davem06
1 Follower
Recent Profile Visitors
1,894 profile views
davem06's Achievements
  1. Im looking to buy a set of CPI inframe pipes, anyone got a set for sale???
  2. Ill be there Dave, We booked our hotel in Hart so we will both be there on Sat. morning and Sunday. I just hope I can get it tuned in by then. Im using that heat wrap stuff so the problem is solved I guess until I ride it and if it doesnt work then ill have to use the other methods you guys shared with me. Thanks for the help guys, Dave
  3. Im using pro design intakes. They arent like touching really hard but are real real close. They are the big filters but they arent straight they go on a band after the rubber where you clamp it.
  4. Recently I have gotten a set of 34 mm pj's and the big K&N pods. Now I can mount them but they are against the exhaust. Does anyone know what I can do? I was thinking of some heat resistant material of some sort but would like to hear what everyone else is doing. Thanks Dave
  5. My name is Dave and I live in southern ontario. I ride around here and at silver lake. Looking forward to the april silver lake trip.
  6. Ill be there on the 28th and 29th....see you guys there.
  7. I have almost an identical set up , I have a dune port and pods but everything else the same and Im running 380 main jets on stock carbs.
  8. I will talk to my dad about this, Id love to go, plus I got the new parts in this weekend.
  9. Both guys had their packages in my michigan for the weekend I went, thanks very much guys :biggrin:
  10. Im from chatham, ontario. I used RB racing in ovid, michigan for porting, really good guy. really cheap to
  11. anyone??????
  12. I took a real good listen today without the stator cover on, and it sounds like its coming from both sides. Im tearing it down tommorow. Is there anything I should check before I split the cases?? Can someone give me a list?
  13. Its wierd, it was about 6 hours after ridding it in the dunes it started, I just re ringed it before that trip. So im not sure. Ive heard the crank bearing or something in the bottom end is to blame. Im ready to split the cases and just check everything.
  14. I may end up just tearing it up, its turning into a big headache for me, I don't like hearing it, and I don't really want to ride and have to it damage the case or whatever and blow up massively. And if its not good after that, then I will keep trying to solve the problem I guess.
  15. Did you take the flywheel off to repair this?
