=0
