crazycanuck
Everything posted by crazycanuck
  1. I forgot to tell u earlier when you PM"d me, I had to use a bunch of washers to move them out from the head on the stator side. and a couple on the silencers too.. As Cam said welcome to shearers. That Cub will LOVE those pipes tho. nice choise
  2. what cam mod does everyone do ? i think ive read it before tho.... advances the timing?? lol i donno
  3. OK so... I sweated my balls off all day workin on this POS and this is what I ended up with 172 main 48 pilot dirk bike needle, middle clip. 2 turns out I fuckin hate 4 strokes so i donno, it sounds like a LOUD wet fart and pulls hard. The Fuel customs intake was a pain in the anus lol...... but turned out ok. I ended up not using the air box as we usualy ride in the same conditions. I did notice the low end bog right from idle, Is this the problem that the quick shot solves ?? AND i took it for a few good rides and the fan never once kicked in.... WOW WAS MY LEG HOT IN SHORTS
  4. what is this quickshot u speak of??
  5. Contact F.A.S.T racing. they will hook you up with EVERYTHING. mine came with everything you need to instal
  6. Did you keep the air box?, would u happen to have any pictures of yuour setup?
  7. Shit. Don't forget a duel Pingal with 1/4 inch or bigger fuel lines
  8. Take ur gas cap apart and gut all that check valve shit. Then drill out the hole as big as u can. As long as u can slide the little hose back on. Also what carbs u running ?? I would suggest billet bowls. I did all that with mine and don't even think twice about runnin out. Hope this helps
  9. Hey guys sorry if this is in the wrong spot, but i need some help. I am working on my buddies 07 yfz 450 and am installing the following -sparks racing full system -fuel customs intake and filter i got a new needle and a bunch of jets. i was just wondering what a good starting point is for jetting?? im @ 2300ft OH and where the F$#K is the the air adjust screw???????
  10. is it puking out the overflow? what do the plugs look like? does it rip? or feel lazy? or pop and surge ??
  11. Im runnin 168 mains @ 2300ft with dgh needles in the middle clip, 48 pilots and 1.5 turns out on air screw +8 timing on vp c-12
  12. Have a good time Jeff!
  13. Sorry. was just gonna 'chime' in.. Mine is goin back to wcr. Im alomost 100% positive i got on of the old extremes. before thy found the problems. just figured urs could be one of the same ones.
  14. Im running a Stellar +8 and couldnt be happier. I found it not that bad to dune once i got used to it.
  15. I remember reading this before, Its either for a speedo or a tach on the RZ 350 street bike. It was just still in the yamaha casts and there was no reason to design a new factory case without it.
  16. Yes you will need a stock drum and also don't forget to remove the springs that are inbetween the shift forks. And if it was me. I would change the forks. Just cuz there cheap and you never know how that override was treated before you had it
  17. Yes you will need a stock drum and also don't forget to remove the springs that are inbetween the shift forks. And if it was me. I would change the forks. Just cuz there cheap and you never know how that override was treated before you had it
  18. If you have a play bike then go with the +8. i have one and i really dont find it too long. just takes some gettin used to.
  19. Love my shearer's on my unported cub.. pull to the moon, They look and sound amazing. the fit is kinda tricky but with a few washers on the stator side and they fit perfect. I had CPI"s on a stock cylinder bike and i fuckin hated them. they look ugly, hard to get at the plugs and i burnt my legs all the time.. they came on a little sooner than the shearers but oh well, the small amount of low end they got me wasnt worth the other complaints i had. I myself want a set of unsilenced oof's but i think i dune too much and they might not stand up to that type of riding.
  20. ya man, are you able to make it there on those days?
  21. Got mine from Jeff @ F.A.S.T.
  22. top
  23. Our group is headin down JUNE 11th. Riding 12,13,14,15 and drivin home on the 16th . Is anyone around ???? you local guys should come out for a ride!!!
  24. You will love a 1-5 N down, i have one and it is a BLAST to ride
