prochargednova
    89 Banshee LRD Porting,Pipes,and Silencers,30mm OKO's,Rad Valve,etc.
prochargednova's Achievements
  1. 1989 Yamaha Banshee LRD Ported cylinders welded and trued crank Cool Head 30 mm OKO carbs LRD adjustable pipes and silencers Lightened flywheel Adjustable stator plate Billet water pump impeller Hinson Clutch basket New clutch +4 swing arm (stock one available) New front tires All brake lines are steel braided hose It is in PERFECT running condition and runs great. There is only one very small crack in the rear plastics. No slop in any suspension components. $3100 FIRM Located in central Oklahoma 405-924-0119 I also have Skat Trak 8 paddle tripple buffed Extremes and front Dune Runners that can go with it for $300
  2. I had a modified plate, and the best I could tell with my measurements was 4 to 5 degrees. That was comparing it to the cheap Ricky Stator plate.Also, my plate was slotted about as far as you could go with out breaking through.
  3. Red and grey 89 shee with a +4
  4. They have definitely been ported just not to big. They look similar to mine but hard to tell w/o sitting them side to side. You can easily see the transfer ports are done and it looks like they went easy on the port timing.Hard to tell in the pics though.
  5. Are you talking about the porting? I have a set of cylinders ported by LRD and work very well.
  6. 20-11-10 Sand Stars on T9's. I will throw in a little $ for a good set.
  7. I have a set of 20-11-10 ITP Sand Stars on T9 wheels if interested. Perfect shape.
  8. Don't think I have enough power to pull them. Thanks for the reply.
  9. Are they Haulers or Extremes? And, please pm me price and shipping est. to Yukon, OK 73099
  10. I weigh around 220. But almost all the racing I do is on flats not hills.
  11. Do you think they would be to much? Trail ported, LRDs, 30mm Kehin, +4 swinger, timing advance,etc. 50-55 hp bike
  12. Looking for 9 paddle Haulers or Extremes. Have a set of 20-10-10 Sidewinder or 20-10-10 Sand Stars on T9 ITP's to do some trading.
  13. Looking for 21" 9 paddle haulers or extremes.
  14. Please send pics of swing arm to [email protected] Very interested Thanks, Clint
