Wheelie Ripper
Everything posted by Wheelie Ripper
  1. if they were the toomey pipes I would be all over that shit
  2. Pay me 50 and I'll come pick them up and take them off your hands hahah
  3. probably time for a clutch. Either broken disc, clutch is smoked, or something is wrong with internal adjuster (unlikely)
  4. 99 Banshee, located in central NJ. brand new 4mm long rod stroker motor, paul turner pipes, cool head with 20cc domes, billet timing plate, +5 timing, pro flo adapter, pro taper bars, brand new wiseco pistons. 1800
  5. Tire Kicker.
  6. Ill switch the pipes if you switch the 1 and the 2 and make it 2100
  7. Up for sale is my 99 banshee. Just did a 4mm setup, long rod and the crank is trued and welded, brand new wiseco pistons, paul turner cool head 20cc domes, billet timing plate set at +5, paul turner pipes and silencers, pro flo adapter for air filter, adjustable rear axle, pro taper bars, twist throttle. Bike is located in central new jersey 08559 zip code. Asking 2350 or best offer, don't be shy.
  8. Hey meng, do you still have the crank for the bangshee?
  9. hey meng, will these work on my bangshee with da toomey pipes?
  10. This guy is all balled up and full of excuses hahahah. See you at the top of the coal piles
  11. Selling my 99 Banshee. Has brand new 4mm long rod crank, 795 pistons .040 over, cool head 20cc domes, billet timing plate at +5, paul turner mid range pipes, pro-flo adapter with foam filter, twist throttle, max rev cdi, heavy duty clutch springs, pro-taper bars, extended axle, twist throttle. Also included is an extra set of uncut rear plastics. Located in central New Jersey 08557. Asking 2300
  12. also will take best offer
  13. <a href="http://s811.photobucket.com/albums/zz40/wheelieriper/?action=view&current=102_4020.jpg" target="_blank"><img src="http://i811.photobucket.com/albums/zz40/wheelieriper/102_4020.jpg" border="0" alt="Photobucket"></a> http://i811.photobucket.com/albums/zz40/wheelieriper/102_4020.jpg
  14. I have a set of stock carbs with TORS, throttle cable and fuel lines. Asking 90 dollars shipped priority. [img=http://i811.photobucket.com/albums/zz40/wheelieriper/102_4020.jpg]
