Joejr915
Everything posted by Joejr915
  1. Mine a 521 I run 28:1 also and these are my last plugs I checked 2weeks ago at the races Sent from my XT1585 using Tapatalk
  2. I run 55p 180m cel needle 39pwks
  3. Joejr915
    Billet crank
    Pm me if there is one out there thanls
  4. Joejr915
    Billet crank
    I'm looking for a 10mil 115rod billet crank. Preferably a good used one
  5. Nope I tried to get a replacement
  6. Do you still have any hubs still for the axle. m671054. If so Im interested in it for parts
  7. I have rad that looks very similar to that one. It has the same wheel hubs,nut on end of axle and Avery similar sprocket hub. It was a good axle till one of mine wheel hub stripped
  8. It look like a R.A.D axle to me
  9. Parts came better than described. Awesome seller and fast shipping e
  10. How much if you were to sell the bowls?
  11. Mine somehow cracked and sucked the center reed keeper into the motor.
  12. Yes I had problems Sent from my SM-G900V using Tapatalk
  13. Home*
  14. Let me look when I get he I may have 1 laying around. I think it just needs pinch bolts
  15. ^I'm curious also
  16. Can someone let me what size bolt are on the hinson spring loaded basket? Or even what size allen head to use? To remove the. I have one that got buggered up from a idler gear coming loose
  17. Joejr915
    alky
    What's a good alky to run? Whats a good ratio I mix to? What a good ratio to purge with?
  18. Joejr915
    tubes
    K thanks. Kinda hard to throw away a set of 12x10s
  19. Joejr915
    tubes
    Has anyone ever put tube in there tires while drag racing? If so have you ever tear a tube? I have a set of tires that someone put screws the bead cause they were spinning on the rim and I to the screws out now and they leak. Any ideas
  20. Japan bearing I had him put maxloads put on
