LeadBoots
Everything posted by LeadBoots
  1. no the carbs are not stripped. the new carb caps will thread but they do not tighten up all the way. like when u r putting them on there is play in it but its not that much . they still work i was just wondering if they were ment to be like that.
  2. my shee will still run fine but the caps dont tighten up. is that normal for the kits. and also i put the new idle screaws in. and the right side carbs screaw goes in father then the left side . i dont get it . it will still idle fine.
  3. i bought the tors elimanation kit. The caps that came with it are a bit to big is this normal or what? they r for stock carbs.
  4. ya i think that twist throttle is alot better
  5. is it easy to drill and tap the hole for the new idle screw? i bought the kit off ebay will it have direction or should i take it to a shop.
  6. thanks for the info guys
  7. it was a brand new clutch maybe used for like 30 rides. the clutch always worked great never had a problem. is it possable for the clutch plates to stick together?
  8. anyone have an idea on whats wrong.
  9. ok here is whats happening the last night i had my shee out the clutch worked fine. but now it doesnt work . when u pull the clutch lever there is tension. but then nothing else happens . i adjusted it lots of times but it still doesnt work. could the clutch be sticking together it sat for about 4 months. if this makes sence to any of u the help would be great.
  10. is there a different between a twist throttle cable and a thumb throttle cable?
  11. whats the best twist throttle tors removal kit?
  12. well there used to be but the cops are assholes. out near vienna (about 15 mins southeast of aylme) they had great trails there.i have to mainly ride on the road but mainly back roads.but ive heard that vienna has the best trails for atvs and dirtbikes in southwestern ontario.the old trian track were alot of fun to ride on. but if ya get caught on them u get a fine.
  13. aylmer ontario here 30 mins from london
  14. my throttle cable was fine to the last time i used it but now it does not work.
  15. i had my shee that bad before too . i took it up north in canada to go moose hunting. we were goin down the trail then it was just mud. i tried to giver but i didnt make it. there was about a 1/2 inch coating of mud covering my whole bike. it was very bad.
  16. how old is ur throttle cable maybe you need a new one
  17. i know most of u guys are from the states and i dont know if you guys have TSC stores. they are a farm store they sell DOT approved tires im pretty sure.
  18. when the engine is warm can ya kick start it.
  19. will it fit in a 96 Banshee
  20. how do i adjust the slides im not very good with carbs.
  21. yes i know its wrong. but i dont no how to change it. i will clean the carbs.
  22. i got it running it will start but it still takes alot of kicks. but when it starts it just revs up like crazy and wont idle down. what would that be the carbs sticking?
  23. i really havent worked on carbs before so im not quite sure on how to do everything. i will look at the mains and pilots in the morning. yes the choke tube is hooked up and no i didnt take the carbs apart. and i didnt look at the screen but the petcock is working great. gas is getting to to carbs.
