1989 Yamaha Banshee
LRD Ported cylinders
welded and trued crank
Cool Head
30 mm OKO carbs
LRD adjustable pipes and silencers
Lightened flywheel
Adjustable stator plate
Billet water pump impeller
Hinson Clutch basket
New clutch
+4 swing arm (stock one available)
New front tires
All brake lines are steel braided hose
It is in PERFECT running condition and runs great. There is only one very small crack in the rear plastics. No slop in any suspension components. $3100 FIRM Located in central Oklahoma
405-924-0119
I also have Skat Trak 8 paddle tripple buffed Extremes and front Dune Runners that can go with it for $300
I had a modified plate, and the best I could tell with my measurements was 4 to 5 degrees. That was comparing it to the cheap Ricky Stator plate.Also, my plate was slotted about as far as you could go with out breaking through.
They have definitely been ported just not to big. They look similar to mine but hard to tell w/o sitting them side to side. You can easily see the transfer ports are done and it looks like they went easy on the port timing.Hard to tell in the pics though.
