jasons
Everything posted by jasons
  1. damn i have been looking for some 33's
  2. its not my bike i just saw it on CL here locally. The HP seems low for that big of a engine to me.
  3. http://norfolk.craigslist.org/bar/3126569980.html SERIOUS INQUIRIES ONLY. Email with the subject "Banshee", so I can sort through Spam. Email goes straight to my cell phone. Please leave a phone number, and I will call you back. Normally, I can call you within 15 minutes. If you want to trade your boat for my bike, please leave a description of the boat in the email. I am looking for something fairly specific. Please read the bottom of this post to see what kind of boat I'm looking for. Sorry for being so long-winded. I want to answer as many questions you may have before you ask them. Thanks for looking, Chris. Engine 535cc CP Industries Cheetah Cylinder (powervalved) 73mm Wiseco Pistons Crankworks 10mm Billet Stroker Crank (64mm stroke) Cases trenched and port matched to cylinder and crank TZ Bearing on PTO side of crank Max Load Bearing on flywheel side of crank Direct Drive clutch lockout with clear Lexan cover Chariot Performance polished stator cover with bearing support V-Force III, 250r reeds Billet 250r intakes Pingel Dual-feed, high flow petcock Keihin 39mm PWK carbs, setup for gas K&N style 13" open air filters CPI Racing Big Bore, Inframe, drag exhaust with silencers Custom cut removable head domes (15:1 compression) Cylinders have FULL drag port, done by Andy at M&M ATV in Oklahoma ProDesign Billet, adjustable timing plate (set at +7 degrees) ProDesign Billet, High-Flo water pump Mattoon Machine Billet Water Pump Cover Stock 6-speed transmission with Shifter Star mod Dyno'd at 127hp, 68ft/lbs MUST RUN MINIMUM 110 OCTANE Always ran Klotz Super Techniplate @ 36:1 with Sonoco 110 Only used Castrol GTX, ATF-Type F Transmission Fluid Suspension Stellar +3" Wide +1" Forward, Fully adjustable, Chromoly A-Arms, built by Tim Wible at Stellar Machine And Performance in Arizona Stellar +3" Chromoly Tie Rods, built by Tim Wible Stellar +8" Chromoly, gusseted, round tube, Honda carrier Swingarm, built by Tim Wible Elka Piggyback Reservoir, Dual-Rate Spring, adjustable front shocks Stock Yamaha Banshee rear shock, revalved for +8" Swingarm, 190lb rider Yamaha YFZ-450R Dual piston front calipers and pads Body And Controls 2001 Yamaha Banshee frame, lightened All metal either powdercoated Translucent Blue with chrome base, or Bengal Silver Maier Silver Plastics Front plastic race cut Seat recovered with faux snake skin Duncan Racing billet front bumper Pro-Taper S/E ATV Mid-Rise Handlebars ASV C5 Breakaway Clutch Lever ASV C5 Breakaway Front Brake Lever Streamline Stainless Braided throttle cable Streamline Stainless Braided Clutch cable Streamline Stainless Braided rear brake hose Tether Shut-Off ModQuad Billet Ignition/Handlebar Clamp ModQuad Billet Rear Brake Reservoir ModQuad Billet fuel cap ODI Clamp-On grips Moose Racing Billet adjustable thumb throttle BOSS Billet HD Sprocket Hub ModQuad 4-Bearing rear axle housing ITP polished 9x9 rear wheels with Maxxis iRazr tires. One of them I cut every other row of tread off. Haven't messed with the other one yet. Douglas Black Label 10x9 rear wheels with AMS Aerospeed 10-Paddle tires. The paddles don't look too good, but still work. Stock 10x5 front wheels with brand new AMS tires Cascade Slammer Billet shifter Entire electrical system was relocated to behind the radiator. You cannot see the coil, regulator, or CDI. Currently has 17/39 tooth sprockets on it EK X-Ring Racing Chain, rated at 8,700psi I'm sure there is plenty more that I'm leaving out. I built this quad from the ground up, and have over $20,000 and about 1,000 man hours tied up in it. Everything on this bike is quality name brand parts. I built this bike to drag race up hills. It's low, wide, long, and extremely fast. I have ridden this bike several times in the woods and trails, and have brought it to Busco Beach. It is scary fast in the woods, but very fun at the same time, and handles like a dream. It literally rides like a Cadillac. The suspension is plush, and handles hard bumps quite well. I have ran it a couple times before on the asphalt 1/8 mile track in Hertford, NC. This bike runs neck and neck with lightly modified Suzuki GSX-1300R Hyabusa Streetbikes. This bike is garage kept. It is a little dusty from sitting, but I will wash it before anyone comes to look. All of the aluminum on this bike has been sanded down and polished to a mirror finish. It has been ridden and cleaned several times, therefore the aluminum doesn't shine like it used to. You could easily bring the shine back with some elbow grease. I don't have the time to shine it back up, or I would do it. I would recommend that whoever buys this, is somewhat mechanically inclined. It is a very high horsepower racing quad that tends to shake bolts loose every now and then. It currently has summer (75-90 degree weather) jetting in it. Winter time will require a jet change in the carbs. If you don't jet it for the winter, it will run lean and blow up the motor. Technically, you should re-jet if you ride during any drastic temperature chance. Cold weather needs more fuel. Willing To Barter For..... I am looking for a TURN KEY, RELIABLE fishing boat on a road worthy trailer, capable of fishing the Chesapeake Light Tower, and all over the Chesapeake Bay.. I would prefer a 21-24ft Walkaround, but might consider a center console. I want a quality deep V hull, with preferably a Chevy-Mercruiser Inboard/Outboard. The only outboards that I will consider are Yamaha or Mercury, on a gill bracket. No transom mounted outboards please. I would like it to have a hardtop, but I can deal with a soft top. Not really interested in a bimini top, unless the boat makes up for it. I would like a full enclosure, but not a must. I would prefer no bottom paint at all, but will consider.. I DO NOT want anything branded by Bayliner. I just don't like them, sorry. I do not want any runabouts, cuddy cabins without a walkaround, bass boats, speed boats, etc. Whatever it is, it must be worth around $9,500, or you throw in cash to compensate. NO project boats please. I've had plenty of them in the past, and don't want another one. I have well over $20,000 tied up in this four wheeler, so please don't low ball me. I know what it is worth, and I'm taking a major loss. Will Also Accept Cash..... If you want to buy instead of trade, I will only take 100% cash, or a certified check from your bank. I am asking $9,500, but I am a little flexible on the price. I will not take payments, and I will not even consider checks, nor will I ship it anywhere. You must pick it up. I won't sell to low-ballers, because I really don't want to get rid of it. Thanks again for looking..... Manufacturers were not mandated to produce titles for Off-Road Vehicles until 2004. Therefore I do not have a title, but will draw up a "Bill Of Sale" and have it notarized. This bike will be sold/traded "As-Is", with No Warranty. Absolutely NO JOY RIDES. Serious inquiries only. If you bring cash and/or a boat to trade, I will let you ride it. I have a legal place to ride. Here's a couple of videos and pictures of the bike. http://youtu.be/QCtLrA0WpFM
  4. and he is running toomey t6 pipes.
  5. the reeds look like they have a quite a few tiny holes in them from the pics.
  6. Evening Bump with more pics
  7. I am posting up my 30mm OKO carbs for sale or Trade. They are basically the same carb as a 28mm pwk and uses all the same internals etc. just want to go to a bigger carb. I am looking for 33mm pwk with filters will trade plus a little cash maybe. Send pics of what you have. The K&N filter are like new have a little pipe rub on 1 filter. Will clean them before i ship. Great carbs never had a issue tuning them just need to go bigger. Will include throttle cable if necessary. vent hoses are also all new this is an old pic. ill get pics of the filters later. Asking 150 gifted and shipped.
  8. Pull the pin and let her rip........
  9. will you sell just the rears thats all i need. let me know a shipped price to 23438. or trade my entire sand tire set fr your entire set. Thanks
  10. aren't those rs stators 185 brand new in the box never bolted on? used is used IMO. Also whats a re-active carbon fiber reed. is that just the brand?
  11. pm me a price if i pic up locally.
  12. dont have what your looking for in trade but how much will you sell those for shipped to 23438?
  13. I take it you didnt ask for pics before you left. what a dick to waste 2 hours of your time.
  14. no rush to sell. so ill pass on 2k. its just sitting in the garage covered. i travel to much to ride.
  15. Morning Bump ttt
  16. are the lens actual glass or plastic?
  17. I have up for sale or trade is a 1997 4mm Yamaha Banshee.The bike has been totally rebuilt. Way to much to list but I'll try my best to fill in all the details. Engine doesn't even have 1 gallon of fuel through. Bike is in Virginia. I have a lot so if you need pics i have on them my phone. Can deliver within reasonable distance for a fee and when I am home. I have many other pics just pm me with a number and i can text them. Quad was setup for the sand then i moved from California to VA no need for this anymore. jayzx750 and jrmarquez.702 and bigred350x can vouch for Titan racing engines. PM me with any questions. AND NO I AM NOT PARTING IT OUT YET!!!!!!!!!!!!!!!! Engine: New freshly built 4mm dune ported engine By Titan Racing bought jrmarquez.702 FMF Fatty pipes with Brand new silencers Internals include: Hotrod +4mm Crank Trued and welded with Maxload bearings, Bearings are new cranks really low hours bought from jrmarquez.702 Fresh Bore with 65.50mm Weisco forged pistons New Chariot racing head with custom 4mm domes (No Spacer Plate Required) Billet Intake Boyseen reeds 30mm Carbs K&N Pod Style Filters Vortex Billet Clutch Basket Modded Shift Star from FAST Racing Modded shift shaft with easy spring from FAST Racing Lighten Flywheel Electrical: 200w Stator with DC Conversion HID lighting LED Tail Light Custom Battery box w/ new battery from JDS Customs Controls: New Black ASV levers Chrome anti-vibe steering stem New Renthal Handle Bars Suspension: Front Works Dual Rate shocks w/ reservoirs Rear Custom Axis Shock fresh (rebuilt by Axis) no hours +2+1 Extended A-Arms w/ stainless steel brake lines +2 JLEngineering Extended Round-House Swingarm with Lonestar Carrier Chassis: Black Powder coated Titled Frame IMS Foot Pegs- Best in the ATV Industry by which all others are measured G-Force extended axle either +2 or +4, you choose currently +4 Also have a Alloyboltz kit. started to change out the bolts but havent finished I am sure I missed a few things but the list goes on. I am willing to trade for a Fully Loaded Jon Boat w/ 9.9hp engine of equal value or let me know what you got and you can add cash on your end. Also looking for a .410 shotgun for my son (youth model), 12ga shotgun semi-auto and AR-15 for myself. Let me know what you have and we can go from there. Cash on your end of course unless you have 4k dollars worth of guns Asking price for the Banshee is $3800 dollars. Email with any questions and I also have alot of pictures. Email me with your number and I can text more pics and video
  18. I have some Sand Skate II on rims. looking to sale or trade for rear knobbies
  19. Whats the purpose of the spiral design on that 2nd set of domes? Seems like a great spot for detonation.
  20. Are they for the Fatties or SST's. the PC II have 2 different part numbers.
  21. What?
