kawiking
Everything posted by kawiking
  1. race i know ive talked to you before. for got were you were from. im in texarkana.
  2. well i went ahead and bought a set of 12' shocks off of bansheesuperstore. thanks for the help.
  3. i know that ced built his own drag frame for it. looked good!!!
  4. ive got a plus six swing, and running a 22 inch hauler. you think 7 inches would be ok ?
  5. whats a good boyesen reed. im having mine drag ported. stock cyln. buudy had some pro seires i was going to buy but when took his motor apart and they were broke.
  6. anyone running a lowering kit?
  7. i got a set of cpi out of frame pipes from my buddy but the stingers got bent off.going to have some made. does anyone know how long they are suppose to be??
  8. will v force reeds work on a stock reed cage??
  9. how long are banshee stock shocks. found some 12' shocks on bansheesuperstore. im thinking of going with them or crj lowering kit.
  10. thanks for the info firehead
  11. i remembered. CED (atv connection forum ) 96'scram... i think it was running 4.? on 300ft sand/dirt drag
  12. the baddest polaris i seen was polarisfreak(atvconnection forum) !!!! he sold his parts to guy in louisiana.
  13. u still have those 34's
  14. kawiking
    Carbs needed
    bump
  15. e-bay assholes suck !!!!!
  16. got another stock shock on e-bay, hope it will help keep my tires down. blown shock wasnt working. going to try and gear up before i go ten paddle.
  17. gear up.. thought the front was 12. just bought a 13 and 14 the otherday. damn!!!!
  18. will it be ok for awhile if i run stock carbs on it if i getting the jetting good. i know it wont have all the power but it wont hurt the motor will it. i mean do u think i can jet a stock carb high enough
  19. whats the stock sizes of front aand rear sprockets
  20. im running cpi out of frames. mukini or keihin carbs??? i have a yfz 450 carb on my kfx400 and i love it. its so easy to rejet!!!
  21. port match them ????
  22. im getting my bike back together and i decidied to have a drag port done. my mods are-- shaved fly wheel,shaved reed cages,+4 timing,shaved head .030,f.a.s.t. clutch,just been bored .040,hot rod crank. i use for sand drags and duneing. i run a +6 swing arm. my ? is what size carbs should i go with ?? and mukini or keihin ??
  23. im getting my bike back together and i decidied to have a drag port done. my mods are-- shaved fly wheel,shaved reed cages,+4 timing,shaved head .030,f.a.s.t. clutch,just been bored .040,hot rod crank. i use for sand drags and duneing. i run a +6 swing arm. my ? is what size carbs should i go with ?? and mukini or keihin ??
