banshee 268
Everything posted by banshee 268
  1. anyone make me a reasonable offer
  2. not totally sure but I think there small bore.how would I be able to tell.never owned out of frames before.the chamber is the same size as my shears that I have now and there small bore.oh there is two small spots on both pipes that I had welded because they had cracks
  3. http://i834.photobucket.com/albums/zz266/bissco/IMG_20140218_150255_985.jpg
  4. I have them on photobucket but for some reason I cant post the link on here to them
  5. I cant seem to get pics to show up on here
  6. I have a nice set of trinity one out each side drag pipes with silencers.no mounting brackets with pipes I just made brackets that connected them to my foot pegs.will sell for 300.00 obo.
  7. Yamaha taper
  8. im looking for some front lonestar front hubs with bolt pattern 4/144 honda
  9. hi im looking for the dust caps for my lonestar front hubs.they have 3 bolts that hold them on and I can only seem to find the ones with two bolts.if anyone has a set don't care what style they are please let me asap....thanks
  10. those are stock bolt pattern.i need them to be Honda 4-110
  11. im looking for rear banshee hubs with the Honda bolt pattern 4-110.....please any help
  12. any help where to find them
  13. hi im looking for rear banshee hubs with Honda bolt patten 4-110
  14. can anyone tell me if it is possible to change the main bearing that the clutch basket shaft goes through with out splitting the motor.it seems that the thin gasket like material in the basket is coming out also.the bearing has very little play in it and would like to just replace it.any help would be great.
  15. where can i find the neon plastics
  16. not sure where you can find them.they onlytell you how to mount it not how to set it.where in mass are you if your not to far i can help you out if you would like.just let me know.my name is rob
  17. power ground racing
  18. thats a very good bar also.i know you seen my set up this winter also.pgr bar works well also and is alot cheaper too.i was pitted across from you thi past winter
  19. the mf44 are good but not ama allowed.big thing to watch for if ama is involved.you should use 1" anyways no matter what tire you use.you need them to go through the canvess of the tire,thats what holds them in.
  20. lonestar is the best but hard to find.im running a pgr racing bar on mine.
  21. i only use the stock shock and have a lowering link in the rear.i have the 450 arms on mine and it sits perfect.the big factor in it is the sway bar in the front.im running offset front rims so im 50 inches wide in the front.
  22. hey just to let you know i wont be going racing over there with you any time soon its 6 hrs from me.to far for just a race
  23. sounds good to me let me know thanks
  24. give me the info where from mass so its not that close to us.we have to plan for it.do you guys have a schedual let me know
