Joejr915
Everything posted by Joejr915
  1. my elvation is about 1500 above sea level
  2. i got a stock banshee with no porting and aftermarket reeds with stock carbs. dmc pipes and k&n pods and +4 timimg. my gas mixture is 32:1 what jets should i put in. And if i mix 40:1 what jets should i put in also.
  3. Joejr915
    pistons
    I found a set of pro lites already thanks for looking for me
  4. Joejr915
    shear pipes
    I'm looking set of shear drag pipes sb sf out of frames? Used please thanks pm me
  5. I got a 465 motor with a set of 41mm pwk carbs of it. What jetting would u recommend I'm looking for jets and air screw and needle settings? Any ideas would help. Thanks
  6. Joejr915
    pistons
    I'm looking a set 64mm pistons for set banshee. Used
  7. i got both just need to know which one to put on.
  8. what pipes would u guys run on a 465 ? sb or bb
  9. is it better to have stock ignition or a pvl on a 10 mil? what would u set it at ?
  10. is it better to have stock ignition or a pvl on a 10 mil? what would u set it at ?
  11. Joejr915
    straight cuts
    im looking for set of straight cuts stock ratio?
  12. Yea its ported
  13. Just bought another banshee need some help with this one. Its mods are reeds,+4 timing,DMC exhaust, ported. Gas mixed to 32:1 and the jets are 30p and 250mains. My elevation is about 1500. I'm not sure on needle platoon or airscrew setting. Its got s little hesitate low to mid throttle. Need help on jetting it?
  14. The bar is about 5 ft long
  15. I got marvins in the front and it a 3 bar wheelie bar with a gokart tire on the back. The bar is about 6in off the gound.
  16. i need help tuning my chassis? i drag race and i have a +6 swingarm and im 230lb rider. also im running a srtut in the rear. im hitting the wheeliebar too hard so hard that the whole banshee comes off the ground. as soon as i get it out about 15ft it rides awseome i ride the bar most of the way down the track. any ideas thanks
  17. Looking for 34 or 35 carbs flatsides with cable Drag pipes small flange big bores Rear brake caliper
  18. Looking a direct drive lockup with cover. I prefer used. Thanks
  19. Joejr915
    parts wanted
    Looking for braided brake lines and terry cable thumb throttle and a cable for 39pwks carbs. Sent me a pm
  20. Got a chain slider off this man took onlyy 3 days to get it. Great seller thanks man
  21. i keep looking for a drag chain that is strong and light and non o ring.
  22. i looking for a shock about 8---8.25in long i have a strut now and dont like it. anyone know where get something that short.
  23. im looking for a good set of chromly set of a arms. pm if u got anything
