So I have an '03 shee, bone stock, (got some toomey tr-6's in a box, kinda jumpstarted this whole project) with probably less than 100 hrs. on her. Always ran great, then I let it sit for about a year, (drained carbs) and the last few rides it acted a little funny. So I decided to tear down the carbs, clean everything, clean the air filter, fresh fuel, fresh plugs, etc.
Now before I cleaned the carbs, my issues were as follows:
1. Low, unstable idle
2. Loading up when holding any throttle position above 1/4 in neutral. Bogging and stalling usually followed.
3. (excessively) erratic throttle under load at low to mid throttle.
4. Almost normal operation under load above 3/4 throttle.
5. Most recently, running on left cyl. only.
After cleaning, both cylinders are running smoothly, idle is appropriately higher rpm and very stable (after some adjustments to idle screw and air-fuel screw). Sounds great, right? Almost.. Somehow my choke is out of sync, as the engine idles and revs normally (in neutral, not under load) only at 1/2 choke. No choke will destabilize idle and stall the bike.
I've cleaned the carbs 2x, can't imagine there's any debris, so it must be a tuning issue, but after extensive fiddling with idle and air-fuel screws, I'm not making any progress. Any ideas?
Keep in mind this is all pre-mod. Stock motor in all respects, stock pipes, etc.
Thanks in advance for your help.
(sorry to be so wordy)
- Rob
