Bill
Everything posted by Bill
  1. Did you check e-bay,they sell the kit alot cheaper.
  2. After you sand them down use a propane torch and lightly melt the edge,dont hold the flame on one spot to long tho.
  3. Just bought both with paypal,thanks alot! :thumbsup:
  4. Just bought the radiator,thanks! :thumbsup:
  5. Dude that's A steal for fifteen hundo!The first thing I would do is get some pipes. You said you like to drag race so get some CPI pipes,you can change the pipes yourself just remember to re-jet the carbs.Theres A bunch of mods you can do just how much you willing to spend?
  6. Id get an aftermarket head with 20cc domes and some v-force reeds,have you elliminated the tors yet?
  7. You haft to buy A weld on kit to use a-arms.
  8. Yep just unplug the little black box under the tank.
  9. Cascade innovations sells A bad ass extended thumb throttle lever.
  10. I had one of those pop out on me twice!The first two times I just hammered it in there,then I got sick of buying them and jb welded the bitch in there.Its all good now.
  11. Looks great! :thumbsup:
  12. Id take your engine builders advice.
  13. Let the bidding begin. :cool:
  14. Bad ass front end!
  15. Yea he's pointing at the swingarm bolt,the slider wraps around the swingarm and dust cap.
  16. Id say so.
  17. Sweet banshee,shee probly ripps pretty good.
  18. Will the v-force reeds still work for duel carbs since they were ported for A 2 into 1 intake?
  19. Do you have A good radiator for sale?
  20. Well then the correct way to do it would be to weld it,but I would split the cases to do that. :shrug:
  21. Pull the clutch arm and try some epoxy.
  22. It almost looks like someone drilled A hole there for some stupid reason. I can't see the chain slapping A perfect hole there. your gonna haft to figure out some way to plug it perminently with out binding the clutch arm.
  23. Before you go spiting the cases you should check the shifter shaft. Get A Clymers manual and it will tell you how to adjust it. It may not even be A bent shifting fork.
  24. Hell yea,post some pics when you get it. Congrats!
  25. If everything is good then I would'nt worry about it.You don't want it real loose anyways.
