cce12
2 Followers
Recent Profile Visitors
cce12's Achievements
  1. I went from 1.6s to 1.4s using the info in this thread. I was using 2.68 and tried everything i could to slow the arms down and couldn't get it done. Now I am using 2.86 and i think its alot easier to tune than 2.68 by far. I went from a 2.23 with 2.68 prim to 2.11 with the 2.86 and pulled that gear easy by tuning the clutch. Track time/seat and your time slips will tell you what direction you're going.
  2. Hey bryan what is angel running against? Everything looks equal to 1000ft in the last 300ft there's a big difference in the mph... bike?
  3. That's really fast for some stock cylinders! !!
  4. nice!
  5. 80 lbs of spring psi with 4 springs?! Do you mean 80 lbs per spring? How are you getting that #??
  6. Post some pics of the carbs..
  7. This is what i use. http://www.everything2stroke.com/content/40-Gearing-Calculator-Banshee
  8. If you are going to keep on gas 19x8x10 a.r sd23 would work well also.
  9. The 18" tires is killing your top end...
  10. I don't think your running out of gear with 18/38,that gearing is gd for 100+ in the 1/8.Something else is going on with your motor setup. A 19 sprocket would be a lot for 421 cub on gas..
  11. Tim@Titan...
  12. WTF!!! Just when i was starting to get this down! Bryan thanks for starting the thread and sharing. Your info was helpful to all us beginners in the clutch tuning world.
  13. cce12
    jj@a honda sprocket
    got one.
  14. cce12
    jj@a honda sprocket
    My bad.. jj@a Honda sprocket hub..
  15. Pm me if u have one. Thx.
