sheerider1026
    4
Everything posted by sheerider1026
  1. Whole crank shifted. Both welds got chewed. Webbing cracked around pin. Possible seperation started? Lots of heat being generated as well. Either way. The clip grooves look perfect. When u Leave the clips out. This is what happens.
  2. Yep. The cases will Chew into the crank as well. You guys never seen a rubber seal wear a groove in a steel crank before? Jeez. It's obvious the clips were left out. Is Tyson to blame? From what I'm seeing id say "you bet your ass he is".
  3. So is this a before or after pic?
  4. Pics worth 1000 words.
  5. $10k. So what's another 400 bones gonna hurt?
  6. I run amsoil dominator @ 50:1. Nasty is correct in his statements. A lot of factors can come into play is the point here.
  7. I couldn't get my cub to run on 100ll. No matter the tune it wouldn't rev out right. All I can tell you is that switching to 93 pump cured the problem
  8. Moose stator. Same setup that racetech uses. Hope that helps. Should be 250w
  9. Wiseco all the way. Been great pistons for me over the years. A good machinist will bore the cylinder to the piston
  10. I am at 650ft. I ran 19cc domes on 91 pump. Just a cleanup port. T5's. 65mm bore. +5 on the plate. I will admit it was a tad fat on the topend. But that's another story.
  11. Can't fix stupid
  12. What brand? Pic?
  13. I'd be interested in clutch basket
  14. Axle showed up yesterday. Haven't opened the box yet. Looks packed decent. Thanks
  15. Meh. Yea. If that's the case I would agree
  16. ^^this^^
  17. The old jugs looked like the sleeve was pretty thin anyway.
