ISSUES
Everything posted by ISSUES
  1. It wounln't take much to seal up the stock stator cover to put oil in it. Be thinking of it do it ,might go ahead and do it now.
  2. I have been told it will remove paint off plastic with out damage, so it should remove paint of metal.
  3. Cut the front and back and toss them, If you are worried about get muddy and dirty don't ride or sell it
  4. x2 that
  5. The differance is psi and size. The size is determined by wether its an older import or a newer one.
  6. If you look at your picture you posted in the upper left hand side the part # is wrong, You got #2472 you need #2473.
  7. You heard correct, should be 0.015"-0.020".
  8. Ordered and received my impeller and gear today very impressive. Thanks again Brandon the very well made and top notch products.
  9. Go ahead and do the compression test, It will give a good lead on what might be wrong. Make sure the fuel is off and both plugs are out and hold the throttle pinned open.
  10. Do a compression test on ,it might be just a blown head gasket and it is just burning coolant.
  11. Thank, Looks like I will hit up Brandon for a impeller and gear.
  12. Hey 87shee, have you rode since you installed the impeller, If so any temp drops or any probems with it? I need a pump for my shee I might just pick one of these up in stead of pro-design from FAST.
  13. Yes you can, Here is another topic on it. http://bansheehq.com/forums/index.php?showtopic=121545
  14. Sounds like pilot jet is to small try going a size lager.
  15. Yea you can block it off with like a steel plug and clamp on, Just make sure your carbs are synced.
  16. Very nice
  17. Call Jeff at FAST
  18. Instant power hair and grease drain opener it's in a black bottle at homedepot
  19. I think he mean 2nd and 3rd click horribley, 4th and 5th work.
  20. Your not going to get stuff like CP said at autozone, You can get some stuff real cheap at harbor freight don't know how well the stuff works from there.
  21. Sweet thanks for the tip and how to remove the coating, Gotta pick some of that drain cleaner up.
  22. Nice, been wanting to do that to mine. How long did you let it sit on there?
  23. Pics or GTFO
