#1 Drain Coolent
#2 Drain Trans Oil
#3 Remove Clutch Cover
#4 On the back remove the curclip off of the white plastic gear.
#5 Remove the watercover impeller cover and puill it out
Please replace the Gasket that is behind the cover with a new gasket and also put a new gasket on the clutch cover please.
Also replace the o-ring that you will see on the small Joint 1 ( dumb name ) you will see it you cannot miss it. Replace it for good measure because it gets its ass kicked when you pull the cover off-on. I think it will run you 1.24 for the oring. The Gasket for the waterpump cover is 9 dollars and the clutch cover gasket is 19.
Please see the provided picture
Thanks,
Ronnie
