als660r
Everything posted by als660r
  1. witch $200 swingarm did you get? how do you like it?
  2. YES I advise take it easy till you learn how the sand is (drops, razerbacks) also I don't like the big event weekends too much RANGER DRAMA. Rear sand tires are a must,I would not buy front for first trip. BE prepared to make plans to back, you will be addicted. Check out WAYNOKA.COM it has the all the rules and rates.
  3. hot knife cuts better than a cold knife. also makes smoother edges the stress mark seem to come back after the plastics flex, only long term fix is paint with a good paint made for plastic or cut them.
  4. step # 1 with a torch heat knife #2 use heated knife to cut at stress marks #3 stress mark are gone
  5. ls power sports had that rear grab bar with lights hanging on there wall thursday.
  6. LOL
  7. I plan to be in the south campground from the 7 to the 11.
  8. if it pulling right is it worse with front tires on ground or wheeling ? if worse with tires on ground may be a caster problem check a arms and mounts real close. If worse when wheeling check for loose swingarm bushings or bad axle carrier bearings also if stock carrier make sure it is adjusted right (axle square with frame) First check all tire presure and sizes
  9. +1 or it said link not here
  10. thanks for the link I wondered what happened
  11. If you mean draggon track there classes were not real quad freadly 50cc kids 110cc kids 350cc over 16 open over 16 if only a few quads showed up they would ran more than 1 class at a time.
  12. I like free.
  13. I thought SAND JAM is in june and SAND FEAST is in sept
  14. [] also isnt spraying foam illegal to do. so is dualframeing, welding chains to the top the frame, spools in the rearend , double tires but if the winners do it everyone has to. yes pinto wagons or sedans make good compac class cars. all it take to win is a lot of MONEY and luck
  15. be sure and watch the freestlye show at LS powersports
  16. Its not a twostroke problem as a no battery problem. I have seen led whips hooked up to the taillight wireing I THINK it works better hooked to small battery.
  17. I voted for pic. Those two seem to take good running quads and "FIX" them into piles of scrap.
  18. no a longer rod does not mean longer stock . longer rod mean the crank will not turn unlees you change piston wrist pin height
  19. Have a good birthday
  20. You must have a early yfz before the oil mod
  21. cat the other white meat
  22. E85 = 85% alcohol jet it up or you be lean.
