banshee332
Everything posted by banshee332
  1. I have tested, 3 sets of snipers. 2 oofs and one set of inframes. All the rusults where for the better
  2. acutely its the other way around, a 39 pwk will flow more then an a 42mm lectron
  3. pms are cleaned
  4. Looking for a stock clutch basket with gear, and kicker gear on back. With little to no play from the gear to the basket
  5. Thanks guys. It has a stock plate the key way is fine. so its not ignition. So it has to be the reeds. Guess I will pull them out and replace..thanks again
  6. Ok now im a drag guy and not use to working on almost stock banshee's. I think I know the answer or answers to this but heres the question. I have a banshee that I think might be ported not sure havent checked, It has fmf pipes and k&n filter with no lid. The problem is, when you rev it up it will back fire sometimes and you can see a flame in the carbs. Any ideas?
  7. what size drill bit would be 118 or 121? what needles do you think be best shayne it had dek.
  8. it has 118 or 121 mains. how do you measure the main. there was dek in them when I bought them. Its for a 10mill cub
  9. what needles for alky eel?
  10. I might be interested in a top end
  11. My guess would be it's to rich and loading up causing it to bog
  12. Jojr, has a vitos top end that was done by k&. my 10mill cub that is heavily ported and has other mods dynoed 114 on gas with sb snipers
  13. He also tired sb shearer oof's, the snipers out performed both sets of out of frame drags pipes
  14. I must add the inframes sound badass Best sounding inframes that I have ever heard
  15. Ok im giving a full report on the snipers. 3 races ago before they tired the snipers they could never get the hjr 421 to run right. So they took it to a local shop and got the porting touched up. Best it would do was 6.4 @91 with cpi's pretty close to being tuned in. It was pretty consistent at 6.5's Now this is a 500ft track. The race after that is the first time we ever tired the sniper inframes. the first pass was a high 6.4@91 with out changing anything. So I got jetting on top right and the bottom was off and we ran out of pass's to correct the problem The best for that night was a low 6.4@92mph. This race 7/23/11 I fixed the bottom end jetting the track was not as good as it was the race before and the temperature was about 10 degrees hotter and the humidity was higher this race. First pass right off the trailer was a high 6.3@93, second pass was a [email protected] mph after that the track just was not as good as it was the first round. He mostly ran 6.3's @ 92-93mph. I would say on a cooler day with better track conditions he should see 6.2 mybe 6.1's. So on average his e.ts dropped 2 tenths and picked up around 2mph with the snipers over the cpi's. He has not really placed to much this year but tonight he got to 2end places.
  16. I have tested 3 sets so far. One on my 10mill cub oof's, one on a 4mill cub oof's and one on the hjr 421 inframes. All have seen results in the positive. The hjr motor is a bugger its just not real responsive to anything we try with it besides the snipers. We are going the right way with it though I should have better results with the hjr 421 cub next race.
  17. did I mention these are in frames
  18. Well I had the chance to test out some inframe sniper this weekend. Just bolted on from switching over from sb cpi offs they ran the same time and mph. We started to lean her down and ended up with almost 94mph from 90.5mph. it has a bog on the bottom that I will have to work out next race but with the bog it still managed to pull more mph then the cpi's could. Zach the owner said he never felt the bike accelerate like it does with the snipers and he tired shearers two races before this one. So all 3 sets of sniper that I have tested to far has out performed every pipe that I have tired. You just cant through them on your bike and expect them to work you have to tune to them.
  19. ttt
  20. what you guys got?
  21. Both sets that I tired out improved both bikes, my buddy has an hjr 421 im going to try and see if I can get a set and try on it. Something just isn't right with it, it runs ok but not anywhere the it should I'm hoping a set of these pipes will help it out some. Not sure if they will but it should.
  22. I would like to know of all the people that has a set and how they are liking them so far. I switched to snipers on two motors and both improved e.t's. I Have a st of hand built snipers for the dmx that I have not gotten to run yet.
  23. Can Someone post some pics of how boss nos is hooked up to a banshee
  24. lol he has a strut on the rear. The bar is a single tube going up. no braces or anything. the wheel sits anywhere from 3-6 inchs off the ground depending where he has it set. chromoloy for the bar I think. the bar is like 5ft. he needs a longer swing arm
