Snopczynski
    2
  1. There is an LT HQ, find the DR. Q guy on there. He is the master of all that is LT. Dave Roberts at ILR Performance can extend a swingarm for ya as well.
  2. I LIKE PRO CIRCUITS BETTER.
  3. Rudy Kurtz is a legend.
  4. Ronnie Saner of RSR used to be one of their engine guys. He is still around and does engines. Ronnie was the guy who ported my old JD bike and it was fast as fuck.
  5. if you have to have paul turners, then you obviously get the mids with an mx port job.
  6. USE THIS THREAD, THE OTHER ONE HAS AN OUTDATED LIST OF WHATS IS LEFT.
  7. yes. Put in a 3/8" spacer and move it to the side of the reed closest to the carb. You will see a small top end hp gain
  8. You guys dont even know if he asking about 2 stroke oil or transmission oil. Before you go making suggestions, you need the answer to that question.
  9. Spacers add midrange power when you space out the reed. You go too far, and it increases the crankcase volume quite a bit, thus not making the cycle efficient. Regardless of what it does, running spacers on a motor with cpi's is going in the wrong direction.
  10. Dont ever use pennzoil in anything.
  11. what pipes are on that motor?
  12. I posted in the outdated thread and said the bumper and nerf bars are gone several days ago.
  13. get a round house + new swingarm.
  14. no, there is an updated for sale list here= http://bansheehq.com/forums/index.php?showtopic=133929
  15. The kick starter sold about 4 days ago.
  16. I like the cpi alot more than the T5's for a mid-top pipe. For what your doing I would get an mx port, nothing much over 190 degree exhaust duration at most. Then a set of dual stage carbon fiber reeds, compression bumped to 155-160psi (dome size depends on Porting)then slap a set of Pro circuits on it. Round that out with about 3-4 degrees of timing advance. That will make a nice little start for ya.
  17. I recommend the Mr. Gasket Thermocap. Cheap, reliable, easy to install, and accurate.
  18. Cascade Front Chain Slider *SOLD*
  19. I will make package deals for multiple items, and combine shipping. If you dont like the price I have on something, then post or PM me and make an offer. Click the link below for pictures (there are 3 pages on photobucket with pics, so look at all the pages). Not all this stuff is in perfect shape, but I will make sure that you know what kind of shape something is in if you are interested in anything in particular. Feel free to post or pm me with any questions. You can email me also. Some of the parts are currently on the front end of my bike, so don't forget to look at those pics too. I do still have some stuff that I haven't listed, so feel free to ask if you have something you need. Pictures: Parts Link *Click Here* 1. Set of silver A-arms all 4, curently on my bike. Finish is decent with normal surface rust on them from use. All the joints are tight, and the arms are straight and in good shape. These will come with the plastic bushings in them. Will sell them as a set for $110.00 or part them out individually for $35.00 each. LU, LL, RU, RL 2. Set (2nd set) of silver A-arms (all 4) in the shop that are also silver. These also have some surface rust, but the joints are tight, and the arms are straight. They dont look as nice as the a-arms on my bike. Each arm comes with a set of bushings in it, the end caps, and the mount bolt. These arms can be sold as a set for $90.00 or part them out individually for $27.00 each. LU, LL, RU, RL 3. Right side spindle $20.00 4. Left side spindle $20.00 5. Set of (Right and Left) tough Stainless steel tie rod tubes, with yamaha tie rod ends installed in them. they are stock length rods and are currently on my bike. $30.00 6. Left front hub with bearings and brake disc. $17.00 7. Right front hub with bearings and brake disc. $17.00 8. Set of stock reed cages with what look to be older boyeseen reeds on them $20.00 9. Stock radiator caps that are used. $3.00 10. Cascade front swingarm chain slider in black. $5.00 11. Rear brake lever. $12.00 12. Set of 1989 front brake calipers with flexible rubber and hard brake lines. $40.00 13. Cascade quick release flag mount. $10.00 14. Couple sets of stock banshee swingarm chain adjusters, along with some of the long adjuster bolts. Some brand new and some used, prices vary depending on what set you want. $5.00-$10.00 15. White brothers boost bottle. $5.00 16. Polished aluminum front brake resevoir cap. $10.00 17. Stock headlight/kill switch. $10.00 18. Set of blue radiator and tank plastics. $40.00 19. Stock radiator. $22.00 20. Motion pro twist throttle with black oury grips, missing the large screw in adjuster on the throttle. $20.00 21. Set of chrome stock foot pegs that have chrome peeling off them. Good for making custom double pegs. $20.00 22. Set of Innova Sand Gear front dune steering tires 22x8x10 on SS (stamped series) 6" wide aluminum rims (4+2 offset). They are the dual rib front steer tires. These are currently on my bike. No dents or bends in the rims, and the tires are in good shape. $110.00 23. Stock used tie rod. $5.00 24. Thumb throttle cable for twin carbs. $10.00 25. Stock outer tie rod end. $5.00 26. Stock stator cover with gasket. $10.00 27. Stock Rear chain slider $5.00
