Snopczynski
    2
  1. FYI if you guys want jb weld to hold really well on aluminum, het it up with a torch and then put the jb weld on it. It kind of runs into the pourice pores in the aluminum and makes it seal/hold a little better.
  2. So what do you guys usually do as a fix to put it back in and make it stay there? I was thinking of roughing it up a little and putting some jb weld on it?
  3. I cant be sure of that, it may take a 64.5mm bore job to do it. There is no exact way of telling until you get it done.
  4. Did you not get the pm I sent you back? Your looking at $150.00 US dollars shipped.
  5. The pipe clamps and tail light + bracket are gone. FYI: The front end (A-arms on my bike) are $125 for all four links, or $35.00 each. These arms will come with just the zerks, and the urethane bushings. I have to keep my bolts, steel bushings, and caps for my new front end. The front end that is off the bike and is seperated out will be $95.00 for all 4 links, or $26.00 per link. This front end is in good shape, but has a little more finish wear on it. This one will come with the factory urethane bushings, caps, and bolts. There are 2 grease zerks missing. Both front ends have tight links. The works shocks are standard travel shocks.
  6. Here is what I have guys. Feel free to PM me or post if you have questions. I have pictures on the link below. If you guys get multiple things it may be priced different so you can get a package deal. and shipping will vary depending on what you get, and where you live. Not all this stuff is in perfect shape, but I will make sure that you know what kind of shape something is in if you are interested in anything in particular. Feel free to post or pm me with any questions. You can email me also. Here are the pictures, and the list below has been updated. There are 4 pages of pictures. Snopczynski Parts Pics Link *click here* 2 Full sets of banshee stock a-arms. Both sets are silver, and I will split them up if you need a certain arm. The arms are used, but nothing is loose. 1 of the sets is currently on my bike. For 4 arms your looking at $125.00! For each arm it would $35.00! 1 set of Works front shocks in Dual rate. Black spring and a white spring on the shock. Sprung for 180-200Lbs rider. Shocks are used and in good shape. These shocks are currently on my bike. I rode with them when I was a 165Lbs, to the fat ass 194 Lbs I am now. $200.00 Right and left spindles used and in good shape. $40.00 Right and left Stainless tie rods with tie rod end joints. $30.00 A set of complete front hubs with bearings and brake discs that are used. $40.00 A set of stock jugs at 64mm bore that need a bore job, and the bottom of the transfer ports have been cleaned up on them. I can have Dan Wade at Patriot Racing bore em before I send them. $100 without the boring done. $225.00 with the boring done. A set of stock reed cages with what look to be older boyeseen reeds on them, they are used. $25.00 A set of stock intake boots with a stock boost bottle, they are used. $20.00 A set of used graydon nerf bars with black webbing, has all hardware. $50.00 Stock radiator caps that are used. $3.00 A used cascade front swingarm chain slider in black. $5.00 A red lonestar axle nut (used). $25.00 A used rear brake lever. $15.00 A used set of 1989 front brake calipers with flexible and hard lines. $45.00 A used DG front bumper. $25.00 A used Cascade quick release flag mount. $10.00 A couple sets of stock banshee swingarm chain adjusters, along with some of the long adjuster bolts. Some brand new and some used. $5-$10 depending on which one A used White brothers boost bottle. $5.00 A used and polished front brake resevoir cap. $10.00 A used stock headlight/kill switch. $10.00 A used set of cascade rear fender support brackets. $5.00 A used set of blue radiator and tank plastics. $45.00 A used aluminum bar clamp with key switch and light mounts. $15.00 A used stock radiator. $25.00 A brand new rear led tail light and bracket (polished). $25.00 A motion pro twist throttle with black oury grips, missing the large screw in adjuster on the throttle. $20.00 A slightly used front swingarm pivot bushing (big long one). $10.00 A used set of cascade pipe clamps that were on some pt mids. $10.00 A used set of chrome stock foot pegs that have chrome peeling off them. $20.00 A used set of Innova Sand Gear front dune steer tires 22x8x10 on SS (stamped series) aluminum rims. They are the dual rib front steer tires. These are currently on my bike. $120.00 A stock used tie rod. $5.00 A thumb throttle cable for twin carbs. $10.00 A stock used outer tie rod end. $5.00 A stock used stator cover with gasket. $10.00
  7. Here is what I have guys. Feel free to PM me or post if you have questions. I have pictures, so if you want a pic, send me your email and I will get them to you. If you guys get multiple things it may be priced different so you can get a package deal. and shipping will vary depending on what you get, and where you live. Send me your email for pics, I dont want to upload them all into photobucket. There is a lot of them. Not all this stuff is in perfect shape, but I will make sure that you know what kind of shape something is in if you are interested in anything in particular. 2 Full sets of banshee stock a-arms. Both sets are silver, and I will split them up if you need a certain arm. The arms are used, but nothing is loose. 1 of the sets is currently on my bike. For 4 arms your looking at $125.00! For each arm it would $35.00! 1 set of Works front shocks in Dual rate. Black spring and a white spring on the shock. Sprung for 180-200Lbs rider. Shocks are used and in good shape. These shocks are currently on my bike. I rode with them when I was a 165Lbs, to the fat ass 194 Lbs I am now. $200.00 Right and left spindles used and in good shape. $40.00 Right and left Stainless tie rods with tie rod end joints. $30.00 A set of complete front hubs with bearings and brake discs that are used. $40.00 A set of stock jugs at 64mm bore that need a bore job, and the bottom of the transfer ports have been cleaned up on them. I can have Dan Wade at Patriot Racing bore em before I send them. $100 without the boring done. $225.00 with the boring done. A set of stock reed cages with what look to be older boyeseen reeds on them, they are used. $25.00 A set of stock intake boots with a stock boost bottle, they are used. $20.00 A set of used graydon nerf bars with black webbing, has all hardware. $50.00 Stock radiator caps that are used. $3.00 A used cascade front swingarm chain slider in black. $5.00 A red lonestar axle nut (used). $25.00 A used rear brake lever. $15.00 A used set of 1989 front brake calipers with flexible and hard lines. $45.00 A used DG front bumper. $25.00 A used Cascade quick release flag mount. $10.00 A couple sets of stock banshee swingarm chain adjusters, along with some of the long adjuster bolts. Some brand new and some used. $5-$10 depending on which one A used White brothers boost bottle. $5.00 A used and polished front brake resevoir cap. $10.00 A used stock headlight/kill switch. $10.00 A used set of cascade rear fender support brackets. $5.00 A used set of blue radiator and tank plastics. $45.00 A used aluminum bar clamp with key switch and light mounts. $15.00 A used stock radiator. $25.00 A brand new rear led tail light and bracket (polished). $25.00 A motion pro twist throttle with black oury grips, missing the large screw in adjuster on the throttle. $20.00 A slightly used front swingarm pivot bushing (big long one). $10.00 A used set of cascade pipe clamps that were on some pt mids. $10.00 A used cascade aluminum clutch inset cover. $10.00 A used cascade aluminum water pump cover. $30.00 A used chrome kickstarter that needs a rebuild kit. $10.00 A used set of chrome stock foot pegs that have chrome peeling off them. $20.00 A used set of Innova Sand Gear front dune steer tires 22x8x10 on SS (stamped series) aluminum rims. They are the dual rib front steer tires. These are currently on my bike. $120.00 A stock used tie rod. $5.00 A thumb throttle cable for twin carbs. $10.00 A stock used outer tie rod end. $5.00 A stock used stator cover with gasket. $10.00
  8. Here is what I have guys. Feel free to PM me or post if you have questions. I have pictures, so if you want a pic, send me your email and I will get them to you. 2 Full sets of banshee stock a-arms. Both sets are silver, and I will split them up if you need a certain arm. The arms are used, but nothing is loose. 1 of the sets is currently on my bike. 1 set of Works front shocks in Dual rate. Black spring and a white spring on the shock. Sprung for 180-200Lbs rider. Shocks are used and in good shape. These shocks are currently on my bike. I rode with them when I was a 165Lbs, to the fat ass 194 Lbs I am now. Right and left spindles used and in good shape. Right and left Stainless tie rods with tie rod end joints. A set of complete front hubs with bearings and brake discs that are used. A set of stock jugs at 64mm bore that need a bore job, and the bottom of the transfer ports have been cleaned up on them. I can have Dan Wade at Patriot Racing bore em before I send them. A set of stock reed cages with what look to be older boyeseen reeds on them, they are used. A set of stock intake boots with a stock boost bottle, they are used. A set of used graydon nerf bars with black webbing, has all hardware. Stock radiator caps that are used. A used cascade front swingarm chain slider in black. A red lonestar axle nut (used). A used rear brake lever. A used set of 1989 front brake calipers with flexible and hard lines. A used DG front bumper. A used Cascade quick release flag mount. A couple sets of stock banshee swingarm chain adjusters, along with some of the long adjuster bolts. Some brand new and some used. A used White brothers boost bottle. A used and polished front brake resevoir cap. A used stock headlight/kill switch. A used set of cascade rear fender support brackets. A used set of blue radiator and tank plastics. A used aluminum bar clamp with key switch and light mounts. A used stock radiator. A brand new rear led tail light and bracket (polished). A motion pro twist throttle with black oury grips, missing the large screw in adjuster on the throttle. A slightly used front swingarm pivot bushing (big long one). A used set of cascade pipe clamps that were on some pt mids. A used cascade aluminum clutch inset cover. A used cascade aluminum water pump cover. A used chrome kickstarter that needs a rebuild kit. A used set of chrome stock foot pegs that have chrome peeling off them. A used set of Innova Sand Gear front dune steer tires 22x8x10 on SS (stamped series) aluminum rims. They are the dual rib front steer tires. These are currently on my bike. A stock used tie rod. A thumb throttle cable for twin carbs. A stock used outer tie rod end. A stock used stator cover with gasket.
  9. Here is what I have guys. Feel free to PM me or post if you have questions. I have pictures, so if you want a pic, send me your email and I will get them to you. 2 Full sets of banshee stock a-arms. Both sets are silver, and I will split them up if you need a certain arm. The arms are used, but nothing is loose. 1 of the sets is currently on my bike. 1 set of Works front shocks in Dual rate. Black spring and a white spring on the shock. Sprung for 180-200Lbs rider. Shocks are used and in good shape. These shocks are currently on my bike. I rode with them when I was a 165Lbs, to the fat ass 194 Lbs I am now. Right and left spindles used and in good shape. Right and left Stainless tie rods with tie rod end joints. A set of complete front hubs with bearings and brake discs that are used. A set of stock jugs at 64mm bore that need a bore job, and the bottom of the transfer ports have been cleaned up on them. I can have Dan Wade at Patriot Racing bore em before I send them. A set of stock reed cages with what look to be older boyeseen reeds on them, they are used. A set of stock intake boots with a stock boost bottle, they are used. A set of used graydon nerf bars with black webbing, has all hardware. Stock radiator caps that are used. A used cascade front swingarm chain slider in black. A red lonestar axle nut (used). A used rear brake lever. A used set of 1989 front brake calipers with flexible and hard lines. A used DG front bumper. A used Cascade quick release flag mount. A couple sets of stock banshee swingarm chain adjusters, along with some of the long adjuster bolts. Some brand new and some used. A used White brothers boost bottle. A used and polished front brake resevoir cap. A used stock headlight/kill switch. A used set of cascade rear fender support brackets. A used set of blue radiator and tank plastics. A used aluminum bar clamp with key switch and light mounts. A used stock radiator. A brand new rear led tail light and bracket (polished). A motion pro twist throttle with black oury grips, missing the large screw in adjuster on the throttle. A slightly used front swingarm pivot bushing (big long one). A used set of cascade pipe clamps that were on some pt mids. A used cascade aluminum clutch inset cover. A used cascade aluminum water pump cover. A used chrome kickstarter that needs a rebuild kit. A used set of chrome stock foot pegs that have chrome peeling off them. A used set of Innova Sand Gear front dune steer tires 22x8x10 on SS (stamped series) aluminum rims. They are the dual rib front steer tires. These are currently on my bike. A stock used tie rod. A thumb throttle cable for twin carbs. A stock used outer tie rod end. A stock used stator cover with gasket.
  10. I have 1 vp can and 2 scribners. I get good fuel with all 3 cans when I store it. The cans are white and yellow.
  11. I have a theory about guys with humongous sig pics and a mile long sig/Avatar description...........
  12. You can bore your own for less money than it would cost for cylinders, and you will more than likely still have bores left on them.
  13. I also have a set with the bottom of the transfers cleaned up.
  14. I buy Sunoco 110 out of the pump nearby me usually the week before I go riding. I had some left over in April, and just used it at the end of June. I have used Sunoco 110 that sat around in my 5 gallon plastic scribner jugs for 90+ days with no issues.
  15. I have a set of works front shocks I would sell off my bike for $225.00!
  16. Stock set of 64mm cylinders that need bored. Have the bottom of the transfers cleaned up. $150.00 shipped.
  17. The old school gold series pipe was a damn good pipe in its day.
  18. Not likely. You can probably buy a bike that will be faster and more reliable for less money than it would cost to retrofit a chassis.
  19. Snopczynski
    a arms
    Call Tim at Stellar and have him make you a set, they are $400 in bare finish with tie rods I believe.
  20. I still hate modquad heads.
  21. I also have two sets in good shape as well. PM me if your interested.
